Like Tree4Likes
Old 06-21-2013, 10:02 PM   #4231
Q: with the kind headz motor mount and center dif parts do i need the king headz top plate or can i use the stock piece with the wire channel???
bbond919 is offline   Reply With Quote
Old 06-21-2013, 10:20 PM   #4232
Frank L's Avatar
Trader Rating: 148 (100%+)
Just watch your temps. I had to drop back to a 13 on a smaller track.
Old 06-21-2013, 11:06 PM   #4233
rcgod's Avatar
Trader Rating: 27 (100%+)
Stock fits.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-22-2013, 03:55 AM   #4234
I have a few questions for you guys because I'm a noobie to racing again since I haven't been into r/c since 2005. A lot has changed...
My setup is Tekin rx8 gen2, Tekin 4300kV pro4 HD, with a 6500mAh or 7200mAh SMC battery. What pinion gear should I run? I'll also be using the current limiter, will I need to change pinions when doing so?
I haven't bought a steering servo yet. What's a good enough servo that can handle this truck that isn't outrageously expensive? I don't know much about servo specs or what this truck needs.
DA6righthand is offline   Reply With Quote
Old 06-22-2013, 04:09 AM   #4235
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up
STOCK WORKS JUST FINE
Normal track use 14T if its Big try 15T but check temps of motor anything over 185* is considered too hot
Spektrum S6040 Digital Titanium Gear High Speed Surface Servo about $70
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-22-2013, 05:31 AM   #4236
TrailblazerSS81's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Frank L View Post
That's a lot of motor for this truck and that motor is very heavy. Where are you running it at? And on how many cel?
I'm running on an1/8 size track with a 4cel.
Byron Fuels/Airtronics M11x/Mugen Seiki/Hitec/TLR/Tekin/ProTek Supreme Power/Xray XT9
TrailblazerSS81 is offline   Reply With Quote
Old 06-22-2013, 05:51 AM   #4237
Grandturk's Avatar
Anyone run both the Savox 1258TG and the Spektrum 6040? Any performance comparisons? Looking to replace the 1258TG that I've been using for 2 years with something that feels a little smoother.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 06-22-2013, 06:34 AM   #4238
nanoverse's Avatar
Originally Posted by rcgod View Post
Well guys, you asked for it and here it is! The new BCE SCTE 2.0 chassis.
Bill and I have been working together for the last three months to produce the best chassis available for this truck. We feel we have improved on the stock chassis in several areas. 7075 aluminum for increased durability, the battery is mounted lower on the chassis for lower COG, increased torsional stiffness for better steering feel, and multiple rear chassis brace options for varying track conditions and driving styles.
There are a limited quantity available currently, so if you want the best, contact Bill through his website at www.BCEspeed.com
The chassis will be added to the website in the next couple of days, so if you don't see it, don't worry. There are some available! Contact Bill and he will take care of you. Bill wanted to give you guys the first shot at this chassis for all of your support here at RCTech. He knows he has many loyal customers here, so this is his way of saying Thank You.
No, 1.0 to 2.0 chassis? My 1.0 is so pimped up and working good that I won't be bying a 2.0 soon. 2.0 has also too many small things that I would like to see changed.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 06-22-2013, 06:45 AM   #4239
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Originally Posted by NITROALM View Post
Big Thanks RCG Thank you for all of you help ,for your post and the little sneak peak
We will have much more here, in the next few days.Racers feel free to drop us a line if you need any additional info
BEAST
I will now convert my 1.0 to 2.0 Via BCE.
Losi 5ive T: Bartolone XP Pipe- Zenoah - Turlte Racing - Savox -Team Hoonage
SCTE 2.O BCE H1 HW SCT Pro/HW 4000/Savox
Feint Motion is offline   Reply With Quote
Old 06-22-2013, 06:46 AM   #4240
I've used the 6040 for about a year and it is fine. I think it is the recommended servo for the 2.0.
bladeys is offline   Reply With Quote
Old 06-22-2013, 06:51 AM   #4241
nanoverse's Avatar
Radiopost green is super!
Hitec Lynx 4s
Old 06-22-2013, 06:58 AM   #4242
Grandturk's Avatar
Oh I've heard they're good let me check on that!
Old 06-22-2013, 07:10 AM   #4243
rcgod's Avatar
Sent you a pm.
Dialed RC Hobbies
Old 06-22-2013, 07:19 AM   #4244
Stock fits.
any benefit to running the metal king headz top plate? other than the cost of course
Old 06-22-2013, 08:09 AM   #4245
reckboy's Avatar
Originally Posted by Feint Motion View Post
BEAST
I was thinking the same thing.
-Losi Mini 8ight | Losi Mini Crawler | Duratrax Evader Brushless | Losi Ten-SCTE
reckboy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 25 (1 members and 24 guests)
Moogumby
