Like Tree4Likes
Old 04-16-2013, 11:42 PM   #3346
Trader Rating: 41 (100%+)
Send a message via AIM to rifraf Send a message via Skype™ to rifraf
yessir.mans best friend with R/C cars..
I will have the 2.0 as soon as I can give away this 410!!lol.
rifraf is offline   Reply With Quote
Old 04-16-2013, 11:51 PM   #3347
XRated SCT's Avatar
Yup it's a badass truck, if I had the money I think I'd buy it again just to unbox it and build it fresh haha
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 04-16-2013, 11:55 PM   #3348
I have a MIP/LOSI conversion that puts the other to pure shame!!
really the only thing I am using is the MIP chassi.
Old 04-16-2013, 11:57 PM   #3349
BmainStar's Avatar
Originally Posted by Blitzrockey View Post
I also just serviced all my diffs, the front and rear were empty they looked liked they both leaked into the diff case from the paper gasket? The middle one was the only one with any fluid in it, this was after 3 battery packs. Very strange to say the least.
With the new diff cups you can really tighten down the four small screws (now)!!USING HPI SCREWS THO.LOL.Sometimes with the 2nd rebuild the screws will go in a little more ..Had one of the new ones leak out and just snuged it up a good amount more than last time and its holding. .Good luck!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-17-2013, 12:30 AM   #3350
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Thats what I'm thinking too. I'll see how it goes now.
Blitzrockey is offline   Reply With Quote
Old 04-17-2013, 12:31 AM   #3351
Old 04-17-2013, 01:40 AM   #3352
I had a leaky rear diff. The problem was the screw holes in the diff were too tight. It seemed like I had the screws tight enough on the first build to the point I was afraid they would strip if I tightened them anymore. After the rebuild I was able to screw them in more. I also sanded the face of the diff where the gasket seals on a flat surface and now my diff doesn't leak.
Jedev is offline   Reply With Quote
Old 04-17-2013, 05:21 AM   #3353
Make sure when you build the diffs you sand the face of the diff case flat. It doesn't take much . Just a light sanding. Then use some red or black grease on the gasket. Light coating .i use mobile synthetic grease red stuff.
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 04-17-2013, 05:31 AM   #3354
luko's Avatar
Im about to build my diffs,I hear what you guys are saying,I think I might pre thread the diff housings without the cover or the gear on to be sure the screws won't bottom out or become to tight in the thread.
Hey can anyone tell me if the diff shims in the 2.0 kit are the same as the 1.0 , super soft.I have some of the hardened spring steal ones on the way to rebuild my 1.0 diffs with the hd housings,
NRRCMC President.
LOSI/SERPENT/TEKIN/FUTABA.
luko is offline   Reply With Quote
Old 04-17-2013, 05:48 AM   #3355
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
I always pre thread the diff screws, never stripped one either.
Tekno EB48.3/ET48.3 Tekin gen2 RX8/1900 kv KO PROPO EURUS
Sponsored by
Tekno Rc
Dialed-Rc Hobbies
Advantage Racing Products
MOE is offline   Reply With Quote
Old 04-17-2013, 05:54 AM   #3356
luko's Avatar
NRRCMC President.
Old 04-17-2013, 06:25 AM   #3357
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
congrats to tlr canadian driver Dave Henry, he is on here giving advice for those that need it, super fast , smooth driver, wicked nice guy to talk to...
Uploaded with ImageShack.us
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-17-2013, 07:46 AM   #3358
SnotRkt's Avatar
I think I might buy the appropriate tap and pre tap my cases for my next round. Can't hurt, that way your not using the screws to pretap...
SnotRkt is offline   Reply With Quote
Old 04-17-2013, 08:04 AM   #3359
eddomak's Avatar
slot the diff screws with a dremel before you screw them in the diffs.that way you can use a small flatblade screwdriver..
Heh heh, pre-emptive Dremelling - I like it! That way you can use the hex, but if it all fails you still have the slot without scoring the casing itself. Nice one!
Losi SCTE 1.0 - BCE Chassis, Hobbywing SCT Pro, Hobbywing XERUN 3656SD 4000KV, Hitech HS-7955TG
TLR 22T - Orion R10 Pro, Turnigy 10.5T 3250KV
Axial SCX10 Honcho | Traxxas Mini Summit VXL | Losi Micro Desert Truck | Tamiya Boomerang
Airtronics/Sanwa MT-4 | Flysky GT3B - Custom firmware
eddomak is offline   Reply With Quote
Old 04-17-2013, 08:37 AM   #3360
ta_man's Avatar
Trader Rating: 151 (100%+)
I tapped mine part way and used a regular M2.5 socket head (not flat head) screw to pre-thread the diff cases the rest of the way. I was concerned that if I tapped to full depth, there would not be enough friction on the screws to keep them from backing out.
ta_man is offline   Reply With Quote
