Like Tree4Likes
Old 04-21-2013, 01:25 AM   #3451
egobrkr's Avatar
Trader Rating: 26 (100%+)
I had the same problem at my track on the triple. I moved the battery all the way back and it was perfect!
Mugen MBX7R Triton L5 Picco 2120 pipe M2C clutch
Mugen MBX7T Triton L5 Triton 2120 pipe M2C clutch
Mugen MBX7R Eco Tekin RX8 Gen2 Tekin 2050kv
youtube.com/user/egobrkr
Thanks to my sponsors Mugen Seiki and Radiopost
egobrkr is offline   Reply With Quote
Old 04-21-2013, 06:01 AM   #3452
dougo96's Avatar
Originally Posted by XRated SCT View Post
So I got my hw motor in and after placing the esc down my leads are BARELY touching the solder post, is there a way to stretch em or get em to stay in tack w/out having to get new extended leads
Flip the tabs on the motor, so instead of them facing back put them to where there facing forward. They're held in by solder so just heat em up and they'll slide right out.
Team CRC-TS Paint-Bauer's Speed Shop-HobbyWing North America
dougo96 is offline   Reply With Quote
Old 04-21-2013, 06:51 AM   #3453
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Question on setup
I'm really happy with the car but I let on of the fast kids at the track run it and all he said to improve was a little more steering...
How can I achieve this?
1) more toe out?
2) a faster servo? Currently running hitec 7945 (403oz and .12 @ 7.4 but the mmp only goes up to 7.0v)
3) tighten my servo saver screw more? Pic shows how tight it currently is and I can't really tighten it more by hand at least...
agarabaghi is offline   Reply With Quote
Old 04-21-2013, 07:02 AM   #3454
egobrkr's Avatar
Are you using dunford's setup he posted? I use his setup and I have steering to spare. One thing also to check would be endpoints. I noticed on my 2.0 I could get more travel then my 1.0 before binding.
Old 04-21-2013, 07:30 AM   #3455
I have the travel set to 80... I went up a bit to 85% but it kinda started to hit the case
Old 04-21-2013, 08:00 AM   #3456
Panda-PR's Avatar
Servo is ok. You can always take some pliers and adjust the nut a little more, better if you use threadlock.
From THE guide:
More Overall Steering:
Lower shock mounting in on arm.
Thinner oil in front shocks.
Softer front springs
Stiffer rear springs
Short rear upper link
Longer front upper link
Thinner or no front swaybar
Less rear toe in
Short Ackermann plate
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 04-21-2013, 02:11 PM   #3457
went to local track today and finally broke into the 13.xx 's
Saw some new stuff on horizon:
TLR331003 TLR SCTE 2.0 Chassis Protective Tape Precut (2)
Will does this part go over the center diff?
XTR10858 Carbon Fiber Transponder Mount, Black: SCTE
Old 04-21-2013, 02:55 PM   #3458
Casper's Avatar
Trader Rating: 33 (100%+)
Chassis tape is for the 2.0. It covers then entire bottom of the chassis from the very front of the front bumper all the way to the rear. Covers up all the screws is one draw back but you can cut out screw if you need to access the chassis screws.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-21-2013, 03:44 PM   #3459
I meant the xtreme racing transponder mount but reading the description it looks like it mounts to the 1.0 rx box. I think ill stick with the kingz heads
Old 04-21-2013, 04:10 PM   #3460
What guide are u talking about that seems like a handing thing to have thanks
Briancruzz is offline   Reply With Quote
Old 04-21-2013, 04:15 PM   #3461
tc5 man's Avatar
JQ.com its on the top of the page on the website its called the Guide. Best explaining of what tuning diffrent things do and what driver style it fits to !
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 04-21-2013, 04:46 PM   #3462
nice!
Old 04-21-2013, 06:09 PM   #3463
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
Hello Everyone..I got rid of my Heckno.lol..I purchased a used losi 2.0 roller that has only 2- 5 min of runtime.I would like to know how long of sensor wire I need for a Tekin 550 motor?I am gonna mount my RX8 with the soulder post inside next to the front driveshaft..
Also,Do the tie rod ends cut mark go to the outside of the truck?
Thanks,
rifraf is offline   Reply With Quote
Old 04-21-2013, 06:51 PM   #3464
TCCustoms's Avatar
Thanks,
275 is about the right length just to give alittle slack in the wire
and i beleive the marks are suppose to be facing the same side...so if your looking at the front of the truck...all the marks should be on either the right or left. I beleive if looking from the front of the truck and the rear is in the distance mine are on the right but if like a normal truck mine are facing the driver side, lol
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-21-2013, 07:24 PM   #3465
Thanks. On the rod the marks should be all facing the left,if your sittin in the drivers seat of a normal full size car?
