Like Tree4Likes
Old 06-06-2013, 05:30 PM   #4081
TCCustoms's Avatar
Originally Posted by OfnaJoe View Post
Thanks Casper, so for what I have now about all I need is a chassis and towers?
Originally Posted by Casper View Post
Well actually you need chassis, side guards, servo mount, battery tray, front and rear torque rods, Chassis foam pads for the battery. It is a combo of it all as most of the 1.0 center chassis stuff does not fit on the 2.0 chassis.
basically if you take off the front and rear clips, add the shock towers to them, and slap them on the 2.0 chassis....you will need everything else on the chassis other than the 2 center driveshafts as those are swapped front to rear. You dont really need a new diff, diff mount, or motor mount but the top plate for the diff is new
SCTE 1.0 to 2.0 Conversion parts list
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 06-06-2013, 09:47 PM   #4082
Frank L's Avatar
Trader Rating: 148 (100%+)
Starting a new build. Any tips??
Old 06-06-2013, 10:12 PM   #4083
BmainStar's Avatar
Got the 2.0 out Sat nite for the 2nd time and really starting to get a feel for it!!
Unfortunately right before the second qual while revving the motor prior to setting her on the track a clicking sound emerged from the rear diff but I ran anyway. It seemed to stay together :lol :By the main it was loud enough that every one at the track knew something was wrong. I was gonna run her anyway since I was sitting at the TQ spot.
I made to the end took the win but kinda had to limp it around.Finaly dug into the rear diff to see the problem and the ring gear was missing about 4 teeth!!She finished both races and put me on the podium
Cost of new ring and pinion $21.00 finishing first with a battered 2.0 =Priceless.
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 06-06-2013, 10:13 PM   #4084
Casper's Avatar
Trader Rating: 33 (100%+)
Get some good tools (especially a 1/16 for the diffs)
Take you time.
Read this.
http://losiracing.blogspot.com/2013/...uild-tips.html
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-06-2013, 10:28 PM   #4085
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
Revving a brushless engine in the air is hard on everything...just saying.
rifraf is offline   Reply With Quote
Old 06-06-2013, 10:39 PM   #4086
BmainStar's Avatar
Im talking about a quick 1/2 throttle blip before she hits the track to make sure all is good and I have throttle at all. Just as with the steering will get a quick check as well. Most peeps who race do this. Im not standing there holding full pin and checking things out. LoL
Toy Car Playerz
West Coast
Old 06-06-2013, 10:59 PM   #4087
Good deal! I have seen lots internals of brushless motors and drivetrain problems because of NO load conditions in my 25+ years of R/C racin..anyways,I was just makin a friendly suggestion..it all good for me...
Old 06-07-2013, 01:51 AM   #4088
looks like everyone is digging their 2.0
I might have to move on up :-)
Are most dudes running the Tekin pro4/rx8 set up with the 2.0 ???
hairmetal is offline   Reply With Quote
Old 06-07-2013, 08:36 AM   #4089
Frank L's Avatar
Take you time.
Read this.
Thanks. That's perfect.
I have built many rc's and a good set of tools is priceless I agree.
Are you guys running the 540 pro4 or the HD 550 can?
Old 06-07-2013, 09:18 AM   #4090
The throttle isn't too bad as long as you aren't holding it wide open for a long time. Its the people that have their brake at 100% still for some odd reason and rev it way up and then jam on the brakes...that's what causes heat and most damage, lol.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 06-07-2013, 09:25 AM   #4091
blade329's Avatar
Trader Rating: 114 (100%+)
What can cause that to happen?
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 06-07-2013, 10:13 AM   #4092
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Poor shimming of the diff, pinion gear backing out from the ring gear on the diff,
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 06-07-2013, 11:17 AM   #4093
Purdue Engineer's Avatar
Is anyone really shimming the ring and pinion? I put mine together like the manual shows and there are no shims in the front or back cases. The only shim, I believe is in the center diff on the motor side I think. I guess the only variable in these is if the center drive shaft is not pushed all the way on the pinion with the pinion being pushed all the way up to the bearing on the inside of the case.
Maybe Hacker or casper can let us know how they shim there's. I'm going to guess it's by the book.
Purdue Engineer is offline   Reply With Quote
Old 06-07-2013, 11:22 AM   #4094
tc5 man's Avatar
Ive ran this truck for a long time never had to shim the diffs at all no issues my guess is because your only running on a 2s . Now if you never check the bearings inside the gear box than i can see the diffs stripping if you have a gritty bearing or just bad.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 06-07-2013, 11:47 AM   #4095
I have seen some diff cases that wear out or are exposed to extreme conditions need to be shimmed from time to time. It is only the rear diff that I have seen this with due to the motors we are running these days and the extreme torque. I do have mine shimmed as the aluminum rear bearing holders come with shims but it will be different for each vehicle.
-Ryan Dunford
