Like Tree4Likes
Old 04-12-2013, 03:23 PM   #3211
ta_man's Avatar
Trader Rating: 151 (100%+)
Originally Posted by SuperDaveNT View Post
Could you not just use the 17mm hexes from the Losi 810?
Assuming you could find a set, 810 hexes would require some machine work to keep the wheels inside the body. I've done that on a set for one of my SCTEs. For my 2.0 I modified a set of OFNA 17MM T-Maxx adapters. That also required some machine work and using Ten-T axles. I think the Proline ProTrac rear 17MM adapters for the Slash would work with the standard SCTE axles but I only have one pair and they are now discontinued.
For any of these 17MM conversions using DE wheels, the truck is no longer officially ROAR legal. Not because of the 17MM hex, but because the DE wheel has a little bit more offset than the standard SCTE 12MM hex wheels and you end up over the ROAR width limit by about 1/8 to 3/16 inch. So far, no place I race has cared about that.
There is not much you can do about it: the 17MM hex can't be thinner than about 1/8" because the crosspins are already 1/10 inch thick.
ta_man is offline   Reply With Quote
Old 04-12-2013, 03:38 PM   #3212
Ya, I'm not doing any ROAR racing any time soon so that's ok.
SuperDaveNT is offline   Reply With Quote
Old 04-12-2013, 04:13 PM   #3213
I assume if you used the Ten T axles the small nut will thread on and hold the 17mm hex in place?
Old 04-12-2013, 05:03 PM   #3214
ta_man's Avatar
Me niether. The DE wheels are great and I can use them on other SC trucks I have because they all have 17MM adapters - no need for separate wheel/tire sets for each truck.
Yes and no. The crosspin through the 17MM hex holds it in place fine and with the wheel on the crosspin won't come out. But the 810 hexes don't fit absolutely tightly on the axle so a nut on the end takes out the play. For the first set, I milled a recess for the nut. For the second set I didn't bother - instead I milled the nut to reduce its height.
Also, on this second set I drilled and reamed the crosspin hole in the hub to exact fit on a precision reamer blank crosspin so I may not end up needing the nut after all. The nut doesn't stick out past the tire but is past the end of the wheel and looks a little hokey.
I also considered drilling a hole down the center of the Ten-T axle (after removing the threaded part) to allow use of a set screw to retain the crosspin (like on the 810 and regular 1/8 scales) but using the nut right now got me going faster on the next steps on my kit assembly. I might still do the set screw thing when I have some more time.
If you found and used the ProLine Protrac rear adapters on the regular SCTE axles, you would need the nuts included with the adapters.
Old 04-12-2013, 07:27 PM   #3215
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Can someone give me a link to a spring rate chart and the chart for the hinge pin inserts?? Please
TLR 22 SCT, Tekno SCT410, Airtronics MT-4
Clark RC Park, S&N's Trackside, MARCCA Carpet Racing
Gas Rat Racin is offline   Reply With Quote
Old 04-12-2013, 07:51 PM   #3216
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
http://www.tlracing.com/ProdInfo/Fil...uning_Tips.pdf
Found this for yea...
Originally Posted by Briguy
Anyone know the rates of the silver , gold , and black springs ? All I can find id soft med and hard .
Spring rates for LOSB 2959 Front set
Green - 3.6
Blue - 3.9
Black - 4.2
Purple - 4.5
Spring rates for LOSB 2963 Rear set
Red - 2.7
Orange - 3.0
Silver - 3.3
Green - 3.6
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-12-2013, 08:35 PM   #3217
Grandturk's Avatar
So... Did anyone else notice you can't get a motor in and out while the mud guards are on?
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-12-2013, 08:48 PM   #3218
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
lmao yes it is a hassle lol.... im thinking about shaving off some of the edge
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 04-12-2013, 09:50 PM   #3219
I'm just starting my kit tonight. Are most of you guys using the box stock set up or Ryan's? I noticed his is for indoor so is it good for outdoor to?
Old 04-12-2013, 09:57 PM   #3220
Trader Rating: 83 (100%+)
I can get mine out with some effort. Check your mud guards to be sure they are on the right side. When I built it I put them on the opposite side and couldn't get my motor out. If you swap sides it works.
bigbeej is offline   Reply With Quote
Old 04-12-2013, 10:05 PM   #3221
Panda-PR's Avatar
IMO the one on the manual is better for outdoor track
I did that. Still its a hassle lol
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 04-12-2013, 10:18 PM   #3222
silvalis's Avatar
Trader Rating: 29 (100%+)
Hey guys, whats the goto setup for outdoor dirt? My truck is going around corners holding a front paw up.
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 04-12-2013, 11:29 PM   #3223
evostyle's Avatar
Trader Rating: 102 (98%+)
Try running a heavier rear sway bar. You could also change to a stiffer rear spring but that'll also change shock absorbtion and jumping attitude. The sway bar will only change the amount of body roll. This may also make the rear a little looser and give you more steering on power.
"If you no longer go for the gap that exist, you are no longer racing". Ayrton Senna
evostyle is offline   Reply With Quote
Old 04-13-2013, 12:35 AM   #3224
Default Suggestions for scte gearing 3800kv 2 and 3s
Just wondering if anyone has some sugggetions on what gearing I should run on a losi scte for general bashing. Using as turnigy nanotech 2s 6600mAh 65c. I have a 3800kv 401 tenshock motor with a hobbywing sc8 esc. Also if anyone has any esc settings suggestions. Would like to use 3s as well not looking for massive speed but would like things to run quicker than the rtr setup and cooler. Thanks
FR0GGY is offline   Reply With Quote
Old 04-13-2013, 03:31 AM   #3225
silvalis's Avatar
Ok, thanks
I might try playing with rideheight and downstop a bit first. I eyeballed it instead of chucking it on the setup station, so it's probably a bit out.
Does this truck run well with lots of droop (say, like a mugen)?
