Like Tree4Likes
Old 04-18-2013, 04:00 AM   #3376
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Also...
Originally Posted by jmc5313 View Post
Ok....im probaly 10 packs through my truck....ive ran half on indoor clay...half on outdoor dusty/loose....every time its been ran on the dusty surface it has been blown of with compressed air.....i ve tried to get every nook and cranny....however....the front steering now creaks like an old lady....both directions slow or fast....is it the captured ends?? I've never heard an rc truck make this noise this quick....
Check your servo saver is not too loose.... and the blue adjuster is not touching the chassis
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 04-18-2013, 05:26 AM   #3377
maddog9's Avatar
Trader Rating: 29 (100%+)
Ran my truck last night, the truck was pretty dialed ran times roughly a full second faster than a local tekno sponsored driver. My truck is back to stock 553, 27.5 all around, #3 and #4 pistons, front camber locations is in the inner lower location, and rear camber link is b is lower outer position. I have a slight over steer on exit of the turn, its really noticeable on 180 turn. What could i adjust to get it a bit more tight on exit. Camberlink adjustment?
maddog9 is offline   Reply With Quote
Old 04-18-2013, 06:42 AM   #3378
kingofcool999's Avatar
Angry
Doing more shake-down runs w/my 2.0, and burned up a new Novak Havoc Pro SC w/x-drive. Using a Novak 4.5t 550, 14/40 pinion/spur.
Anyone else out there ran this setup? Had any problems? Is this a marginal application (even tho the ESC is rated for that motor)? Is it just my bad luck?
kingofcool999 is offline   Reply With Quote
Old 04-18-2013, 06:56 AM   #3379
Grandturk's Avatar
I ran that setup no problem in my 1.0 - in fact I also ran a 15T and boost.
That said, every ESC and motor out there has failure issues. Contact Novak customer service, they will help you out.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-18-2013, 07:04 AM   #3380
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
I used to love Novak electronics till I bought the Havoc Pro system and the ESC smoked on me 3 different times ! Once on the bench right after I plugged it in ! The other 2 lasted a few weeks and then started to shut off on their own and act erratically .
When they work the Novak ESC's are great but how long will they work is the question . Good thing is their CS is decent so they will probably replace it , but good CS is of little comfort IMO if you are missing races witing for a repair .
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 04-18-2013, 07:23 AM   #3381
RiceP's Avatar
Trader Rating: 70 (100%+)
I had same problem with the havoc sc pro x-drive smoked 2 before I got the rx8 no issues since
RiceP is offline   Reply With Quote
Old 04-18-2013, 07:31 AM   #3382
Thanks for the info. I'm going to have to pay the $75 for a replacement from Novak (ESC was new, but ran out of warranty sitting on my bench). If it keeps burning up, I'll upgrade. I run the same ESC in my SC10 (2wd) with no problems, but that is a much less rigorous application.
Old 04-18-2013, 07:46 AM   #3383
LVBaja's Avatar
Moving the hubs forward would allow more weight transfer to the rear wheels when under power, thereby increasing on-power rear traction. It's an easy adjustment that can be reversed if it doesn't do what you want. Alternatively, a lower camber link position on the rear tower should increase rear traction too. Maybe a combination of both, but I'd try them one at a time first.
Scott Rapoport; (916) 597-8502; [email protected]
TLR 8ight 4.0; TLR 8ight-T 4.0; TLR TEN-SCTE 2.0
amain.com; AKA; ProTek; OS Engines; Upgrade RC
LVBaja is offline   Reply With Quote
Old 04-18-2013, 07:47 AM   #3384
Grandturk's Avatar
Wink
I would say call them up first - you may be surprised.
That said, if you do have to upgrade, you may want to consider the Pulse or the Activ8. I run the Activ8 in my SCTE now. With both you get more tuning options and a more robust BEC. You can also ask the. About the super tuner upgrade for the Havok Pro - which i have as well - that gives you everything the Pulse has except Extra Timing - which you probably don't need.
What i like about the Activ8 over the smaller ESCs is - you don't need to run a fan, and if you choose to run the fan, it's more robust than the small units on the Havok and Pulse. I had many times lost the fan from my Havok in the SCTE - which then overheats and shuts down. I'm sure you can also secure the fan on with wire or bigger screws as well
Old 04-18-2013, 07:57 AM   #3385
rcgod's Avatar
Trader Rating: 27 (100%+)
You can get a brushless hobbies 120a for less than $75 or SCT pro for $15 more. Why not go that route then you have an ESC that can handle any motor you want to use?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-18-2013, 08:03 AM   #3386
Can you post a pic of that ESC installed? I had enough trouble getting the Havok to fit...
Old 04-18-2013, 08:03 AM   #3387
If I'm not mistaken, I thought that 120A ESC was limited to a 6 turn.
Old 04-18-2013, 08:04 AM   #3388
maddog9's Avatar
I am already at the lowest rear camber link location, Anthony Mazzara helped me and told to me to run a longer rear camberlink. Also, might try his 32.5 and 30 shock oils with the stock pistons.
Old 04-18-2013, 08:14 AM   #3389
Grandturk's Avatar
It fits.
Old 04-18-2013, 08:28 AM   #3390
rcgod's Avatar
Nope. Same specs as the scte pro and hobbywing 120a. I've used both with a tenshock 5200 and they work great. Guys even use them in 1/8 buggies on 4s. Even the castle mamba monster is only ratedat 120a.
Dialed RC Hobbies
