Like Tree4Likes
Old 04-17-2013, 07:46 AM   #3361
xxfile's Avatar
Originally Posted by eddomak View Post
Heh heh, pre-emptive Dremelling - I like it! That way you can use the hex, but if it all fails you still have the slot without scoring the casing itself. Nice one!
I think cutting a slot thru the hex is just asking for it to fail.
I used a power screwdriver with a screw to pre thread the holes, go straight in in one constant drive. using a hand held driver is a lot of starting and stopping and angle changes which doesnt help.
did six diff cups with only one screw and didnt have a problem.
The only issue with getting a tap is its really small and if you break it off it might be a problem to get out... Murphys law states that it WILL break off inside where u cant get at it. again if you do I would chuck it in a drill, NOT the hand tap handle.
xxfile is offline   Reply With Quote
Old 04-17-2013, 07:48 AM   #3362
xxfile's Avatar
Originally Posted by ta_man View Post
I tapped mine part way and used a regular M2.5 socket head (not flat head) screw to pre-thread the diff cases the rest of the way. I was concerned that if I tapped to full depth, there would not be enough friction on the screws to keep them from backing out.
NOT an issue, after tapping the screws are still very tight going in...
Old 04-17-2013, 09:21 AM   #3363
did any1 try MIP's 41 tooth spur gear?
SCTE - Pro4 @ RX8 on KH chasi
krits is offline   Reply With Quote
Old 04-17-2013, 11:53 AM   #3364
maddog9's Avatar
Trader Rating: 29 (100%+)
nope, im assuming it would increase your acceleration, but decrease your top speed. Assuming you keep the pinion the same.
maddog9 is offline   Reply With Quote
Old 04-17-2013, 12:37 PM   #3365
what i meant is - will it fot to the chasi? i recall a fotting problem with kingheadz chasi
Old 04-17-2013, 03:24 PM   #3366
ta_man's Avatar
Trader Rating: 151 (100%+)
If I was tapping metal holes that deep I might be worried about a broken tap, but in plastic I've done holes much deeper than these diff cases without problems.
I burned myself on a screw backing it out with a power driver from the friction generated heat. Even screwing it in manually, I could feel heat build up.
I'll do it for the next ones I replace.
ta_man is offline   Reply With Quote
Old 04-17-2013, 03:59 PM   #3367
Casper's Avatar
Trader Rating: 33 (100%+)
You can sacrifice a screw and cut a slot down the side to turn it into a "tapping" screw as well.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-17-2013, 05:16 PM   #3368
TCCustoms's Avatar
Here is a way to tell the difference from the shock bottoms in the kit to the replacement ones...
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-17-2013, 05:20 PM   #3369
Mxer59's Avatar
Trader Rating: 114 (100%+)
How are you guys running your wire from Esc to Reciever Im not really comfortable with couple ways I've ran mine worried of catching driveline
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-17-2013, 05:30 PM   #3370
TCCustoms's Avatar
Just ran it over from the esc and under the servo like Hacker/Ryan said and then back out
Old 04-17-2013, 05:54 PM   #3371
jmc5313's Avatar
Default She sounds OLD!!!
Ok....im probaly 10 packs through my truck....ive ran half on indoor clay...half on outdoor dusty/loose....every time its been ran on the dusty surface it has been blown of with compressed air.....i ve tried to get every nook and cranny....however....the front steering now creaks like an old lady....both directions slow or fast....is it the captured ends?? I've never heard an rc truck make this noise this quick....
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 04-17-2013, 07:43 PM   #3372
Grandturk's Avatar
Shoot some bearing oil or WD40 in the pivot joints and balls. Otherwise, yes it creaks.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-17-2013, 09:14 PM   #3373
xxfile's Avatar
Just shortening wires to finish the castle 3800 race pro
I have heard that some motors wires can't be cut does anyone know if this
Is true for this castle motor?
Old 04-17-2013, 09:18 PM   #3374
Feint Motion's Avatar
Trader Rating: 24 (96%+)
You can cut the wires.
Feint Motion is offline   Reply With Quote
Old 04-17-2013, 09:26 PM   #3375
Trader Rating: 110 (100%+)
But know that they must all be the same length. Very close to the same length.
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
