Like Tree4Likes
Old 03-28-2013, 10:17 AM   #2656
Originally Posted by jmc5313 View Post
I was there the night it was put together....ring gear was tight....bearings were seated correct...and it rubbed the inside of the diff case for sure...but only with diif case bolts installed and tightned reasonably...thats how it was discovered to drill out the front part of the diff screw holes...and yes it works now like it should have in the begining.... i think wyotitans main gripe is that after all of the hold time and phone jockeying he was treated like a fool that had no idea what he was talking about....i dont know how many times we heard....ive built ALL kinds of these with NO PROBLEMS......well guess what he did have an issue that was fixed with little to no help from Horizon...
Are you referring to the two screws that hold the front triangle brace on?
Originally Posted by wyotitan View Post
well i went rounds with horizon tech.. no one has ever had this problem??.. just the 2 in wyoming i guess. was also told by tech that they dont follow rc tech much as it just a bunch a.... funny if ya want 2 talk 2 the guy that designed it this is the place... with the 2 scte they built in the tech dep. at horizon they did strip the diff. ring gear bolts and had 2 dremal them out... so if you have had problems dont feel bad the techs at horizon do 2.... so is it us them or the truck ... also side note if ya like the 22s and expect the same quality ya could be ... the scte ten comes from a dif. manufacture.. and it shows...
I am sorry that is how you feel you were treated. It shouldnt be like that at all. I did say I am looking into it. I have ordered some parts direct from this latest production run so I will put them together and see what we have going on.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-28-2013, 10:24 AM   #2657
jmc5313's Avatar
No the 2 bottom Button Head Screws that hold the diff cases together...
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 03-28-2013, 10:26 AM   #2658
I was under the impression you both were talking about the front diff adn in that case, there are two cap heads and two flat heads that hold the case together.
The rear case has two flat heads and then the two really long button heads that sandwich everything together...
-Ryan Dunford
Old 03-28-2013, 10:51 AM   #2659
jmc5313's Avatar
LOSA6240......5-40 X 1/2"....sorry going off memory...the front half of diff case was the part drilled....so now screw goes through the front half with no threading and screws into back half....and now there is no rub...on his....mine didnt rub the case like his although they felt similar....i eventually got mine to seat properly....however I still had what felt like a rough spot on the teeth of the ring gear....casper said he had same issue and that the gear would break in properly....is this true?
3MTA3
Old 03-28-2013, 11:01 AM   #2660
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Well I drove my truck with the defective shock bottom caps and even though they were not mounted 100% flush they seemed to work just fine ... So I guess the issue is more cosmetic than structural.
agarabaghi is offline   Reply With Quote
Old 03-28-2013, 11:08 AM   #2661
handyman77's Avatar
mine are halfway screwed and they are working fine so far
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
handyman77 is offline   Reply With Quote
Old 03-28-2013, 11:09 AM   #2662
Has anyone tried the MIP shocks on the 2.0 ... Well I guess it's the shock internals right?
Old 03-28-2013, 11:15 AM   #2663
Just finished my 2.0 build last night. What a bad @$$ truck.
I have 1 concern, my rear brace does not fit in my diff at all. It seems the casting or mold shifted and the rear of the eyelet bottoms out well before the holes line up. I can shave it down, but wondering if anyone else has had this issue?
NCR Motorsports is offline   Reply With Quote
Old 03-28-2013, 11:17 AM   #2664
XRated SCT's Avatar
I had the same problem, just mess with it a little and you'll find a way to get it in there it took me about 5min. to figure it out haha
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-28-2013, 11:18 AM   #2665
Yea it's a little off but you can make it work.
Old 03-28-2013, 11:28 AM   #2666
handyman77's Avatar
^^^ +1
Old 03-28-2013, 12:04 PM   #2667
+2. I had to cut away some of the ball cup.
Tony Vega is offline   Reply With Quote
Old 03-28-2013, 03:53 PM   #2668
Lets talk about sex baby...
Old 03-28-2013, 03:57 PM   #2669
Trader Rating: 35 (100%+)
Send a message via AIM to robby26wi Send a message via Yahoo to robby26wi
think your nuts are upside down for battery hold down...
robby26wi is offline   Reply With Quote
Old 03-28-2013, 04:22 PM   #2670
Trader Rating: 28 (100%+)
+1 but the carbon is nice looking
Gso125 is offline   Reply With Quote
