Like Tree4Likes
Old 06-05-2013, 09:51 AM   #4051
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Casper View Post
Ryan suggests to double check your toe out in the front. Push the front tires in to take out steering slop when adjusting toe out on the front end. A little more toe out will make the truck more stable on exit. If your track is bumpy or loose 5K in the center would calm it down but take away a little of that forward bite you like. The other setup changes effect the forward drive as well so it should not be a dramatic change in foward bite.
I will double check my toe out as well as try 5K in the center at some point.
Originally Posted by hacker07 View Post
Thanks or the feedback, still working on it a bit. I can tell you that when Casper changed to the 4 hole setup, it locked his truck in a bit better. It does not land as good as the 2 hole setup with the shocks though. We are still messing around to find a balance there.
Ya i definitely like how the 2 hole pistons land jumps.
maddog9 is offline   Reply With Quote
Old 06-05-2013, 10:40 AM   #4052
rcgod's Avatar
Trader Rating: 27 (100%+)
Have you guys tried a 4 hole piston with 2 smaller holes and 2 bigger? Seems like it will might give more progression to the pack and give the best of both. Or maybe a 3 hole setup.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 06-05-2013, 10:59 AM   #4053
We have been talking about both actually and trying to figure out what to test.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 06-05-2013, 11:03 AM   #4054
rcgod's Avatar
Cool. I just ordered the 4x 1.1/1.5 pistons from avid to try this weekend. I have a spare set of shocks and will try 3 hole. Any suggestions on what size holes I should try?
Dialed RC Hobbies
Old 06-05-2013, 11:17 AM   #4055
Casper's Avatar
Trader Rating: 34 (100%+)
We have a few things we want to try and see how it works. It is just getting the track time to play with them right now. It will probbly be unitl later this month before we get enough time to gather the data on more testing but things along those lines will be tested.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-05-2013, 11:40 AM   #4056
suby723's Avatar
Trader Rating: 21 (100%+)
It cracks me up that you guys can't accuratly adjust front toe because of all the slop. I'm sure a tlr part will eventually take care of that.
suby723 is offline   Reply With Quote
Old 06-05-2013, 11:41 AM   #4057
Casper's Avatar
The issue is pistons and oil have to be worked out together so hard to tell what is going be best and how it will all play together. I would imagine the 1.1/1.5 will not be enough damping as the 1.5 2 holes are already much larger then what we are currently playing with in a 2 hole ~1.3. So plan to go up in oil a bit.
Old 06-05-2013, 11:47 AM   #4058
Casper's Avatar
We are running a bit of toe out and sometimes it looks like more than it really is. There is not that much slop in the system with the 2.0 and HA balls there as there is with any car there is play in the system.
Old 06-05-2013, 12:07 PM   #4059
blade329's Avatar
Trader Rating: 114 (100%+)
Most cars do. The SC10 2wd is notorious for front end slop. My T4.1 has the same thing.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 06-05-2013, 01:20 PM   #4060
allan42r's Avatar
like my truck setup but im setting it up to run in the ebuggy class. need to add weight so im thinking a 3 cell with a tekin hd motor. not sure on what kv to go with? 10 min mains, slick tracks. thinking the 2500 kv?
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 06-05-2013, 03:29 PM   #4061
You're just pissed off that you were faster with your losi than you are with your tekno. The only thing you have to bitch about is the slop on the losi. How about the crappy stock setup on the tekno?
I'm sure the added weight of the tekno suits your driving style better since you like to punt guys from the rear.
When you're a factor at any track other than norcal then you can talk. Now you can go back to the tekno thread and swing on those nuts.
Homer723 is offline   Reply With Quote
Old 06-05-2013, 03:34 PM   #4062
Casper's Avatar
Calm down. We don't need to start this all over again.
Old 06-05-2013, 03:42 PM   #4063
It is common for folks to go into other threads to see what the competition is doing and all. I don't see the necessity for making comments as he did but oh well, it happens. There is some slop in our steering, but there is some slop in most parts of any off road car. Not saying we don't work to make it better as we have with the 2.0, but slop or no slop, the 2.0 is the fastest 4wSC out there right now in many of the different conditions.
-Ryan Dunford
Old 06-05-2013, 04:14 PM   #4064
Are any of the 4 hole 22 pistons the same as the #3's?
Dave Hoare
Sponsors: Visa....
SuperDaveNT is offline   Reply With Quote
Old 06-05-2013, 04:21 PM   #4065
3's are 1.05mm holes. A #58 would be the closest at 1.067mm and the smallest hole we make for the 22 is a 57 which is a 1.092mm which is closer to a #4.
-Ryan Dunford
