Like Tree4Likes
Old 04-06-2013, 02:04 PM   #3031
Panda-PR's Avatar
And here is the receiver i posted earlier
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 04-06-2013, 02:06 PM   #3032
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by Integra View Post
I would not advise that, Older "Ace" were the culprits who were guilty of sucking upwards of 15A under load. Stick with the AE version's.
Are the newer ones better now? Cause I already orderd one.
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-06-2013, 08:28 PM   #3033
Mxer59's Avatar
Anyone running the schuurspeed 4300kv that can give a decent gearing? On my scte 1.0 I ran a 13t with my 4600kv, should I go up to 14t now?
Futaba 4pls
Team Chase 2015
Old 04-06-2013, 08:49 PM   #3034
suzuki_73's Avatar
Originally Posted by mojo 309 View Post
I know at different tracks and condission not all tires will work at any given time lot depends on weather if its cool warm or hot outside if the track is dry slick dusty rought or smooth or if its watered alot durning the race day or watered only alittle.Certain tires might work really well starting out but wont as well as the day gets hotter,so my question is from the list of tires below
Hpi Blitz 2wd SC./Schumacher Mi3.5 US/VTA/LosiTenscte 4x4 SC.
Spektrum.
Speed Passion GT2.0 ESC/ v3.0 Comp Motors.
Savox Servo's
Mamba max pro/castle1410 motor-Old dogs never die,they just pass you by.
Not on your list but the track I run on sounds kinda like yours. People are having really good luck with the Panther Switch. I just ordered a set for myself being my barcodes had like zero traction today. Tried some warn out cityblocks, they hooked up good under power but for turning they pushed really bad.
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-07-2013, 09:36 AM   #3035
TCCustoms's Avatar
Do i see some QTEQ connections?!
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-07-2013, 10:45 AM   #3036
rcgod's Avatar
Trader Rating: 27 (100%+)
14-16
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-07-2013, 11:08 AM   #3037
Grandturk's Avatar
Schuur recommends 13-14 and 15 for really big open tracks. I've only run mine with a 13T so far and it's plenty for an indoor track. I ran outside for the first time with it yesterday. I got pulled on the straights with the 13 but had more interior punch. It kinda topped out early on the straight but the end of the straight was so slick it wouldn't have helped to have any more top speed anyway.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-07-2013, 01:32 PM   #3038
Panda-PR's Avatar
Yeah but I still suck at soldering. They held up today a ton of abuse!
Getting some nose dive, leaned rear shocks on the tower and moved the lipo to the rear and help a little. Thinking of trying front black springs next time (thoughts?)
snake pit:
Old 04-07-2013, 02:35 PM   #3039
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Nose diving can be prevented by proper trigger control coming off the jumps and in the air. How big are we talking? I'm running 27.5 front and 25 rear with the standard 3 and 4 pistons that come with the kit and any nose dive is my fault.
We run on a high grip indoor track with a small triple and some medium size doubles.
agarabaghi is offline   Reply With Quote
Old 04-07-2013, 03:09 PM   #3040
Some pictures of my 2.0s one is built with the Ti screw kit. Gonna swap the electronics over, but ill get the weight difference first...
Old 04-07-2013, 03:18 PM   #3041
louperez4's Avatar
Send a message via Yahoo to louperez4
nice truck's . I think I seen those tow before.
losi pro8,tekin pro 4 4300 HD,venom 70c 7000
louperez4 is offline   Reply With Quote
Old 04-07-2013, 03:45 PM   #3042
So just the kits alone:
2.0 w/ stock screws: 3.35lbs
2.0 w/ Ti screws: 3.25lbs
So about .1 lbs lighter or 1.6oz!!
Old 04-07-2013, 03:46 PM   #3043
Haha Lou had to take some pictures before the new gets used and abused!
Old 04-07-2013, 03:46 PM   #3044
Panda-PR's Avatar
I take the jumps and leave a little throttle to prevent nose dive but it has more to do with the tracks condition (bad shape). But I was using black front springs on the 1.0 on that track so it was my fault that did not brought them with me.
snake pit:
Old 04-07-2013, 03:52 PM   #3045
Could be give it a try!
Another note on the 2.0 kit w/ Ti screws is that they fit much better on the bottom of the chassis than the stock screws. I know someone else mentioned the stock screws not fitting flush
