Like Tree4Likes
Old 05-30-2013, 10:10 AM   #3991
Originally Posted by MonsterSummit View Post
Awesome thanks for the info!
Also on an unrelated note, what is your opinion, if you have one, between the new 2.0 and the MIP setup. I have run a the 2.0 some(friends car), and I currently have the MIP setup with the towers drilled out for the 2.0 shock locations. I also have ALL the TLR garb on it as well. The only difference I have really seen is the MIP batt is a all the way back, where as the 2.0 is up a little in comparison. Just wondering what your thoughts are as far as 2.0 setups on the MIP conversion.. Basically looking at what 5000 would do in the rear diff, and also the new shock package. Currently I have 5-7-3 and the 2 hole shock setup. Truck is awesome, but as I'm sure you know your always looking to make it better..
Well, the reason for this new different setup was to take advantage and adjust for the weight balance change. The battery being back as far as it is in the MIP truck would be a whole other beast in my opinion. The MIP towers also have different camber positions and this also makes a huge difference. The chassis does flex the same, they change out the steering turnbuckles which plays with the bump steering a lot...all sorts of things are different to be honest.
You can learn from trying some of whats on the new setup maybe on your truck but I would not expect to put it on the truck and have it be perfect I guess is what I am saying.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-30-2013, 10:12 AM   #3992
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by hkrob View Post
I ran Ryan's new setup today @ Tony's hobbies tight indoor clay with good traction. Truck was on rails had lots of steering good rotation rear end was planted I used the full set up except the hex Shims. Also no traction rolling at all can run a lot harder into the corner with out fear of rolling over.
Thanks TLR (Ryan/Casper) for all your hard work.
This is exactly what I wanted to hear. Tony's is where I ran my (new) 2.0 and where I had the steering issues.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 05-30-2013, 03:53 PM   #3993
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up New setup
Ok started my install of new setup,
using 1.3 2 hole pistons not sure the shock oils Front 27.5 Rear 25
5/5/5 dif ( for loose outdoor) can go to 7000 in center easy, just want to try 5000
its an experiment with suggestions
from the TLR guys.... outdoor track, mostly med traction.
I will keep you updated....
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 05-30-2013, 06:11 PM   #3994
Thumbs up Sanpit RC
Proud owner of a 2.0 TLR 4X4. His first 4X4 which took 5 races to get an A-Main win!
B-FAST R/C Performance|TLR 2.0|TLR 22 SCT|Schuurspeed
tekinACE is offline   Reply With Quote
Old 05-30-2013, 06:40 PM   #3995
TCCustoms's Avatar
Oh Man, he is surrounded by trouble...Keep him away from them 2, LMAO!!!
Congrats to You and the Little Man...cant call him a boy cuz he drives better than most men and most def me, lol.
Whats up with the THUMBS DOWN on SandPit, Area51, or whatever its call....never been there but hear about it, just hoping HillsdaleRC could get something set-up locally and do indoors and outdoors but who knows with Shawn
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 05-30-2013, 07:41 PM   #3996
hkrob's Avatar
Trader Rating: 18 (100%+)
I also lacked low speed steering when running at Tony's with the old set up its much better now. The old set up worked really well at Pegasus & west coast I really liked the on power steering. Going to run at Pegasus this Saturday we'll set how this new set up works there.
hkrob is offline   Reply With Quote
Old 05-31-2013, 04:31 AM   #3997
Not sure how the thumbs down got on there The boy had a great time its a fun place to race.
Old 05-31-2013, 05:39 AM   #3998
I have now upgraded from my 810e, I no it's a buggy but still an scte 2.0
goldy is offline   Reply With Quote
Old 05-31-2013, 06:29 AM   #3999
XXXDad's Avatar
Thumbs up Cool
Running on 3's?
Whay body do you use?
Old 05-31-2013, 06:44 AM   #4000
Yep 3s on 3400kv motor. I run an 8ight body cut long at the rear at the moment, but I'm going to try a friends tekno body for size this weekend if its good I think the new finisher will be spot on
Old 06-02-2013, 02:20 AM   #4001
Trader Rating: 20 (100%+)
ok
xxxtruck is offline   Reply With Quote
Old 06-02-2013, 07:27 AM   #4002
Default What motor? Help!
4600 or the new HD 4300? Yes I know new is cooler with lill more torque. On a budget here. Just looking for some input from those that know.
I run large indoor trk, tacky,slippery 1.0 almost 2.0 scte.
Thanks for the help.
fullpull is offline   Reply With Quote
Old 06-02-2013, 08:09 AM   #4003
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Hobbywing 3656 4pole 4000kv. Motor is as powerful and as fast as the two listed at a much cheepere price. Runs cool and very reliable. I use a 14 to 15 tooth and a little boost if needed.
Blitzrockey is offline   Reply With Quote
Old 06-02-2013, 12:08 PM   #4004
TCCustoms's Avatar
Even the 3656sd 4700kv is awesome...
Old 06-02-2013, 01:26 PM   #4005
Thanks for the info guys. To bad it's not related to my question but thanks for the tips
