Like Tree4Likes
Old 04-08-2013, 09:57 AM   #3061
Originally Posted by agarabaghi View Post
So just the kits alone:
2.0 w/ stock screws: 3.35lbs
2.0 w/ Ti screws: 3.25lbs
So about .1 lbs lighter or 1.6oz!!
Not bad at all, looking forward to weighing mine later this week. I'm also using titanium turnbuckles and the KH aluminum center diff mounts. I suspect I'll be a little heavier than yours.
Is anyone not using the droop screws in the chassis? I noticed I could get another ~1-2mm travel without them, I just don't know if taking them out is even necessary if the shocks at full length even cause the arms to hit the chassis.
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 04-08-2013, 10:03 AM   #3062
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Which Ti turnbuckles are you using? I saw a pic of someone's with gold turnbuckles
agarabaghi is offline   Reply With Quote
Old 04-08-2013, 10:21 AM   #3063
I went with the Lunsford SCTE set.
Old 04-08-2013, 10:22 AM   #3064
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Most likely durango 1/8 buggy tie rods
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-08-2013, 10:25 AM   #3065
They looked really cool ha.
The TI turnbuckles should be a bit lighter right?
Old 04-08-2013, 11:50 AM   #3066
xxfile's Avatar
Ok so its a quiet day on the forum...
Well we have completed bag G so we are done except for servo mounting and Motor /esc.
Thanks to this forum, and losi's build tips (probably from this forum) the whole build went smoothly.
I was walking a complete noob thru this and we took our time only working on it sunday afternoons and the occasional evening.
We had 1 each out of 12 diffs screws that went wrong, and the xpected issue with the shock caps but we were prepared and go thru it all...
Now the snow is ALMOST gone and its supposed to rain a lot the next two days which should take care of the rest of it.
They are however calling for 15-20 CM/ 4-8" of snow thurs/fri. FML.
We still have to mask and paint glue tires etc The Noob is pumped to get out.
We have had him indoor racing BRP sc18's on carpet all winter which was his first experience with RC cars.
Thanks Losi for building a great upgrade to the first truck. added up the Noobs Bill hes $1550.00 with hitec servo and castle MMP SCT system and faast Receiver for his Futaba, proline calibers and 4 batteries.
xxfile is offline   Reply With Quote
Old 04-08-2013, 10:05 PM   #3067
BmainStar's Avatar
On the 1.0 I ran full droop with shock bottoms unscrewed
maybe a bit too much LOL on this 2.0 I will run the same!!I think on a real blue groove track you will want them,other wise may not......
Casper or Ryan,are you guys running the plastic rear hubs or going with the alum for the 2.0. I kinda liked the plastic better on the 1.0 ,just trying to get my new truck (()) set up. Also seems as tho the bottom chassis c`snks are a bit shallow..? I think I can fix this myself at work ,but was wondering if this has been an issue..? Thanks ...
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-08-2013, 10:27 PM   #3068
Casper's Avatar
Trader Rating: 33 (100%+)
We are both running alum rear hubs because we can. One of those things you do when representing a company is running the hop up parts. We have found the stock plastic rear hubs hold up just fine but can become brittle in cold weather. Otherwise they work great. C'snks were a little off but not to the point of not shipping the cars. I know Ryan is aware of it and looking into it.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-08-2013, 10:53 PM   #3069
Mxer59's Avatar
Trader Rating: 114 (100%+)
Will these work for diffs?
ProTek R/C 2.5x12mm "High Strength" Flat Head Screws (10)
[PTK-H-2104]
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-09-2013, 04:06 AM   #3070
8ight-e's Avatar
Trader Rating: 57 (100%+)
I have not even bothered to weight these since getting the hobbywing xerun motor installed... LOL the little extra weight is a good thing and worrying about motor heat is in the past.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-09-2013, 04:09 AM   #3071
It's not the chasis because the Ti screw fit perfect??
It's also not the shock caps I don't think, cause old or new they don't fit flush, at least from what I've experienced.
None of these are issues that actually harm the truck though so I'm not worried. I was lucky enough to get the Ti kit with my 2nd kit and they fit perfectly flush with the chasis.
Old 04-09-2013, 06:50 AM   #3072
Arrow
Noticably so yes.
I was extremely surprised that my replacement parts from HH arrived last night. The truck is nearly complete!
Old 04-09-2013, 07:03 AM   #3073
Casper & Ryan, I don't suppose you would mind taking a caliper to your rear hinge pin to aluminum carrier and measuring both the the diameter of the pin and the inside diameter of the carrier? I ask because it looks like my aluminum carriers are .134 and the pins are .137.5 (including the newly replaced pins from HH CS). There really isn't a good way to mount the carrier to my mill so I'm considering either sanding down the pin in my lathe with an abrasive cloth or possibly using a reamer to bore out the hole to .138. Haven't quite decided yet, but I wanted to get a larger sample of that hole size.
Ryan, the aluminum carriers are 6061 or 7075? Do you by chance know what was spec'd for the diameter in that carrier hole?
Thanks again!
Old 04-09-2013, 07:31 AM   #3074
BmainStar's Avatar
Got it ,Thanks..
Toy Car Playerz
West Coast
Old 04-09-2013, 07:53 AM   #3075
Casper's Avatar
The stock screws are the same as they always have been. This counter sink issue is pretty minor the heads are just above flush. It is not much. The titanium screws most likely just have a little smaller head on them.
Thanks again!
I don't have good access to my truck but I am sure Ryan can stop in and help or PM him.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
