Like Tree4Likes
Old 06-07-2013, 12:05 PM   #4096
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Purdue Engineer View Post
Is anyone really shimming the ring and pinion? I put mine together like the manual shows and there are no shims in the front or back cases. The only shim, I believe is in the center diff on the motor side I think. I guess the only variable in these is if the center drive shaft is not pushed all the way on the pinion with the pinion being pushed all the way up to the bearing on the inside of the case.
Maybe Hacker or casper can let us know how they shim there's. I'm going to guess it's by the book.
I never shimmed my rear diff on the 1.0 but I was running plastic inserts. I too am now running the alum inserts like Ryan and those have a slight bit more play and am running the included shims with those. It is a bit of a case by case basis and like Ryan said some cases will expand slightly over time and you may need to shim the diff as parts wear in.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-07-2013, 02:52 PM   #4097
With a lot of people testing different setups, has anyone tried stiffer rear springs? Just curious, if anyone has, how did it effect the handling of the truck?
The last 2 weeks I have been running the "dunford standard" setup with the "green'' springs in the rear. The main reason for this is, @ my indoor carpet track there is a small "kicker double" jump on the track." It kicks up the rear of the truck". Many guys would just crank down on the collars to fix this issue. However, I did not like the handling of the truck with the raised rearend. Stiffer springs fixed the issue; and maintained ride hight....It hauls a$$!
arrtay is offline   Reply With Quote
Old 06-07-2013, 03:13 PM   #4098
Frank L's Avatar
Trader Rating: 148 (100%+)
The 1.0 I have has never had to be re shimmed since it was new and I have let my 5yr old drive it pretty hard some days while learning track etiquette. Original r/p still on it and it spins very free now.
I just finished the front on the 2.0 and I thought it was strange that there was not a shim used in the front too.
Old 06-07-2013, 07:06 PM   #4099
BmainStar's Avatar
Originally Posted by rifraf View Post
Good deal! I have seen lots internals of brushless motors and drivetrain problems because of NO load conditions in my 25+ years of R/C racin..anyways,I was just makin a friendly suggestion..it all good for me...
Thanks for the reply
Originally Posted by blade329 View Post
What can cause that to happen?
Dun Know..
1st time it happened ,ran the 1.0 for 2 yrs and neva,I did just switch the alum insrts from the 1.0,never shimmed it in that truck
Originally Posted by BDRMBULLY View Post
Poor shimming of the diff, pinion gear backing out from the ring gear on the diff,
Prolly lack of shims it sounds like to me.Help me out here guys who know about this stuff.What do I look for? and where do the shims go? Thanks...
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 06-07-2013, 07:27 PM   #4100
Frank L's Avatar
Metric hardware please.....
Old 06-07-2013, 08:29 PM   #4101
easye's Avatar
Well got 20 to 25 packs threw the truck and have bearing failure already
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 06-07-2013, 08:40 PM   #4102
easye's Avatar
Originally Posted by BmainStar View Post
Got the 2.0 out Sat nite for the 2nd time and really starting to get a feel for it!!
Unfortunately right before the second qual while revving the motor prior to setting her on the track a clicking sound emerged from the rear diff but I ran anyway. It seemed to stay together :lol :By the main it was loud enough that every one at the track knew something was wrong. I was gonna run her anyway since I was sitting at the TQ spot.
I made to the end took the win but kinda had to limp it around.Finaly dug into the rear diff to see the problem and the ring gear was missing about 4 teeth!!She finished both races and put me on the podium
Cost of new ring and pinion $21.00 finishing first with a battered 2.0 =Priceless.
I don't agree with step D-12. I prefer to install the drive shafts on the pinion to make sure there is no pinion walk on the ring gear depth.
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
Old 06-07-2013, 10:48 PM   #4103
I agree first time I built front diff i followed instructions and the diff would bind just alittle. Took it apart and held the pinion in with finger while I installed drive shaft, then finished diff build. No binding and felt smooth.
I think some of the ring gear problems are because it pushes pinion in on ring gear and causes a a bad gear mesh in the diff when the drive shaft is installed last. Not everytime and not to everyone.
Will Dennis
SCTE 2.0 (VTX8, Tekin Pro4 4600)
Sponsors: VISA, Master Card, and half of wifes pay checks.
(Power is nothing without Control)
SixxGunnz is offline   Reply With Quote
Old 06-08-2013, 11:38 AM   #4104
Is there a way to purchase just the plastic ends of the Torque Rods? I have seen quite a few broken and want to get a couple as spares without having to buy the whole Torque Rod. Has anyone found an end that is stronger or even another brace that might be more durable?
Thanks,
BulldogSRT
BulldogSRT is offline   Reply With Quote
Old 06-08-2013, 12:11 PM   #4105
Casper's Avatar
Thanks,
BulldogSRT
http://www.losi.com/Products/Feature...rodId=LOSA6044
Make sure you thread the set screw all the way into the rod end FIRST and then thread the end into the tube. This way the screw fills the hole in the rod end and makes the assembly stronger!
Old 06-08-2013, 01:43 PM   #4106
BmainStar's Avatar
Not the issue here at all, been building these diffs for over two yrs now but thanks for the suggestion . Shims?????How do I know if I need them? I have never done shimming before???? Thanks...
Toy Car Playerz
West Coast
Old 06-08-2013, 01:50 PM   #4107
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Grab both outdrives in the rear gear box in see if it has side to side play in the gear box, install a shim on the driver side to make the diff be closer to the pinion gear.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 06-08-2013, 01:54 PM   #4108
BmainStar's Avatar
Thanx, that makes sense!!
Headed to the track will def look into this!! Thanx again Bully!!!!
Toy Car Playerz
West Coast
Old 06-08-2013, 02:13 PM   #4109
Frank L's Avatar
The losi cars like to have just a tick or play between the ring and pinion. Hold the outdrives and and rock the center driveline back and forth. There should be a tiny amount of movement. When the gears wear a little sometimes you need to add a shim to the ring gear side to tighten up the mesh. Shim accordingly.
Old 06-08-2013, 02:59 PM   #4110
Just purchased a Scte 2.0 kit. Does it come with the rear alum gear box bearing inserts, cant find it in any of the bags.
Losi SCTE 1.0
TLR SCTE 2.0
Assoc B44.1
WeaselSRT is offline   Reply With Quote
