Like Tree4Likes
Old 04-01-2013, 09:28 PM   #2851
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Originally Posted by JoeW View Post
what about cleaning the electrical components?
I use a small paint brush and dab of very little water, and brush away clean. Air dry with a compressor.
Feint Motion is offline   Reply With Quote
Old 04-01-2013, 10:05 PM   #2852
CaseyP's Avatar
SCTE 2.0 was awesome this weekend. I worked on set up and tuned in on what I will be liking. Nice work Ryan
<>< The Truth Will Set You Free!
TLR / Team Orion / Spektrum / AKA / TEKIN / Horizon Hobby / upgrade rc / AVID / SCH / SPY / HAL'S HOBBY WAREHOUSE
CaseyP is offline   Reply With Quote
Old 04-02-2013, 06:47 AM   #2853
JoeW's Avatar
Originally Posted by goehm View Post
Some of the guys at a local track (LCRC, which is also an ATV/cycle shop) showed me some Motul Motowash concentrated cleaner, and I've been using it ever since. 1 liter pump bottle is about $15 shipped, it's strong enough such that you can cut it 50:50 with water for 2 liters. Aside from being impossible to beat price-wise, it works really, REALLY well.
Works great to cut grease and dirt and super plastic friendly. Biodegradable.
For what it's worth, if the bearings are sealed I wouldn't hit them with lube. It won't really penetrate well and will collect more dirt. Also make sure you don't spray compressed air on the bearings as you'll inject them with grit which will kill them.
Motul link here:
http://www.motul.com/us/en-US/products/644
So do you clean the bearing areas at all or just leave them alone? After using the motowash and rinsing with water just let it sit or do you hit it with some silicone pray or something to seal it?
JoeW is offline   Reply With Quote
Old 04-02-2013, 07:33 AM   #2854
8ight-e's Avatar
Trader Rating: 57 (100%+)
Cleaning, spray w simple green 50/50, rinse w water, use compressor to blow off, wd40 all plastics and wipe down w a towel. Fast and awesome results.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 04-02-2013, 08:18 AM   #2855
JoeW's Avatar
What is your solution for a receiver/servo and ESC covered with a layer of dirt? Can't simple green them, can't hose them off.
Old 04-02-2013, 08:29 AM   #2856
blade329's Avatar
Trader Rating: 114 (100%+)
Compressed air.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 04-02-2013, 09:00 AM   #2857
JoeW's Avatar
Originally Posted by blade329 View Post
Compressed air.
And just wipe the rest off? Wonder if contact cleaner would work?
Old 04-02-2013, 09:12 AM   #2858
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
any electrical cleaner will work. so has anyone besides the wing mod fitted something to protect the stiff
agarabaghi is offline   Reply With Quote
Old 04-02-2013, 09:14 AM   #2859
Trader Rating: 15 (100%+)
I've a question.
Is the rear diff bearing housing a matel? or plastic? in SCTE2.0
As i know it's aluminum, but in my kis, there is a plastic version.
which is right genuine parts?
GJ KIM is offline   Reply With Quote
Old 04-02-2013, 09:17 AM   #2860
plastic
Old 04-02-2013, 10:18 AM   #2861
Thanks. i didn't know that... cause every build threads..there were a metal..
Old 04-02-2013, 11:08 AM   #2862
xxfile's Avatar
I would be careful with any liquid it would tend to wash the dirt down into the circuit boards... if you turn it upside down and brush it with a paintbrush most will come off.
Using compressed air is pretty sketchy too as it blows dirt INTO the bearings... the seals dont really seal all that well. I pop the seals out and pack the outer side of the bearing with grease then reseal to create a barrier to dirt and dust.
turning the truck upside down and whacking the bottom of the chassis with a good sized screwdriver knocks a LOT of the dirt out.
xxfile is offline   Reply With Quote
Old 04-02-2013, 11:14 AM   #2863
Quietman_MD's Avatar
Default A arm HELP!!!!
Hello all I need some help with my a arms. Each arm have the letter r-right l-left and finished side and unfinished side. Now do the finished side goes up or down? (letter L-R up or down)
Quietman_MD is offline   Reply With Quote
Old 04-02-2013, 11:16 AM   #2864
xxfile's Avatar
Look close at the pic in the manual... the letters go up
Old 04-02-2013, 11:17 AM   #2865
xxfile's Avatar
cant imagine what build threads, i haven't seen one talking about Metal diff cases.
