Like Tree4Likes
Old 05-01-2013, 11:23 AM   #3631
Originally Posted by RavensNightFury View Post
yeah i might get one the 4700 version ran really hot
If your 4700kv was geared 13-16 and ran hot the motor is not your problem. You need to go over your truck. I run this motor when geared 13-14 with a little timing. Which totally isn't needed but still does not get over 160.its when your geared 15-16 you wouldn't want or need timing.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 05-01-2013, 12:17 PM   #3632
While agree its always a good idea to go over your vehicle when you are having heat issues that you may or may not have had before, the difference in a drivers type can easily account for as much as 35-40 degrees as far as I have seen so something to keep in mind.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-01-2013, 05:24 PM   #3633
Originally Posted by billg1230 View Post
I will second this 100%! I have the HW 3656sd 4,000kv and it is a wonderful motor... Super smooth, powerful, and runs very cool...
I am going to have to completely agree also! I just switched to this motor and it is great! I had a Trinity 3800kv revtech in there...Cost close to a 150 bucks! I assumed I would get what I paid for; not the case It was a slow turd! So far the HW motor is better in every way!! Only like $76 bucks too!
arrtay is offline   Reply With Quote
Old 05-02-2013, 07:09 AM   #3634
xxfile's Avatar
Originally Posted by Grandturk View Post
Why would you run both and switch between the two?
Our club has 6 racers all sct. We race back to back sct
While one is cooling i race the other. Usually 12 -16 packs / race day.
They both handle quite differently. 2.0 has more steering and is faster thanks to the pro 4 4600 and feels lighter in the front. Actually had to de-tune the 4600 to make it manageable on our loose outdoor track.
xxfile is offline   Reply With Quote
Old 05-02-2013, 07:51 AM   #3635
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Just a friendly reminder that Avid has the 1.3 2 Hole Piston for those of you who don't want to make your own.
http://avidrc.com/product/5/accessor...cessories.html
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 05-02-2013, 08:03 AM   #3636
Cackswayn's Avatar
Trader Rating: 16 (100%+)
4 in a pack?
Cackswayn is offline   Reply With Quote
Old 05-02-2013, 08:07 AM   #3637
XXXDad's Avatar
Trader Rating: 195 (100%+)
Exclamation I have them... :)
I recommend them, got to use them this weekend in Coco Florida( Space Coast). Large indoor track , high grip with med size jumps.
I noticed it lands planted so you can get right back on the gas.
Was smooth over the bumps and kept my power down to the track.
Thanks for the great products Avid. I also use your pistons in my 22T (1.6 2 hole 12 mm) along with the Triad slipper. Nothing but good things to say about them! And yes 4 to a pack!
So guys pick up some 1.3 - 2 hole 12mm shock pistons for your TLR SCTE and use the latest setups to get yourself to the Front!
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 05-02-2013, 04:09 PM   #3638
CanadianNascar's Avatar
With the Pro 4 4600 what screw size did you use ?
The supplied (smaller) screws give a bad alignment for the motor wires.
I tried the next size up & will not fit through the motor mount holes.
http://www.dorc.ca/
CanadianNascar is offline   Reply With Quote
Old 05-02-2013, 04:29 PM   #3639
Casper's Avatar
Trader Rating: 34 (100%+)
3mm. you can clock the front cap if you need to.
Most of us run it with the tabs pretty much stright up and works fine. You should not have to change anything to do that.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-02-2013, 05:47 PM   #3640
Tabs are either too close to rear shaft, or too far to the passenger side.
Never thought of clocking the cap. Doh ! Thanks..
http://www.dorc.ca/
Old 05-02-2013, 07:13 PM   #3641
roberto_1029's Avatar
Send a message via Yahoo to roberto_1029
Is there anywhere to buy the screw for the shock caps separate? I've googled it with no luck.
Losi 8ight-E 2.0--Traxxas slash 4x4 Ultimate (Scalpel Build) --TLR SCTE 2.0
TLR 22SCT--TLR 22T --Axial Wraith
roberto_1029 is offline   Reply With Quote
Old 05-02-2013, 08:23 PM   #3642
cttech455's Avatar
I picked a 4 pack of these up 2 weeks ago. Great quality.
cttech455 is offline   Reply With Quote
Old 05-03-2013, 01:37 AM   #3643
shaner222's Avatar
2.0 awesome love my truck
placed third in amain with a completely untighten steering
matter of fact almost couldnt turn at all really slow to get wheels turned
the way it sat beat the tekno by 4 laps
losi 8ight-E- 3.0 rx8 /t8 1900
tlr ten scte 2.o rx8 4 pole 4600
tlr 22 2.0 tekin rs pro/gen2 6.5t
shaner222 is offline   Reply With Quote
Old 05-03-2013, 08:15 AM   #3644
rcgod's Avatar
Trader Rating: 27 (100%+)
http://www.google.com/url?q=http://w...FI8nB-8kYAPrSQ
Maybe one of the TLR guys can confirm these are the right size.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 05-03-2013, 08:28 AM   #3645
maddog9's Avatar
Trader Rating: 29 (100%+)
I am not a TLR guy but those are the correct screws.
maddog9 is offline   Reply With Quote
