Like Tree4Likes
Old 04-02-2013, 11:24 AM   #2866
goehm's Avatar
Trader Rating: 44 (100%+)
Originally Posted by JoeW View Post
So do you clean the bearing areas at all or just leave them alone? After using the motowash and rinsing with water just let it sit or do you hit it with some silicone pray or something to seal it?
I clean the bearing areas with a toothbrush, and I use a radio box so I really can't address the receiver cleaning issue. However, for my other vehicles it doesn't get that dirty, but when I do clean I just use a toothbrush there as well. If I want to do a more thorough job in those areas, then after the first pass with a dry brush, I'll spray the brush with the Motul Motowash and scrub it a little.
For your arms and such, you don't need to pre-wash before using Motowash, nor do you need to wash the Motowash off. It's one-stop cleaning.
A+
Also - I try not to use compressed air to clean my shocks. I did one time and when I rebuilt the shocks I was trying to figure out why they were so pressurized. Then I remembered the air compressor. LOL!
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 04-02-2013, 11:28 AM   #2867
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by GJ KIM View Post
Thanks. i didn't know that... cause every build threads..there were a metal..
I think they were talking about these.
http://www.hot-racing.com/index.cgi?...CTE11C01;c=629
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-02-2013, 12:11 PM   #2868
Quietman_MD's Avatar
Originally Posted by xxfile View Post
Look close at the pic in the manual... the letters go up
Thanks...I should have put my glasses on.
Quietman_MD is offline   Reply With Quote
Old 04-02-2013, 12:40 PM   #2869
xxfile's Avatar
Oh so you're old like me?
if you lay the part over the manual picture it usually becomes apparent.
Ive built about 10 Losi's from kits over the years sooooo...
AND Left is the drivers side by the way
xxfile is offline   Reply With Quote
Old 04-02-2013, 12:44 PM   #2870
xxfile's Avatar
I've seen those but havent ever read a reference on this thread that anyone was using them...
The new Losi parts are great I rebuilt my 1.0 with them when they first arrived and have just finished all 3 of my 2.0 diffs
Old 04-02-2013, 12:56 PM   #2871
Casper's Avatar
I think I had seen these meantioned before but would not want the extra wieght. I agree def not needed with the new HD cases.
Old 04-02-2013, 01:21 PM   #2872
Lightbulb
Hello all I need some help with my a arms. Each arm have the letter r-right l-left and finished side and unfinished side. Now do the finished side goes up or down? (letter L-R up or down)
Another way to look at this is by the droop screw adjustment. The hex-end is on the top and the oval shape on the set screw is on the bottom and is over the droop screw hole on the chassis. You can also refer to the sway bar and shock mounts. In all three cases it can only be one way. It's just like a Lego instruction sheet.
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 04-02-2013, 02:04 PM   #2873
BmainStar's Avatar
Originally Posted by CaseyP View Post
SCTE 2.0 was awesome this weekend. I worked on set up and tuned in on what I will be liking. Nice work Ryan
Sweet.. Casey P... in the house.....
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 04-02-2013, 03:59 PM   #2874
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Not sure if he meant those , or the losi rear alloy gear box inserts, that are made only for the rear and not the front,
Buhp im so confused lol
SCTE, DESC 410, XRAY XB4, MBX6 ECO
I hate feeling bad about feeling good about that!
Hand D Flooring
BDRMBULLY is offline   Reply With Quote
Old 04-02-2013, 04:03 PM   #2875
rcgod's Avatar
Trader Rating: 27 (100%+)
A tip for when you build the diffs. Make sure you use a new tip on the hex driver or if the one you have is even slightly worn you can grind it a little shorter with a dermal cutoff wheel or sanding drum. I rounded off the first screw I tried to install and didn't have any of the hpi screws, so I ground the tip back and all of the rest of the screws installed easily with no problems.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-02-2013, 04:04 PM   #2876
xxfile's Avatar
Hmmmm that could be...
hes in north Dakota I think so he could be suffering from frostbite much like the rest of us north of the US of A
Old 04-02-2013, 04:38 PM   #2877
JPKinsella's Avatar
Trader Rating: 30 (100%+)
The hot racing alum. diffcases are 2.3grams heveier than the losi HD diffcases. I run the hot racing diffcase in the center never had any problem and with the king headz center diff mount looks really good. could not tell any diferance in proformance..... By the way the hot racing rear Alum hubs are 1.5 grams lighter than the plastic losi hubs WOW...
AE B5M, Hot boddies D413, Kyosho RB6 mod, Orion ESC, Radio Post servos, Futaba 4pks
NOT HERE FOR A LONG TIME JUST A GOOD TIME!!!!!!!!!!
DON'T HACK ME BRO............
JPKinsella is offline   Reply With Quote
Old 04-02-2013, 04:52 PM   #2878
BDRMBULLY's Avatar
For the price of one hotracing diff case i could buy 3 hd losi diff cases and maybe squeeze in a large timmy's lol
Hand D Flooring
Old 04-02-2013, 06:12 PM   #2879
CaseyP's Avatar
Lol, I'm sure Casper and Ryan have you guys covered in here but I'm up for questions.
We all have different wants goals in a set up, and I'm getting mine where I want it.
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 04-03-2013, 03:49 AM   #2880
maddog9's Avatar
Trader Rating: 29 (100%+)
This past saturday was a higher competition club race at my local track. Had tq rounds 1 and 2 and in round 3 was beat out by 2 seconds. Start 2nd and finish 2nd in the Main. I was able to beat a fast small sponsored tekno driver and was able to beat the guy who usually always win with his 1.0 scte.
maddog9 is offline   Reply With Quote
