Like Tree4Likes
Old 05-19-2013, 11:06 AM   #3841
Trader Rating: 16 (100%+)
Originally Posted by Cackswayn View Post
Sounds like you motor wires might be backwards.
If you set it to sensorless, and remove the sensor wire does it run correctly? If so you have the motor wires hooked up wrong. Make sure your leads are A-A B-B and C-C, then reverse the motor direction in the esc programming if needed.
MX304 is offline   Reply With Quote
Old 05-19-2013, 04:37 PM   #3842
tzbichorsk's Avatar
Somewhere in this thread I saw someone posting that they were using the two hole pistons from the 22 truck instead of the four hole that came with this truck. Could you tell me what the advantage is going this route?. Then I guess I have to ask the usual questions, what springs?, What oil?, And what kind of track would you use this setup on?.
tzbichorsk is offline   Reply With Quote
Old 05-19-2013, 05:06 PM   #3843
TCCustoms's Avatar
the 2 hole pistons allow for more pack and the set-up is on the first post of this thread for the set-up info...
I wish Ryan would update the name of the thread that says READ FIRST POST for up-to-date info....like the 22sct has so people check that first post and would find the info 90% of the time that they wanted
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 05-19-2013, 08:47 PM   #3844
easye's Avatar
At what point do you go from 3and 4 pistons to the 2 hole 22 piston setup? What type of track conditions?
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
leisure hours hobbies and raceway. Ez duz it customs.
Al Richards #1 fan Mr.Mellow #5 fan
easye is offline   Reply With Quote
Old 05-19-2013, 09:16 PM   #3845
Blown up's Avatar
This truck has by far been the best handling most durable 4xSC I've owned to date and I've tried them all. It's so easy to drive fast! I can lay down the fastest most consistent laps I've ever run, indoor and out.
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 05-19-2013, 09:16 PM   #3846
Blown up's Avatar
Ryan- TLR's SC body is the slickest looking body out but It would be sweet if someone could get them to make the non-precut 4x4 one just a "skosh" thicker
Old 05-19-2013, 09:33 PM   #3847
Suspended
Trader Rating: 440 (99%+)
That body is definitely super thin! I run one on my tekno sct and it looks great but is super thin.
MattP is offline   Reply With Quote
Old 05-20-2013, 08:32 AM   #3848
We are thickening it up. It was originally supposed to be thicker but the way this one was made, it thins out the plastic too much so we had to go to thicker plastic. It is a running change but we have listened and should be starting to see those shortly.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-20-2013, 08:51 AM   #3849
jyfz2's Avatar
Originally Posted by agarabaghi View Post
Question and I will probably post in the Tekin Pro 4 HD forum also, but...
I just install my pro 4 hd and when i hook it up sensored and set the MMP to Sensored moder and all that i lose reverse and there isnt enough power to move the wheels.
Unplug the sensor wire and the motor runs fine....???
I had one do the same thing. I think mine was a bad sensor board in the motor. Sent mine back to tekin should know something shortly.
RadioPost/SpeedZone USA/VP Pro/WHR Raceway
jyfz2 is offline   Reply With Quote
Old 05-20-2013, 08:57 AM   #3850
Grandturk's Avatar
Good news! While you're at it you should mold some big "TLR" letters into it so all those guys running this body on their Tecknos, SC10's and Durangos roll around with some TLR lettering.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 05-20-2013, 10:26 AM   #3851
easye's Avatar
So there will be a running change to the bodies to make them thicker? What about dimples for body mounts?
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
Old 05-20-2013, 11:05 AM   #3852
easye's Avatar
Also has anyone tried mip bypass1 pistons in the 2.0?
b5m tekin r1
rc8b3 werks
rc8b3e hobbywing
Old 05-20-2013, 11:52 AM   #3853
Blown up's Avatar
I'm stoked on the thicker body! As far as guys running them on other trucks, what eva. TLR will just sell more bodies.
Old 05-20-2013, 01:42 PM   #3854
I tried them when they first came out. Didn't really like them. The 2 hole 22 pistons are the best I've tried.
Homer723 is offline   Reply With Quote
Old 05-20-2013, 06:06 PM   #3855
Purdue Engineer's Avatar
Hay guys
I like playing around with different setups a lot, maybe to much. I was looking at Dakotah's setup from the cactus. I know it was for high bite tracks but do you think it would be good for a moist, clay track? It's usually medium to high bite clay, dirt mix.
Purdue Engineer is offline   Reply With Quote
