Like Tree4Likes
Old 04-25-2013, 06:30 PM   #3556
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
has anyone noticed that using a TLR aluminum servo arm when you use the supplied nut and bolt through the the horn and servo link captured end that it has some slop? looks like the supplied screw is smaller in diameter than the hole in the captured in...Hope I didn't confuse anyone.lol.
Thanks for your help.
rifraf is offline   Reply With Quote
Old 04-25-2013, 06:38 PM   #3557
TCCustoms's Avatar
hop on ebay and buy an extra screw kit removed from a vehicle...i do that with any RC i own so if i lose anything i always have spares
http://www.ebay.com/itm/Losi-TEN-SCT...item5d3b84461f
http://www.ebay.com/itm/Losi-Ten-SCT...item4d0bedc13b
http://www.ebay.com/itm/losi-scte-screws-hardware-/151033281559?pt=US_Radio_Control_Control_Line&hash =item232a48fc17
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-25-2013, 06:52 PM   #3558
Nosir,I have all the kit screws.Looks like the supplied 3mm screw is too small for the hole in the captured in on the steering link,like the hole in the rod end may be 5mm..this area has the steering slop i am referring to..
Old 04-25-2013, 09:14 PM   #3559
ta_man's Avatar
Trader Rating: 151 (100%+)
First off, there are no 3MM or 5MM screws on the SCTE - it uses American standard hardware (except in the diffs).
That said, it is possible you used a ball in the steering link meant for a 5-40 screw instead of the ones that are supposed to go in the steering link which (the balls) are meant for 4-40 screws.
The balls are the same outside diameter, so it is possible to fit the wrong ball in the steering link. But then you will find that when you use the 4-40 sized ball in the place where the 5-40 sided ball was supposed to go (because you got them mixed up), that the 5-40 screw won't fit through the ball.
This is all assuming you are talking about the link that connects the servo arm to the servo saver.
ta_man is offline   Reply With Quote
Old 04-25-2013, 09:28 PM   #3560
Thanks.. I did not build this truck.I will look for the for the smaller I.D.ball..
Old 04-26-2013, 03:44 AM   #3561
maddog9's Avatar
Trader Rating: 29 (100%+)
I was experiencing rear looseness before. I started from box stock and put 5000 in the rear diff, put 3.5 toe in the rear and red springs on the rear. Dropped a whole half second thanks to tuning advice from hacker and casper!
maddog9 is offline   Reply With Quote
Old 04-26-2013, 05:25 AM   #3562
Grandturk's Avatar
The diff screws are 1/16". If you use a 1.5mm you will strip out the screws... Which I suspect many with this problem are doing.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-26-2013, 05:51 AM   #3563
Purdue Engineer's Avatar
The diff screws are 2.6m x 10m and use a 1/16 driver. Yeah, I don't understand those.
Purdue Engineer is offline   Reply With Quote
Old 04-26-2013, 07:53 AM   #3564
Originally Posted by drepus View Post
The post is 3mm so you could use a 3mm locknut and a large washer on the front for now and just undo the rear one to change the battery.
The battery mounts use a 5-40 thread, not a 3mm thread just to be clear so for the meantime, you can use a nut and washer but its a 5-40 one. I only ever remove one thumb screw myself which is the rear ward one. I always leave the front one on.
Maybe someone mixed up some screws. There is a 3mm screw that comes with the car but it is used to hold the servo horn in place on most metal gear servos. Thats all its for. The screw going through the servo horn and ball and held in place with a nut is a 4-40 screw.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 04-26-2013, 08:44 AM   #3565
Grandturk's Avatar
Does anyone have a scan of the body post hole template that's included with the high performance body?
Old 04-26-2013, 10:23 AM   #3566
i can scan it when i get home........i didnt use it....but did make the mistake of not putting the tirese on before i made the holes..
the body needs to go pretty far forward to prevent tire rub when steering
bbond919 is offline   Reply With Quote
Old 04-26-2013, 11:25 AM   #3567
Thats odd, you would usually go thinner in the rear to get it to lock in.
SuperDaveNT is offline   Reply With Quote
Old 04-26-2013, 11:43 AM   #3568
maddog9's Avatar
Thats what I initially thought too, but i gave it a try and it made a huge difference. I think the issue i had was spinning the rear tires on the initial punch out of the turns. But it calmed it down and allowed me to drive it nice and hard.
Old 04-26-2013, 04:07 PM   #3569
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Stormer has pro 4 hd in stock ?:@)
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-26-2013, 04:18 PM   #3570
XRated SCT's Avatar
There's a bunch on ebay as well but I don't need one YET lol
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
