Like Tree4Likes
Old 04-03-2013, 03:50 PM   #2911
JoeW's Avatar
Where are most of you mounting the receiver? On the chassis between the motor and servo? Or on the out side of the servo box?
Just to get mine running (still waiting on pro4 hd motor and rx8) I used the electronics from my old scte RTR truck. Mounting the receiver on the side of the servo really makes the wires stick out right to the side guard and seems to get rather dirty out there. Is a better place for it on the chassis behind the servo?
JoeW is offline   Reply With Quote
Old 04-03-2013, 03:51 PM   #2912
Casper's Avatar
Trader Rating: 33 (100%+)
Transponders are not working well on the chassis. Put it on the side of the servo. They work well there.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-03-2013, 03:58 PM   #2913
rcgod's Avatar
Trader Rating: 27 (100%+)
+1. Mine wasn't picking up when on the chassis.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-03-2013, 04:13 PM   #2914
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
That's one of the complaints of the kit is that there is no secure place to put the electronics but I've had no issues with mine
agarabaghi is offline   Reply With Quote
Old 04-03-2013, 04:14 PM   #2915
Also looks like the shock caps are still tight to put on
Old 04-03-2013, 04:19 PM   #2916
Casper's Avatar
I believe they are still on first shipment kits so yes lower caps are still tight. I have not heard if replacements are ready yet.
Old 04-03-2013, 04:48 PM   #2917
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Crazy thing is i run my transponder on the flat portion of the front bumper and it has survived some really bad crashes fits perfect and when fighting for last place i get that extra 0.0005ths of a second....i placed my receiver on the chassis behind the servo no issues there i just make sure i blow the receiver off after every run
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 04-03-2013, 04:55 PM   #2918
JoeW's Avatar
Not the transponder...the receiver for the radio.
Old 04-03-2013, 05:00 PM   #2919
Side of servo not the most protected but it works
Old 04-03-2013, 05:01 PM   #2920
Old 04-03-2013, 05:46 PM   #2921
TCCustoms's Avatar
Just got 3 more kits in... 2 are being shipped out but one ill be building again with the Ti screw kit. I'm wondering if the shock caps or diff screw issue has been revised? Also... Will the TI screw kit have different screws for the diffs?
still no...as ive said a few times i talked to HH personally and they said Ryan will post on here once he gives the OK and then they will ship and they will most likely have nothing to do with the diff screws so just buy the HPI Z449's and be done with it if it bothers you or just take your time and use the stock ones.
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 04-03-2013, 05:49 PM   #2922
Panda-PR's Avatar
FYI the tc3 and rpm receiver box are too big. Still looking for one small enough to fit behind the servo.
Any of you know if HPI Racing Desert Trophy Trucks has a small enough receiver box?
http://www3.towerhobbies.com/cgi-bin...&I=LXCHTX&P=ML
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 04-03-2013, 05:59 PM   #2923
Whoa dude easy with the hostility... I'm a horizon dealer I was just curious. This is the 5th kit I've personally be through. My
Builds have gone perfectly fine... I was just wondering if I should wait for my Ti kit or proceed building the diffs and shocks. So no nothing is bothering me ...
Old 04-03-2013, 06:30 PM   #2924
TCCustoms's Avatar
no hostility, just saying...just stating that ive talked to them and posted 3-4 times that Ryan will post on here before HH most likely even knows the new shock bottoms are ready and shipping
As for the screws its gotta be bothering you just like the caps since you seem to think that they are gonna do something about the hardware even some took their time and did have issues. Everyone knows that they are a bit tight and this is my first build and just by hearing about them being tight by the few that had the truck before me or the 1.0 trucks with the updated housings i just hopped on ebay and bought the HPI for the build so you kno there is another option and for less than 10 bux for more than all 12 screws needed its worth getting them just for the ease of use come time to do maintenance and take them out and put back in
Old 04-03-2013, 06:38 PM   #2925
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Has the diff screw issue has been revised?
Feint Motion is offline   Reply With Quote
