Like Tree4Likes
Old 06-03-2013, 10:56 PM   #4021
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by picco007 View Post
Hey guys, I wanted to ask how everyone is putting the bottom cap on the shock? Its not as easy as it was when I rebuilt my 1.0 shocks a while back. Is there some after market aluminum shock bottoms available?
Contact Horizon and they can send you out some replacements. The first batch kits the caps had bad threads.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-03-2013, 11:32 PM   #4022
Some where on the first thread in the build tips it talked about the bottom caps having some srinkage when they came out of mold and told how to get them to work if you didnt want to wait on replacements.
Screw the bottom cap on as tight as you can with fingers. Then put the aluminium top on. Using the shock tool that comes with the kit that tightens the top and a pair of pliers on bottom cap spin shock assembly till bottom cap seats. Then using both shock tools to untighten shock cap and finish build.
Link to video
http://losiracing.blogspot.com/2013/...uild-tips.html
Will Dennis
SCTE 2.0 (VTX8, Tekin Pro4 4600)
Sponsors: VISA, Master Card, and half of wifes pay checks.
(Power is nothing without Control)
SixxGunnz is offline   Reply With Quote
Old 06-03-2013, 11:42 PM   #4023
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Anyone run a bit less rear antisquat for looser bumpy tracks? Work good?
Blitzrockey is offline   Reply With Quote
Old 06-04-2013, 12:04 AM   #4024
Originally Posted by XXXDad View Post
Ok started my install of new setup,
using 1.3 2 hole pistons not sure the shock oils Front 27.5 Rear 25
5/5/5 dif ( for loose outdoor) can go to 7000 in center easy, just want to try 5000
its an experiment with suggestions
from the TLR guys.... outdoor track, mostly med traction.
I will keep you updated....
Did you get a chance to try this set up Glenn?
SuperDaveNT is offline   Reply With Quote
Old 06-04-2013, 03:14 AM   #4025
StepPins's Avatar
Originally Posted by LVBaja View Post
Finally got my 2.0 outdoors for the King of Kings race this past weekend in Fremont, Indiana. Used the stock setup with a ProTek 100C 7000mAh lipo and a Tekin Pro4 4600 and AKA Supersoft Grid Irons to take TQ and the win. The truck was great!
Congrats on your win! I too have just purchased a 2.0 and waiting to build it once my gen2 RX8 comes in (on back order). Once built, can't wait to tu e and race it
Btw, what pinion are you running on that track, how long was the main, and what were your temps? Kinda new to sct racing and trying to soak up info and comparisons...
StepPins is offline   Reply With Quote
Old 06-04-2013, 04:08 AM   #4026
XXXDad's Avatar
Trader Rating: 195 (100%+)
Unhappy No sorry not yet..... I was at 1/8 Regionals Miami
Was at 1/8th Regionals... and no time yet. Hope this weekend... for sure I will let you know!
But the rain is killing it.....
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 06-04-2013, 05:49 AM   #4027
Not sure about Scott my boy ran a 14p and it was a 10 min main never checked the temp with the gun but it felt fine.
B-FAST R/C Performance|TLR 2.0|TLR 22 SCT|Schuurspeed
tekinACE is offline   Reply With Quote
Old 06-04-2013, 05:54 AM   #4028
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Thanks, I will contact them today. I appreciate it!
EA Motorsports
picco007 is offline   Reply With Quote
Old 06-04-2013, 05:55 AM   #4029
picco007's Avatar
Link to video
Thanks for the link!
EA Motorsports
Old 06-04-2013, 10:51 AM   #4030
LVBaja's Avatar
Thanks. I was running a 15 tooth pinion and the main was 7 minutes. The motor temped at 135 at the end. Keep in mind I am running the FTW carbon fiber fan mount and fan on my motor though, so that helps keep the temps down.
http://www.amainhobbies.com/product_...unt-w-40mm-Fan
Scott Rapoport; (916) 597-8502; [email protected]
TLR 8ight 4.0; TLR 8ight-T 4.0; TLR TEN-SCTE 2.0
amain.com; AKA; ProTek; OS Engines; Upgrade RC
LVBaja is offline   Reply With Quote
Old 06-04-2013, 10:53 AM   #4031
LVBaja's Avatar
The rest of the electric mains were 10 minutes, but they shortened the 4x4SC main to 7 minutes because guys were worried they couldn't last 10.
Old 06-04-2013, 10:57 AM   #4032
Awww, thats always a bummer when that happens. Should be able to make 10 minutes with one of these no problem.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 06-04-2013, 11:09 AM   #4033
blade329's Avatar
Trader Rating: 114 (100%+)
Having problems building the shocks. I have always sucked at this. In regards to the emulsion caps with the bleeding screws. I followed the directions on a Youtube video, but the shocks never come out right for me. I'll compress the shaft all the way up, some oil comes out, then put the bleed screw into the cap. I pull the shaft all the way down, then it gets sucked back up on it's own. What causes this? I followed the bleed instructions exactly, but it doesn't work for me. What am I doing wrong?
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 06-04-2013, 11:13 AM   #4034
LVBaja's Avatar
Yeah, 10 minutes is no problem with my setup, but oh well, majority ruled on that one.
Old 06-04-2013, 11:19 AM   #4035
Casper's Avatar
With an emulsion shock you have to let the shock suck some air. You are creating a vaccum in the shock when you push the shaft all the way up to displace the oil and then seal it off. Stroke the shock back and forth a few times and it should normalize. A little suck back is not bad as well as a touch of rebound. It is the shock trying to normalize itself.
