Like Tree4Likes
Old 05-13-2013, 01:42 PM   #3781
roberto_1029's Avatar
Send a message via Yahoo to roberto_1029
What's the difference between the 1.0 and 2.0 shocks other then emulsion bleeder style caps?
Losi 8ight-E 2.0--Traxxas slash 4x4 Ultimate (Scalpel Build) --TLR SCTE 2.0
TLR 22SCT--TLR 22T --Axial Wraith
roberto_1029 is offline   Reply With Quote
Old 05-13-2013, 01:45 PM   #3782
rcgod's Avatar
Trader Rating: 27 (100%+)
Hard ano bodies, nitride coated shafts, hard ano balls, aluminum spring adjusters.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-13-2013, 01:52 PM   #3783
Grandturk's Avatar
New chassis, diffs, electronics layout
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 05-14-2013, 12:30 PM   #3784
blade329's Avatar
Trader Rating: 114 (100%+)
My 2.0 chassis arrives today. Now I have everything I need to convert to the 2.0. Can't wait to see the difference between the two.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 05-14-2013, 05:32 PM   #3785
Thumbs up
Originally Posted by hacker07 View Post
The main thing is that if you are using a longer 550 can motor, you will likely want to move the battery to the forward position.
Thanks a lot Ryan, starting the build of the 2.0 this week. You and Casper are awesome lending your time to this forum.
yamasledhead is offline   Reply With Quote
Old 05-14-2013, 05:57 PM   #3786
Blade are you converting a 1.0 to a 2.0 ?
mavdriver is offline   Reply With Quote
Old 05-15-2013, 04:42 AM   #3787
XXXDad's Avatar
Trader Rating: 195 (100%+)
Questions?? ORION R10/4600 Tekin combo
Who Uses the Orion R10/4600 Tekin combo, are there any problems stressing that combo? Are you using sensor wire? I heard you need to run without sensor wire. Or is that some wrong info...
I use the RX8 now and want to move it to my 1/8 scale and drop the R10 in the 2.0
So who has this setup and how's the Temps and Power??
I know to program it I unplug the motor..... but my buddy says he cant run it in Sensor Mode.
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 05-15-2013, 07:56 AM   #3788
blade329's Avatar
Yup.
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
Old 05-15-2013, 08:29 AM   #3789
Too bad you don't have a second RX8, they are shipping gen 2's just so you know, haha. In regards to the R10, it needs to be the R10 Pro for starters. Then if you do not have their box to load the 4 pole software which is the best thing to do and in that case you would run the sensor wire, you would run without with the 2 pole software so it doesn't error into sensorless, it just runs that way naturally. Then you will have full power at least.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-15-2013, 10:11 AM   #3790
Casper's Avatar
Trader Rating: 33 (100%+)
Just to clear that up team drivers are getting RX8 Gen2's very soon. Sounds like shipments to shops are about 30 days away. So very soon!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-15-2013, 02:48 PM   #3791
CanadianNascar's Avatar
I have the Orion R8 with Pro 4600, glitches even with firmware update, it needs a bec..
Couldn't wait for the Gen 2...
http://www.dorc.ca/
CanadianNascar is offline   Reply With Quote
Old 05-15-2013, 03:53 PM   #3792
Blitzrockey's Avatar
Hw v3 or 3.1 works awsome!
Blitzrockey is offline   Reply With Quote
Old 05-15-2013, 04:01 PM   #3793
Trader Rating: 6 (88%+)
What servo horn do you guys use my hits my servo. and I cant get full throw out cuz it hit. it the one from the 22 buggy.
Rcdudes3475 is offline   Reply With Quote
Old 05-15-2013, 04:37 PM   #3794
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Do you have the low profile ball stud on the servo horn? What servo do you have?
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 05-15-2013, 06:02 PM   #3795
Their firm ware update ?
I've heard a Hobby Wing programmer will work with the Orion also, but don't know which one..
http://www.dorc.ca/
