Like Tree4Likes
Old 04-23-2013, 07:50 PM   #3511
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
Originally Posted by MOE View Post
As many kits you have built you should know! lol
Richard built this one..he gots me confused...
rifraf is offline   Reply With Quote
Old 04-23-2013, 11:15 PM   #3512
XRated SCT's Avatar
Originally Posted by Mxer59 View Post
I ran my truck first time fri and had a hard time with it but my toe angles where off and also new remote that I'm not used to. I decided today to set up toe angles like manual shows on build and matched them with my digital caliber. If the booklet show exact width in the diagram when it shows where to measure from, example: 98.5 my digital caliber is further out then in the books picture (like I said not sure if to scale in manual) my truck came out like this not sure if they should be around this angle.
That's weird how some of yours came out like that, mine came out pretty normal
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 04-24-2013, 12:02 AM   #3513
silvalis's Avatar
Trader Rating: 29 (100%+)
After a while you will come to the same conclusion I did. Screw the turnbuckles in, put the whole thing together then throw it onto a setup station.
The only real concession I make these days are getting the steering links exactly the same length...
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-24-2013, 03:44 AM   #3514
Trader Rating: 25 (100%+)
Default Camber gauge
http://www.amainhobbies.com/product_...i-Camber-Gauge
RustyRC is offline   Reply With Quote
Old 04-24-2013, 04:24 AM   #3515
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
that explains everything
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 04-24-2013, 04:56 AM   #3516
Mxer59's Avatar
Trader Rating: 114 (100%+)
I took my caliber and set it to the same length as the drawling instead of the numbers they gave and it looks a lot better
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-24-2013, 05:11 AM   #3517
8ight-e's Avatar
Trader Rating: 57 (100%+)
If you don't have a camber guage, the least you could do is setup something with a right angle to verify pretty close to equal negative camber Just saying..
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-24-2013, 06:07 AM   #3518
suzuki_73's Avatar
Mine looked exactly like that also before I went to the tuning station.
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-24-2013, 07:49 AM   #3519
xxfile's Avatar
Built two straight from the kit instructions they were spot on
Either there was a running change to the manual or you used different mounting holes for the inboard side of the links than was stated in the manual.
Really no big deal just get out the tool and start cranking until it look right.
ours were within a turn of the turnbuckle from being perfect.
xxfile is offline   Reply With Quote
Old 04-24-2013, 07:59 AM   #3520
xxfile's Avatar
On page one it shows to use outer camber link holes, in the manual it shows to use inner holes. That'll do it if you used the Dunford setup from the first page.
Old 04-24-2013, 08:15 AM   #3521
ironzgti35's Avatar
Trader Rating: 20 (100%+)
My 2.0 should be here today. Still waiting on my 275 sensor wire and a few other pieces and then I'll start putting it together. Without searching a hundred pages what are the things to watch out for other than the shock bottoms? I build 3 hd diffs and ran them in my 1.0 so they shouldn't be an issue
ironzgti35 is offline   Reply With Quote
Old 04-24-2013, 08:21 AM   #3522
Casper's Avatar
Trader Rating: 33 (100%+)
The steering links you want to make sure they are the same length to start and then you can make equal adjustments left and right to set the toe in. The camber linke I just make sure I thread them on the same amount left and right and adjust on the truck. IMO it is a waste of time to measure the camber links as you fine tune those on the car always.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-24-2013, 09:19 AM   #3523
xxfile's Avatar
Built two with no real issues.
There is a build tips download on the first page that helps a lot.
The diffs arent a problem if you are experienced.
we counted the parts as we built and i think it was about 725 pieces total counting nuts bolts set screws body and everything.
I spread it out over a few weeks as i was teaching a total noob but I'm sure it could be done in an evening but a LONG evening mind you.
Pre order the shock caps. You CAN use the kit ones but you need to crank on them with pliers to get them on..
Old 04-24-2013, 09:23 AM   #3524
Casper's Avatar
If you really know what you are doing (I built three trucks in about 2 weeks, not all min I only have one! ) but I got it down to about 4-5 hours without electronics. 4wd cars there are a lot of parts.
Old 04-24-2013, 10:06 AM   #3525
Blitzrockey's Avatar
I lost the little nub cover for my antena tube, Im going to put one little wrap of electrical tape around it so crap doesnt get into it. Is this going to affect the reception and distance or no? Thanks.
Blitzrockey is offline   Reply With Quote
