Like Tree4Likes
Old 04-21-2013, 07:30 PM   #3466
CanadianNascar's Avatar
Originally Posted by rifraf View Post
Thanks. On the rod the marks should be all facing the left,if your sittin in the drivers seat of a normal full size car?
It does not matter which side they are on, as long as they all are on the same side.
This makes it easier when adjusting them independently, because if you turn one upwards, you get the same direction of travel on all of them...
That sounds confusing in print, hope it helps.
http://www.dorc.ca/
CanadianNascar is offline   Reply With Quote
Old 04-21-2013, 07:35 PM   #3467
TCCustoms's Avatar
haha, i still think you said it better....lol
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-22-2013, 03:36 AM   #3468
maddog9's Avatar
Trader Rating: 29 (100%+)
I am having extreme looseness in the rear of my truck, which means i need more rear traction. I was running the same setup as the dunford standard setup minus having stock pistons and 27.5 oils all around. What are some changes I can make?
I tried a longer rear camberlink by moving it inner lower on the rear, move the hubs forward so that one spacer was front and 3 behind. moved the battery back. moved the shocks in one on the tower in the rear. Nothing worked loose loose loose mainly on mid to exit of the turns. And i have a buddy who has had the same issues and couldnt figure it out either. Would it be smart to add some weight to the rear? So far on it outdoor track the car wont be driveable. On indoor tacky clay track the car is awesome. And i had the right tires on as the number 1 and 2 drivers were using the same thing.
maddog9 is offline   Reply With Quote
Old 04-22-2013, 03:50 AM   #3469
egobrkr's Avatar
Trader Rating: 26 (100%+)
I had the same issue. The things I did were went to 7 7 5 diff oil, moved the front camber link in and up on the shock tower and took some droop out. I will not run till tuesday to see if it works but thats what I did.
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-22-2013, 04:16 AM   #3470
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
try adding more rear toe in.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 04-22-2013, 05:16 AM   #3471
maddog9's Avatar
I will give that a try.....i need something that will be stable on loose, blown out conditions, if someone has any outdoor track time, please let me know your setup.
Old 04-22-2013, 05:45 AM   #3472
Grandturk's Avatar
Just ran the Casper setup outside yesterday. Works great.
Let me ask you this - when you get on the throttle, does the car squat a lot? Do the front tires balloon more than the rears going down the straight? If you're running 27.5 front and rear, you may actually be having too much weight transfer. What this is doing is pulling all the weight off the front tires. This will end up making the car very twitchy under acceleration. Try leaving your setup as is and going to a heavier oil in the front. Try 30 front 27.5 rear
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-22-2013, 05:59 AM   #3473
maddog9's Avatar
Yes i have have 27.5 front and rear with the 3 pistons front and 4 pistons rear. And i think it is squating in the rear alot during acceleration almost to the point where if i didnt get on it right going down the straight it would want to spin out mid straight. i will try 30 in the front. Would you suggest 2 on antisquat as well?
Old 04-22-2013, 06:15 AM   #3474
Grandturk's Avatar
I run anti-squat 3 as per Casper/Dunford setup. 2 was stock on the 1.0. You want weight to stay on the front end as these are drive wheels and keep the truck tracking straight. I struggled with just this same problem all last summer.
I would set the anti-squat at 3 and go to a 32.5/30 or 30/27.5 setup depending on the track.
Old 04-22-2013, 06:18 AM   #3475
8ight-e's Avatar
Trader Rating: 57 (100%+)
Are you sure you have the right tires on? First thing I would do is make sure you have the right tires, look at the fastest drivers and see what they have, make sure they have a similar driving style. If that doesn't help you can change rear camber positions on the tower (move it down if you need side bite, move it up if you need straight line traction) not 100% sure from your description. Start there then make more or bigger changes. typically traction is tires first.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-22-2013, 06:31 AM   #3476
maddog9's Avatar
100% positive down to the foam and compound, first and 2nd place had the same tires. keep in mind i was the 3rd fastest truck lol!
Old 04-22-2013, 06:56 AM   #3477
maddog9's Avatar
would the 2 hole 1.3mm pistons make a bit of difference too?
Old 04-22-2013, 07:05 AM   #3478
Pygmy's Avatar
After driving yesterday I noticed the positive female connector in my battery comes out (2mmor so). Is this a sign of lipo puffing or just a bad connector ?
"If it ain't broken, take it apart and see how it works."
LOSI Ten SCTE [ Build : http://bit.ly/VsAulx ]
Pygmy is offline   Reply With Quote
Old 04-22-2013, 08:16 AM   #3479
Some thing to try are moving the rear hubs all the way back, go to more rear toe in, small changes at a time, so use the .5 out in the rear outer hinge pin brace, thicker rear diff oil.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 04-22-2013, 08:19 AM   #3480
Grandturk's Avatar
It shouldn't really as they have a bigger effect on high speed damping.
Nah, the tubes often pull out a little from the case. It's ok
