Like Tree4Likes
Old 04-24-2013, 10:09 AM   #3526
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Is Losi sending out replacement parts for the shock bottoms yet or just taking your information for when the corrected ones become avail?
ironzgti35 is offline   Reply With Quote
Old 04-24-2013, 10:11 AM   #3527
xxfile's Avatar
Originally Posted by Blitzrockey View Post
I lost the little nub cover for my antena tube, Im going to put one little wrap of electrical tape around it so crap doesnt get into it. Is this going to affect the reception and distance or no? Thanks.
Dont bother not needed really no issue
The tape will just be a ball of goo with dirt stuck to it after a run or two.
xxfile is offline   Reply With Quote
Old 04-24-2013, 10:18 AM   #3528
Grandturk's Avatar
Yes I already got my replacements 2 weeks ago.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-24-2013, 10:56 AM   #3529
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by maddog9 View Post
At roar events do they check everyones car to see if there legal?
It all depends on the level of the event, and your regional ROAR staff. At National events, sure, they have to. At local events there are discretionary enforcements. The reality is that you want to be as compliant as possible. If you have a question, reach out to your regional ROAR team to get answers.
Otherwise, the best answer is 'it depends'.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 04-24-2013, 11:54 AM   #3530
rcgod's Avatar
Trader Rating: 27 (100%+)
Casper, I called horizon over two weeks ago to get the shock caps and a sway bar link that was missing from my kit. They said it would ship in a couple days. Still haven't received them. Are they out of stock or what's the issue? Getting tired of having to use pliers to take my shocks apart.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-24-2013, 12:12 PM   #3531
Grandturk's Avatar
How many times do you have to take your shocks apart?
Old 04-24-2013, 12:39 PM   #3532
Casper's Avatar
Trader Rating: 33 (100%+)
I would call them again. I know the lower cap came in stock. They are pretty good about that stuff usually though.
I second the question. I can't believe you have enough run time on the shocks to require access to the bottom end. Those o-rings should last a LONG time.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-24-2013, 01:11 PM   #3533
rcgod's Avatar
I take them apart every couple of race days to clean them.
Dialed RC Hobbies
Old 04-24-2013, 01:24 PM   #3534
Grandturk's Avatar
Well, I'm not going to argue against preventative maintenance.
I've only changed my shock oil 3-4 times since the truck came out and even then it was crystal clear. These O Rings work. I spray out the whole thing with motor spray and get all the crud off, but I'll only touch the bottom cap when I change the O Ring - which I only did 1-2 times in 1.5 years running the 1.0.
Anyway - you're mileage may vary. Call up customer service again. Make sure you talk to Cali - they send out a little Baggie with just shock bottoms. It's the insert Baggie for the kits "use this instead of bag E" or whatever.
Old 04-24-2013, 01:43 PM   #3535
I would call and use the call back function and ask them. We have them all in stock. And how often are you having to remove these, I maybe put new O-rings in every 6 months, lol.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 04-24-2013, 01:51 PM   #3536
Casper's Avatar
He is cleaning his shocks every few outings not replacing them.
Old 04-24-2013, 02:13 PM   #3537
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by xxfile View Post
Built two straight from the kit instructions they were spot on
Either there was a running change to the manual or you used different mounting holes for the inboard side of the links than was stated in the manual.
Really no big deal just get out the tool and start cranking until it look right.
ours were within a turn of the turnbuckle from being perfect.
I used the inside bottem tower holes on front, after I redid to the picture length they look more correct for a baseline for me to use now, I just thought it was crazy how they came out following the Millimeter instructions. Now my rear look like maybe only 1 deg or less and front look to be slightly camber out.
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-24-2013, 02:21 PM   #3538
Panda-PR's Avatar
I went to a small event about a month ago and there was a mugen eco converted to sc. He was using a tekin 1900/rx8 and 4s. Sure he was killing everyone! I didn't raced sc that day. If I were racing I would be that guy complaining LOL
So to my point, sometimes rules are there to help...
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 04-24-2013, 05:13 PM   #3539
TCCustoms's Avatar
Someone likes Proline Calibers....I love them tires too!!!
My 2.0 should be here today. Still waiting on my 275 sensor wire and a few other pieces and then I'll start putting it together. Without searching a hundred pages what are the things to watch out for other than the shock bottoms? I build 3 hd diffs and ran them in my 1.0 so they shouldn't be an issue
if your good with the diffs just make sure you put the side guards on right...alot of people havent payed attention to help guide done by Ryan to where the side guards are side specific so the side with the taller inside(closest to the chassis) goes to the battery side to help support the battery and not fall out and the lower side goes on the other side and allows for the motor mount to slide
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-24-2013, 07:39 PM   #3540
ironzgti35's Avatar
Good to know. Picked the kit up tonight and will start the build tomorrow. I have the tip sheet link from page one up for reference where needed
