TLR TEN-SCTE 2.0 Kit Thread
#3121
It's always easier to point fingers at the "other" guy isn't it lol....terrible.
We are aware of quite a few esc's that ran run the Rx8 just fine. However of course WE recommend the Rx8.
Chances are good that if the esc is known to not work with the Pro4, it will also not work with the Pro4HD.
#3122
#3123
You're not wrong. The sensors in the motor either work, or they don't.
#3124
See thats one of the reasons why i run Sensoredless no need to worry about what motors work on what ESC etc. Depending on what ESC your running Sensoredless can be smooth !
#3125
On my SCT I had the Novak (worked great while it lasted) went too the MMP with BEC , then to the RX8 again cuase I went to the SCT410 chassis and the RX8 was the best fit . I do feel the Tekin RX8 is the best 1/8 ESC currently on the market but there are others that work just as well .
It isn't the motors fault that the ESC cant run it its the software in the ESC not working properly .
#3126
If you have ever ran on small postage stamp sized layouts you would see the benefits of a sensored system , though I will agree some ESC's are quite smooth when ran sensorless (the RX8 and HW150 being 2 that I have used) .
#3127
Just get an rx8 and run any motor u want. I have tried them all and now the rx8 is all I run its easy setup and in field adjusting with out having to take a laptop or mesmerizing beep and tones is what makes it so great IMO. Also u can use in just about all your cars 1/8 1/10 or whatever. Plus the tech support is awesome.
#3128
EXACTLY!
#3130
Yea i can agree on that on smaller layouts being felt more. The Brushless Hobbies ESC is smooth on Sensoredless mode well when you have the cap board still soldered onto the ESC not ripped off my fault on that one lol.
#3132
#3133
Anyone using the r10 pro 160a with a hobbywing 4000kv 4 pole? How is the esc handling it? I currently have an rx8 but I'm sick of carrying around my computer to change the settings. Also would like to swap my rs out for an Orion in my 22sct which Orion is best for that application?
what C rating are you using for batteries? i upgraded to the CRC sensor wires since they are more flexible and also upgraded to bullet packs so the ESC is direct wired to the 4mm bullets and plug into the batt and that got rid of my problem between the 2
#3134
Ive heard the Tekin motors are also noisey and that effects the the esc some how
right now all I have is 50c
#3135
Pro4 is a good fast motor but it was a big topic issue that mainly 4600kv for having a noisier signal of some sort, the fact the Rx8 runs dual drive which may cause it to not be affected. Rx8 is a good Esc aswell but I think each company has a bad one time or two slip pass to customers. The fact the RX8 is hard to get right now is why I'm trying a different setup and I will see how it goes. But you can't go wrong with any system they all work good.
