Like Tree4Likes
Old 04-04-2013, 05:12 PM   #2971
tc5 man's Avatar
Yea them Soft City blocks on dry dirt do not last long for some reason and when the middle of the tread on them is gone to much they suck lol. Like it said though on high grip tracks, the wear is not as bad and they grip great when on a moist track !
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
tc5 man is online now   Reply With Quote
Old 04-04-2013, 05:39 PM   #2972
Brazman's Avatar
My rear springs rub the shock body. Is this an issue?
Brazman is offline   Reply With Quote
Old 04-04-2013, 05:44 PM   #2973
tc5 man's Avatar
Thats the same issue with the 1.0 also just push the the spring up and turn it and it will fit tighter around the shock coller better. I dont get why there like that though.
Old 04-04-2013, 07:28 PM   #2974
suzuki_73's Avatar
Does anyone else feel the top shock caps should not slide back and forth as much on the mount as they do? Or am I missing something there? I have the spaces but they slide forward and back quite a bit.
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-04-2013, 07:36 PM   #2975
Miller2's Avatar
Default Sadly turned off now
I was super excited to build this kit. I know many ppl had issues with diff screws I took my time and even put black grease on them for easier screwing. I stripped 2 screws and couldn't get them out. Now I have to order both parts and wait to finish bag B. big disappointment.
Miller2 is offline   Reply With Quote
Old 04-04-2013, 07:51 PM   #2976
suzuki_73's Avatar
I honestly had zero issues with the diff screws using these tools- http://www.dynamiterc.com/Products/D...ProdID=DYN2909
Traxxas Slash 4x4
Old 04-04-2013, 08:03 PM   #2977
tc5 man's Avatar
Dont waste your money on the stock diff screws just get two bags of the HPI screws .
Old 04-04-2013, 08:06 PM   #2978
tc5 man's Avatar
Na nothing to worry about if anything having the shocks go back and forth on the mounts makes less binding . Now if its excessive over time i would replace the shock mounts .
Old 04-04-2013, 08:41 PM   #2979
suzuki_73's Avatar
Cool, figured I'd ask before running the truck. Thanks.
Traxxas Slash 4x4
Old 04-04-2013, 10:12 PM   #2980
Mxer59's Avatar
Trader Rating: 114 (100%+)
what's a good servo for this truck? ds1015 been out of stock
Also what other screws can be used for diffs? the Hpi ones have been out of stock
Is a 280mm sensor wire long enough?
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 04-04-2013, 11:19 PM   #2981
Trader Rating: 19 (100%+)
I was excited myself. Too get this truck. I had the same problem putting the first front diff together. I stripped 1 screw the first time. I bought a whole new diff.
This is what I did with my diffs. I screwed the screws in the diff housing first. Then took them out,before I put the diff together. Then screwed the whole diff together.
It made it easier and you don't have the chance to strip out the screws.
Speed Passion-B-Fast R/C-Liverc.com-Dirt Heaven-Revolution Raceway-Venom Designs-M&M Home repair and remodeling LLC-92 Zero Designs.
b4wires is offline   Reply With Quote
Old 04-04-2013, 11:44 PM   #2982
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Any servo around 200 oz of torque or greater and .145 or faster you will be in good shape!
For the sensor wire 270-275 is perfect. 280 you will have a little bit of slack.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 04-05-2013, 12:42 AM   #2983
Trader Rating: 110 (100%+)
Subscribed
*MIP/SCTE*
+FTM GRIP+
socal23 is offline   Reply With Quote
Old 04-05-2013, 04:27 AM   #2984
Thumbs up
Try checking ace servos. They are the ones that make the ds1015. It's a few bucks cheaper when u get it from them .
* HobbyWing of N.A. * Nitrohouse *M.I.P.*Proline * Carl D. *
Losi57 is offline   Reply With Quote
Old 04-05-2013, 06:11 AM   #2985
Integra's Avatar
I would not advise that, Older "Ace" were the culprits who were guilty of sucking upwards of 15A under load. Stick with the AE version's.
