Like Tree4Likes
Old 04-25-2013, 12:28 AM   #3541
XRated SCT's Avatar
@hacker, I mentioned before my rear ring gear tore 2 teeth off and I had ordered one but the way it mounted was backwards so I think I ordered the wrong one, should I just contact HH and get a replacement which I should of in the first place?
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 04-25-2013, 08:32 AM   #3542
Purdue Engineer's Avatar
Hay guys,
Where can I buy the new carbon shock towers? I noticed the rear tower, it's not broke but the top layer of carbon is splintered, just about an 1/8 of an inch on the edge in the center right next to where it bolts to the case. I'm thinking of just putting some CA glue on it and running it. It's not bent, I don't think carbon bends. So, where can I get these if I have to end up replacing it?
I also broke a part on the steering bell crank. Should I just pay $6 for another plastic set or pay $35 for a complete alum. set? I have noticed that over the last week there has been a lot of slop in the steering. Is this normal? It looks like it is in the plastic rod ends. Do these need to be replaced often?
Ok, last question.
I have already replaced two CVD pins in the center drive line ( front and rear). I have been told that I should upgrade to the, dare I say it, Hekno CVDs because they are stronger and last longer. Has anyone replaced there center CVDs and front and rear dog bones?
Going to rebuild my truck and also order some avid revolution bearings to get ready for the out door season.
Thanks guys.
Purdue Engineer is offline   Reply With Quote
Old 04-25-2013, 10:24 AM   #3543
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Every losi I've owned has had a good amount of slop in the front end and steering. It is normal as far as I know and in my opinion has a positive effect on the cars handling characteristics.
ironzgti35 is offline   Reply With Quote
Old 04-25-2013, 10:59 AM   #3544
XRated SCT's Avatar
Originally Posted by Purdue Engineer View Post
Hay guys,
google works wonders
https://www.google.com/search?q=go&a...w=1366&bih=667
Old 04-25-2013, 12:00 PM   #3545
Battery Thumb Screws (2): SCTE 2.0 mine just came end and only had one thumb screw in it package and picture says two.
xxxtruck is offline   Reply With Quote
Old 04-25-2013, 12:04 PM   #3546
by: Team Losi Racing
Avg. Customer Rating: 0.0 (0) .
Item: TLR231003
Ships in: Backordered
Price: Reg. $5.99 $5.99
Qty.
Add To Cart Add to Wish List
Old 04-25-2013, 12:05 PM   #3547
well can not get pic to post
Old 04-25-2013, 12:06 PM   #3548
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Always glue edges of c/f before you instÓll them to prevent delamination
You prob need new rod ends n ball links
I have broken a bell crank n replaced with alloy
Get the m2c coupler pin keepers so the dont fly out of the plastic coupler retainer
I hear teckno stuff wears just as fast
Did i cover all Q?
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-25-2013, 12:32 PM   #3549
blade329's Avatar
Trader Rating: 114 (100%+)
Yup. Same thing happened to me. The company I ordered from said a whole shipment came in like that from TLR. It's supposed to have two. They sent me a second package.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 04-25-2013, 01:30 PM   #3550
Yeah, those never passed QC and got put into stock on accident. About 60-70 of them made it out before I caught it and pulled the rest from stock. They were packaged wrong.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 04-25-2013, 02:53 PM   #3551
suzuki_73's Avatar
Originally Posted by rcgod View Post
Casper, I called horizon over two weeks ago to get the shock caps and a sway bar link that was missing from my kit. They said it would ship in a couple days. Still haven't received them. Are they out of stock or what's the issue? Getting tired of having to use pliers to take my shocks apart.
I just spoke with Horizon to get replacement caps and he said they should ship out on monday.
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-25-2013, 03:24 PM   #3552
XXXDad's Avatar
Trader Rating: 195 (100%+)
Cool Sigh..... Same thing here
Looks like Nut and washer time.....
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 04-25-2013, 04:19 PM   #3553
drepus's Avatar
The post is 3mm so you could use a 3mm locknut and a large washer on the front for now and just undo the rear one to change the battery.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 04-25-2013, 06:58 PM   #3554
BmainStar's Avatar
At some point it does affect the truck a bit,but not for a long while. What I tell people who are concerned with this is to: With the steering trim adjusted correctly run your car full throttle down the strait away and let go of the wheel,truck will continue to track forward and strait(if set up correctly) with all that slop.... Cheers...
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-25-2013, 07:05 PM   #3555
TCCustoms's Avatar
We were told that we did not need to have to CA the edges of the TLR towers and pry why most didnt do it
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
