Like Tree4Likes
Old 05-26-2013, 08:16 AM   #3916
Blown up's Avatar
Broke the center front drive pin lastnite in the second qual and the track store had Tekno cvd's for $18 or losi for $14, I'll give the Tekno a shot, they seem to make great hardened parts. That was the first broken part since I got the truck on it's release. Very pleased!
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 05-26-2013, 09:28 AM   #3917
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by blade329 View Post
Ran my 2.0 (converted from 1.0 w/Bump chassis) for the first time today. I was rather disappointed. It did jump/fly better, but the steering sucked! I'm running the Dunford standard setup on high grip clay.
Do I have a problem somewhere? Has anyone elese had this issue with the standard setup.
Give the new setup Dunford posted a shot. He has added a bit more steering to the truck without giving up rear stability. Make sure you look at the details. Shock length (droop), ride height and make sure the rear arms are not bound and sway bars don't have too much play all that little stuff. It all adds up.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-26-2013, 09:34 AM   #3918
hkrob's Avatar
Trader Rating: 18 (100%+)
How did you guys do at Jbrl yesterday? Did you run the new set up there.
hkrob is offline   Reply With Quote
Old 05-26-2013, 09:36 AM   #3919
Where can I find this setup?
aland is offline   Reply With Quote
Old 05-26-2013, 10:53 AM   #3920
Purdue Engineer's Avatar
Page 259
Hay Ryan did you get a chance to measure the length of your shocks at full droop? I did the turns out on the shaft ends and I got 89mm in the front and 103mm in the rear. Is that about right?
Purdue Engineer is offline   Reply With Quote
Old 05-26-2013, 01:27 PM   #3921
Originally Posted by Purdue Engineer View Post
Page 259
Thanks!
Btw, is this a stupid idea for practice runs? The Pro4HD 1850 as motor in this case.
Old 05-26-2013, 02:15 PM   #3922
Grandturk's Avatar
Originally Posted by aland View Post
Thanks!
What's the point? What are those lipos?
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 05-26-2013, 02:43 PM   #3923
blade329's Avatar
Trader Rating: 114 (100%+)
Originally Posted by bds81175 View Post
Define how it sucked. Corner entry? Corner exit? Not enough high speed? I've struggled with mine to get the steering I want. A bit of toe out, the short Ackerman arm, minimal kickup, and the right diff oil all around (higher in the middle/front, lower in the rear) finally got me the exit steering I wanted. Now I'm moving outside onto lower bite tracks so things will change more.
Corner entry speed. Really bad. I'm going to give Casper's suggestion a shot.
Thanks. I'll give it a shot.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 05-26-2013, 03:04 PM   #3924
Lipos are 2 x 2S shorties in serial, so 4S combined with a 1850kv Tekin HD motor.
Point? Keep temps low and amps at reasonable level without sacrifing any expensivse batteries. Controlling the punch/power by limiting CL in ESC and EPA on the TX.
Only downsides are of course the added weight, 90g more on one side.
I have'nt tried this yet. Only an idea for a practice setup for a hight traction track where the electronics are put to a max on 2S.
Old 05-26-2013, 09:06 PM   #3925
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Good set up for a 10 min main but not in 4s , was considering two 2 s set up as i converted my dingo to run , but decided i have so many tires for scte and didnt wanna buy more tires to run the dingo, waiten fer the new rx8 to pair up the pro 4 hd then ill slap my old rx8 in my dingo for a back up / 2nd qual car to see how i do.
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 05-26-2013, 10:50 PM   #3926
Thanks!
Get the pro4 HD 4300 and some protek 100c 7000 mah stick packs. Tons of power and good run time as well. Able to make 8min main and practice laps as well. I think I saw some posts out there that amainhobbies has a 10% off $100 going on right now.
darkdrgn103 is offline   Reply With Quote
Old 05-27-2013, 05:46 AM   #3927
Trader Rating: 40 (100%+)
hey guys, I am helping a friend purchase his first racer and he decided it would be the losi scte 2.0. I have told him to get a gen2 rx8 and a pro 4 HD but he seems to think the regular pro4 is better for some reason. Is his correct?
Also- what is the minimum torque the servo should have?
MBX7R Eco
MBX7R
MBX7T Eco
Icero is offline   Reply With Quote
Old 05-27-2013, 05:57 AM   #3928
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I run a Savox 1258 and it's more than fast enough and strong enough. I don't think you would want to go much lower than this in the torque department.
http://www.savoxusa.com/Savox_SC1258...avsc1258tg.htm
The standard Pro4's have the nice advantage of quite a bit lighter weight. The HD will have more torque. I can't really imagine needing any more power than I have right now with my Pro4 4000kV but that's me. This class seems to be a bit over powered a lot of the time anyway. As they say many times....slower is faster.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-27-2013, 08:43 AM   #3929
rcgod's Avatar
Trader Rating: 27 (100%+)
The 2.0 is light enough that the regular pro4 hauls it around just fine.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-27-2013, 09:19 AM   #3930
Hey guys im getting 10 mins with the Pro 4 HD 4300 , with castle fan , Castle Mamba Pro sensored mode , and 2s Gen Ace 40c pack , temps on motor 165 , batts 108 , speedo 110 , really looking forward to a Tekin Gen 2 RX8 when they are available , also what do you guys think of the temp on the motor is 165 degrees to hot ? also im runing a 15 tooth gear thinking about going 14 maybe it would cool the motor down some , whats your opinion guys ? thanks
Ed
mavdriver is offline   Reply With Quote
