Like Tree4Likes
Old 04-03-2013, 09:51 AM   #2896
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Purdue Engineer View Post
I have 14 pinion on motor. I came off the track after a 5 min heat at 145 deg on the motor. How hot is to hot for this motor? I just took a look at the notes I had from the guy I bought the rx8 off of. He ran it in a 4x4 Durango sc. He had the pinion at 16 and the current limiter at 30 and 0 timing. This was on the same track and dirt I'm running on. I think he told me he talked to Randy about those settings for this track, but I'm not sure.
Maybe I'll try that. What are your thoughts on that?
Randy says the motor is good up to 200. Mine comes off between 150-170 depending on the track and outside temp. You could probably go up another tooth and you could drop the CL down some more and this should smooth out the bottom for you without effecting top or even gaining some top end. (CL only effects low speed punch). Timing should not effect low end as well as timing ramps as RPM increases so that is a top end thing as well. I would take the timing out and go up a tooth and drop the CL and see how that works for you.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-03-2013, 09:58 AM   #2897
rcgod's Avatar
Trader Rating: 27 (100%+)
My rear torque rod bottoms against the case before the holes line up to put the screw in. Anyone else had this problem?
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-03-2013, 10:23 AM   #2898
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
14T on the TLR is fine, your temps are good as long as you're under 200f on the motor after a full run.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 04-03-2013, 10:27 AM   #2899
Trader Rating: 15 (100%+)
Talking right..
Originally Posted by BDRMBULLY View Post
Not sure if he meant those , or the losi rear alloy gear box inserts, that are made only for the rear and not the front,
Buhp im so confused lol
exactly, i meant it's bearing housing, losi part number "Team Losi Racing Aluminum Rear Gearbox Bearing Insert Set [TLR3100]" sorry for confusing.
GJ KIM is offline   Reply With Quote
Old 04-03-2013, 10:37 AM   #2900
Purdue Engineer's Avatar
Thanks Randy and Casper for the help. I'm getting closer and closer to getting it where I like it. Thanks for all the help.
Randy - I talked to you a while ago, back when I had the Durango. I was asking you for help with my rx8, pro4 4600 and the Durango 4x4 sc. I have moved on to the 2.0 and I'm loving it!
Purdue Engineer is offline   Reply With Quote
Old 04-03-2013, 10:38 AM   #2901
Yes it's off. File away at the ball end to make the diameter smaller. It only takes a bit. Make sure the screw goes straight thru and not at an angle.
Tony Vega is offline   Reply With Quote
Old 04-03-2013, 10:52 AM   #2902
suzuki_73's Avatar
Almost done building the rear end of the truck. Can't wait to get this thing running! Anyone have any issues with any of the axles fitting into the bearing in the hub? I'm going to have to do some grinding on one of my rears because it only fits half way into the smaller hub bearing. Other than that no issues..Am I the only one who had zero issues with the diff screws? lol
TLR Ten SCTE 2.0 Tekin RX8 Tekin Pro4 4600
Traxxas Slash 4x4
suzuki_73 is offline   Reply With Quote
Old 04-03-2013, 11:59 AM   #2903
Casper's Avatar
These have always been a tight fit. I have never had to file but you could. I always just forced it into place.
Old 04-03-2013, 12:26 PM   #2904
tc5 man's Avatar
Im willing to bet its a burr around the axle stub or its a Manf error.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 04-03-2013, 12:56 PM   #2905
suby723's Avatar
Trader Rating: 21 (100%+)
I've seen first hand that your casings are wrong. I've seen others mention it on here. How bout you guys fix the issue instead of pointing fingers back at the customer!
suby723 is offline   Reply With Quote
Old 04-03-2013, 01:14 PM   #2906
suzuki_73's Avatar
Yeah, the other one is nice and smooth and this one is really rough. I'm going to hit it with my dremel a little to smooth it out. It's not only in one place it's all the way around.
Traxxas Slash 4x4
Old 04-03-2013, 01:17 PM   #2907
Grandturk's Avatar
Try a little scotch brite pad on it first. It may just be a little bit of thick coating around the part.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 04-03-2013, 01:30 PM   #2908
tc5 man's Avatar
Oh yea i woundnt use the Dremel its easy to mess them up with it. I would know from a diffrent truck i ran before !
Use a Scotch pad or some sandpaper and lightly sand it down.
Old 04-03-2013, 01:48 PM   #2909
2low4u's Avatar
Originally Posted by xxfile View Post
Well unless ur indoor the -40 temp in PEI should call for about 0.5 weight LOL
Lol, we have shock Oils in the negtive numbers here .
Losi 8 2.0 Tekno E-Conversion, Tekin RX8 Gen1, Tekin 1900kv
TLR SCTE 2.0, Tekin RX8 Gen 2, Tekin Pro4 4600kv.
Assoicated B4.1FT Worlds Edition, BH 120A, Turnigy 8.5T & 17.5T.
Futaba 4PL.
2low4u is offline   Reply With Quote
Old 04-03-2013, 03:08 PM   #2910
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Just got 3 more kits in... 2 are being shipped out but one ill be building again with the Ti screw kit. I'm wondering if the shock caps or diff screw issue has been revised? Also... Will the TI screw kit have different screws for the diffs?
agarabaghi is offline   Reply With Quote
