Like Tree4Likes
Old 04-26-2013, 06:04 PM   #3571
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
[QUOTE=hacker07
Maybe someone mixed up some screws. There is a 3mm screw that comes with the car but it is used to hold the servo horn in place on most metal gear servos. Thats all its for. The screw going through the servo horn and ball and held in place with a nut is a 4-40 screw.[/QUOTE]
Thanks hacker07 for clearing this up...
I ran with hacker07 set up today on a VERY DRY outdoor track and it was money... Thanks to you and Casper for all the support...
What other bodies fit this truck correct?
Thanks,Tommy
rifraf is offline   Reply With Quote
Old 04-26-2013, 08:19 PM   #3572
CanadianNascar's Avatar
I noticed that if you make the batt compartment as long as possible the batt strap does not fit.
The second pic the red arrow indicates the strap is sitting on top of the post.
Oh yea, check batt dimensions before you order.
This batt will not fit http://www.hobbyking.com/hobbycity/s...dProduct=17252
But lucky for me I have McGyver skills !
http://www.dorc.ca/
CanadianNascar is offline   Reply With Quote
Old 04-26-2013, 08:51 PM   #3573
The multiple positions are simply that, forward, middle, and rearward battery positions. For this, the strap is one length. This is not meant to make longer and shorter packs fit. ROAR uses a given battery dimension and that is what we use to make the dimension for the battery compartment here.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 04-26-2013, 08:59 PM   #3574
Doh ! I gotcha, makes sense..
Any suggestions ? Is there a longer strap available ?
Funny, I just sized up an old tooth brush that is long enough..lol
Thanks Hacker..
http://www.dorc.ca/
Old 04-26-2013, 09:03 PM   #3575
Casper's Avatar
Trader Rating: 33 (100%+)
Thanks,Tommy
Most any SC body should fit. The truck is a little longer then typical but I have seen all sorts of bodies from other companies run on this truck.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-26-2013, 09:04 PM   #3576
Thanks,
Old 04-26-2013, 09:42 PM   #3577
rcgod's Avatar
Trader Rating: 27 (100%+)
Thanks Hacker..
Use a Velcro strap. Just sandwich it between the battery mounts and the chassis. That's how I have my battery mounted.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-26-2013, 09:49 PM   #3578
Oh, remove the posts, & run the strap length ways, under the batt mounts ?
Thanks for the tip eh...
http://www.dorc.ca/
Old 04-27-2013, 01:08 AM   #3579
rcgod's Avatar
Yes. Like this.
Dialed RC Hobbies
Old 04-27-2013, 02:22 AM   #3580
Josey Wales's Avatar
Default shock towers
Does anyone know if the 2.0 shock towers wil work with the 1.0
Josey Wales is offline   Reply With Quote
Old 04-27-2013, 02:46 AM   #3581
Suspended
Trader Rating: 7 (82%+)
Are these a 16 big bore shocks like the tekno
RavensNightFury is offline   Reply With Quote
Old 04-27-2013, 02:54 AM   #3582
LVBaja's Avatar
Yes, but in order to take advantage of the new shock mounting positions the 2.0 towers offer, you will also need to purchase the plastic spacers that mount along with the body mounts. Basically, the spacers just move the body mounts about a quarter inch away from the tower to make room for the shock standoffs and nuts that secure them. Another thing to consider is that your body mount holes will change as well with this new spacing.
Scott Rapoport; (916) 597-8502; scottrapoport73@gmail.com
TLR 8ight 4.0; TLR 8ight-T 4.0; TLR TEN-SCTE 2.0
amain.com; AKA; ProTek; OS Engines; Upgrade RC
LVBaja is offline   Reply With Quote
Old 04-27-2013, 03:14 AM   #3583
egobrkr's Avatar
Trader Rating: 26 (100%+)
Ran the truck for second time last night. The first night was with hackers setup ant the rear would get every loose on me. This is indoor track well preped. I went to 775 diff oil and moved the battery all the way back and moved the front camber link up and in on the shock tower. Dropped .8 of my fastest lap time before the changes. This diff oil combo works very well and keeps the rear under the truck. If you are having this issue try it out. I would love to hear if others find it as good as I do.
Here is a video of the track last night
https://www.youtube.com/watch?v=Ub5r...e_gdata_player
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-27-2013, 08:02 AM   #3584
suzuki_73's Avatar
Honestly, my best advice in this situation is to get rid of those soft case lipo's! They just don't fit snug like hard case and can move around. In my opinion they are junk.
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-27-2013, 09:58 AM   #3585
XRated SCT's Avatar
Part number for rear gearbox bearing insert for some reason one of mine fits snug and the other just wobbles around, I know there's a aluminum one tlr3100 but I'd rather just pick up the plastics for now
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
