Like Tree4Likes
Old 04-09-2013, 04:19 PM   #3091
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by BDRMBULLY View Post
sent my rx8 in, havent heard from them in a month. then they said theyre short on parts and dont have red heatsinks(gonna replace with black), need another esc i guess and want the exrun 4000 motor, so what esc do i want to go with? sct pro or is there something better, does it have link to cpu or program box? or both maybe? all my stuffs been tekin so im not too sure,
I'm getting ready to try out the new vtx8 from viper I use to run Tekin as well
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-09-2013, 04:29 PM   #3092
Suspended
Trader Rating: 440 (99%+)
The brushlesshobbies lt4 works great in a sct. That's strictly what I ran in my last scte and it worked flawlessly. For $65 it's a bargain.
MattP is offline   Reply With Quote
Old 04-09-2013, 04:33 PM   #3093
jmc5313's Avatar
I've been lovin my new LRP Flow...400amp baby!!!
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 04-09-2013, 05:41 PM   #3094
jmc5313's Avatar
Originally Posted by Casper View Post
Being this is the 2.0 thread I am assuming you are using the HD diff cases. I would be you just did not get the screws tight. I found I needed to pre tap the threads by running the screws in and out of the diff case at lease once before I got a good seat of the gasket. Taping the threads down that deep I got a false sense of "tight". Once you kind of get the threads formed getting the screw in and out once I was able to compress the gasket properly and get a good seal. The HD diff cases come with a thicker gasket already that seals better. I had this issue when I first built my 2.0 diffs but on the second rebuild the screws went in much easier and I got a good seal and they have been perfect since.
Should i re-use that gasket?... my lhs only had non hd ones...
3MTA3
Old 04-09-2013, 05:46 PM   #3095
Suspended
As long as the gasket isn't torn at all I would reuse it. Just be sure to tighten the screws evenly in an x pattern to get a good even seal.
Old 04-09-2013, 06:11 PM   #3096
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Me and lrp are no longer friends, i had two lrp sxx v2 tc spec crap out after 5 min, apparently they knew theyre boards were bad and still sent me a bad replacement, hence the flow boards, i sold my 3rd one to a Friend and it crapped out after 5 min, i returned his money and threw it in the garbage, got tired of sending them back , what a waste O $ i was emailing directly with AE manager, i wont mention his name.
i bought the useless usb bridge for 50$ as well
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-09-2013, 07:05 PM   #3097
jmc5313's Avatar
That's not true at all....they were sending replacements out this summer that were the old design to keep guys going....they had a problem with the bec's...they were switching instead of linear....if you had actually talked to michael he would of told you to run an external bec until the new lower boards were available...thats what i did...if you have any old ones send em to me....they will replace ANY ESC with a bad lower board!!
3MTA3
Old 04-09-2013, 07:16 PM   #3098
BDRMBULLY's Avatar
Garbage!!! 3 esc later? 15 min run time total?
Junk. The ole spheres were great i took my loss over 360 spent on one esc that never worked, once bitten twice shy
Hand D Flooring
Old 04-09-2013, 07:48 PM   #3099
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Wrong I sent in one that fried from the lowerboard and they told me I was SOL.
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-09-2013, 07:56 PM   #3100
jmc5313's Avatar
Well...i guess its a good thing u switched over to tekin it sounds like you're having nothing but rainbow's and unicorns over there...360???? Dang.....u got robbed....i never paid over 260 for any of mine.....and for the other sol guy....double dang....i just got mine back two weeks ago....free of charge....by the way the new Flow just 189 outta Stormer....dont want u gettin robbed anymore....eh..
3MTA3
Old 04-09-2013, 08:31 PM   #3101
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Anyone using the r10 pro 160a with a hobbywing 4000kv 4 pole? How is the esc handling it? I currently have an rx8 but I'm sick of carrying around my computer to change the settings. Also would like to swap my rs out for an Orion in my 22sct which Orion is best for that application?
TLR 22 SCT, Tekno SCT410, Airtronics MT-4
Clark RC Park, S&N's Trackside, MARCCA Carpet Racing
Gas Rat Racin is offline   Reply With Quote
Old 04-09-2013, 08:45 PM   #3102
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Look at the hobbywing v3.1!
Blitzrockey is offline   Reply With Quote
Old 04-09-2013, 09:52 PM   #3103
BmainStar's Avatar
I have heard that the sct pro HW is very smooth with the 4000 kv HW motor....I have one rx8 in parts,one that threw smoke and one that wont recognize the car,the current one has a pinched wire LOL...I dont use credit cards anymore and you need one for repairs.Guess I could do a pre paid type card tho and send um in.. ....
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-09-2013, 09:56 PM   #3104
Once again, does anyone have the part number for the HPI diff screws?
SuperDaveNT is offline   Reply With Quote
Old 04-09-2013, 11:12 PM   #3105
suzuki_73's Avatar
found earlier in this thread
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
