Like Tree4Likes
Old 05-23-2013, 09:54 AM   #3901
Originally Posted by maddog9 View Post
ok thanks i will give the setup a try with the 2 hole setup.
If you are outdoors I would see using it with the 2 hole setup. For now, I recommend folks try it as described with the 4 hole pistons.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-23-2013, 06:13 PM   #3902
I`ve been running mostly outdoors and the only thing i did was change the rear schocks to 35 weigth associated oil (thats what i had ) the rear was bottoming out big time on the woops and the big table top , now seems good but still need to do more dialing in , love the truck also guys do yourself a favor change the rear hubs to alluminun they look great and will handle anything you can throw at it , i snap my stock left hub on my fourth run I will never run the stock rear hubs again way to weak , you would think losi would had throw that in the kit , oh well
mavdriver is offline   Reply With Quote
Old 05-23-2013, 07:20 PM   #3903
Trader Rating: 1 (67%+)
Which are the front camber links? The polished links in bag B or the more dull links? They appear to be the same length but just want to check.
stang is offline   Reply With Quote
Old 05-24-2013, 05:43 PM   #3904
Blown up's Avatar
Doe's anyone have the part# for the gold TD turnbuckles guys are using?
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 05-24-2013, 09:44 PM   #3905
hkrob's Avatar
Trader Rating: 18 (100%+)
#Tdr310214 is what I used for the gold turnbuckles they are off a dex408 buggy. I had to drill out the rod ends to get the larger 5mm turn buckles started I don't remember what size drill bit I used.
hkrob is offline   Reply With Quote
Old 05-24-2013, 09:56 PM   #3906
The titanium turnbuckle set from the 8ight 2.0 fits perfect.
-Ryan Dunford
Old 05-24-2013, 10:11 PM   #3907
hkrob's Avatar
I buy losi products most of the time But the Durango turnbuckles are 1/2 the cost of the losi titanium.kinda hard to pay twice as much to achieve the same thing.
Old 05-25-2013, 06:05 AM   #3908
ta_man's Avatar
Trader Rating: 151 (100%+)
Yeah, but the Durango ones are aluminum, aren't they?
They may be pretty but will they hold up as well?
ta_man is offline   Reply With Quote
Old 05-25-2013, 07:38 AM   #3909
Hey Guy's! Just ordered my 2.0 kit from Ampdraw Hobbies. Can't wait to start the build. My first time doing a kit. Everything else was either a RTR or roller. I've got the new Tekin Gen2 RX8 on order from Tower. And a 4600kv Tekin Pro4. Also ordered a Savox 300+ 0z in servo from Amain.
kenp is offline   Reply With Quote
Old 05-25-2013, 07:57 AM   #3910
Blown up's Avatar
Ya, The TD ones are alum and half the $.. But there is something to be said for buying parts that bolt right in...
Old 05-25-2013, 09:02 AM   #3911
hkrob's Avatar
Yes they are 5mm aluminum I have yet to break or bend one and I run my truck pretty hard. This is a great hop-up for people looking to cut some weight from the truck with out spending a ton of $$$ on Ti parts. The stock steel turnbuckles are plenty strong I was just looking to save a few #'s.
Old 05-25-2013, 03:18 PM   #3912
I don't have another set of #3 pistons for the rear. I did buy the 22 piston set though. Are any of those pistons the same? The 54's look close if not the same as #3's?
SuperDaveNT is offline   Reply With Quote
Old 05-25-2013, 10:43 PM   #3913
blade329's Avatar
Trader Rating: 114 (100%+)
Ran my 2.0 (converted from 1.0 w/Bump chassis) for the first time today. I was rather disappointed. It did jump/fly better, but the steering sucked! I'm running the Dunford standard setup on high grip clay.
Do I have a problem somewhere? Has anyone elese had this issue with the standard setup.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 05-26-2013, 12:52 AM   #3914
Default My 2.0 losi
I got my losi a month ago, an it is awesome , I just get faster and faster with it, Amainhobbys has them on sale right now, check it out
Lou Figueria is offline   Reply With Quote
Old 05-26-2013, 05:59 AM   #3915
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Define how it sucked. Corner entry? Corner exit? Not enough high speed? I've struggled with mine to get the steering I want. A bit of toe out, the short Ackerman arm, minimal kickup, and the right diff oil all around (higher in the middle/front, lower in the rear) finally got me the exit steering I wanted. Now I'm moving outside onto lower bite tracks so things will change more.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
