Like Tree4Likes
Old 03-27-2013, 10:10 AM   #2611
handyman77's Avatar
Trader Rating: 25 (100%+)
[QUOTE="Smiley";11979231]Yes, The FTW Fan Mount will work.
QUOTE]
Thanks Smiley, I will be ordering one!
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
handyman77 is offline   Reply With Quote
Old 03-27-2013, 10:12 AM   #2612
handyman77's Avatar
Originally Posted by XRated SCT View Post
I was thinking of throwing a heatsink on, this is what I did on my velineon system, heatsink w/ some artic silver 5 thermal compound this thermal grease IMO is one of the best out there since I'm experienced w/ it fixing electronics, one thing I learned about heatsinks is for it to work full potential the heat needs to actually get to the heatsink and using this grease does that flawlessly, but it's just a tip if you really want temps to go down
Thanks Bud, I used to run my velineon with a fan and I could run bigger pinions and keep temps down
Old 03-27-2013, 10:14 AM   #2613
Brazman's Avatar
First timed run with the new truck last night. I dropped 0.7 off my pb (set with scte 1.0) in the first race which was the third pack through the truck. also I was a little more consistant as well. Only problem I had was that when I tried to push really hard I was having traction rolling issues when I got on power mid corner. Either I need to try something with the setup or change my driving style. I am using the stock shock setup (not the 2 hole 55's) although I went 30 with the oil because it get hot here. I will try the 55's or drop the oil to 27.5 to see if it helps.
Brazman is offline   Reply With Quote
Old 03-27-2013, 10:22 AM   #2614
Send a message via AIM to agarabaghi
Casper / hacker07 - any input in the diff wobble? Should we be concerned?
As for temps and run times, I'm running the castle mmp and 3800kv combo and 1 back on a high bite clay track (~18mins30second) my temps were 90f and 135f Esc/ motor. Got to say I'm loving the setup, nice and cool. And my run times are great and I'm using sky lipos 5000 mah 20c so they aren't even the best batteries.
I don't even think I could deal with anymore power... But I'm still tempted to pick up the pro4hd 4300 when it comes out just to have a smooth sensored setup.
agarabaghi is offline   Reply With Quote
Old 03-27-2013, 10:27 AM   #2615
XRated SCT's Avatar
My pro4 4600kv rips enough as is I could only imagine the HD
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-27-2013, 11:46 AM   #2616
Here some pics of the girl after the first track day.
Mmp w/ 3800kv 4pole 1410 castle motor
Hitech 7945sh servo
Skylipo 5000mah 2s 20c
OrangeRx micro rx
Jconcepts Pressure point tires
Was averaging about 18min run times on each pack, pretty please with that result
Went through a set of tires in 1 practice day haha!!! Gonna have to pick up a "practice" tire. I'm thinking medium caliber might be a good all around practice tire. Any suggestions for a tire to use on indoor clay that I won't eat through in 1 day!!
I've tried barcodes and though they hook up great I basically run them down in 1 practice day.
Here are some pics:
Also anyone running a rear skid? I def ate through some plastic and aluminum...
Old 03-27-2013, 12:58 PM   #2617
BmainStar's Avatar
Originally Posted by tupapi77 View Post
Ryan,
Thanks for your reply, I am running the activ8 esc from novak and that comes with preset drag brake which I forgot to tone down so I will do that, also mesh was set up correctly...I have about a total of 10 packs on this truck so I am not sure if that can be called "broken in"
I will try the drag brake and will see what happen
Thanks again
Josh
Def, no drag brake and no timing of any kind with that motor.On an RX8 most run some current limiter as well to control heat. And 13 is fine at a small track like LRH....
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 03-27-2013, 01:01 PM   #2618
BmainStar's Avatar
You do not want to run a skid plate,it will skid way earlier than the chassis and not allow the proper ride ht. Chassis wear is gonna happen but it will last a long time even like that!!Cheers!
Toy Car Playerz
West Coast
Old 03-27-2013, 02:00 PM   #2619
dtr
dtr's Avatar
Lighter oil will make traction rolling worse.
I would try lowering ride height first, then stiffer sway bars, then stiffer springs and thicker oil. Reducing negative camber can also be a quick help.
dtr is offline   Reply With Quote
Old 03-27-2013, 02:09 PM   #2620
mojo 309's Avatar
How much rebound is needed for the shocks? and whats a good wight oil for the front and rear shocks was kinda thinking 35 for the front and 30 for the rear. and what about the springs use what comes with it?
Schumacher MI3.5 us/vta,
Spektrum.
Speed Passion ESC.
Savox Servo's.
Midwest Kustomz.
mojo 309 is offline   Reply With Quote
Old 03-27-2013, 02:12 PM   #2621
Casper's Avatar
Trader Rating: 33 (100%+)
We run the shocks emulsion style (no bladders) and basically no rebound. (a slight amount is fine). With stock pistons I would start with 27.5wt all around. Stock springs are a great starting point.
The kit setup works really well. You may want to tweak it some but I think most will agree it is quite good in most conditions with the correct tires for you track.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-27-2013, 02:50 PM   #2622
Blitzrockey's Avatar
Like casper said the kit setup it pretty much dialed!
Blitzrockey is offline   Reply With Quote
Old 03-27-2013, 03:30 PM   #2623
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
I found the kit setup to be REALLY good outdoors on semi low to medium bite and Dunford's setup on page one to be better indoor on medium to high bite.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 03-27-2013, 04:01 PM   #2624
[/QUOTE]
what is the difference in the inner vs outer hole on the servo arm?
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 03-27-2013, 04:29 PM   #2625
weavty1's Avatar
Thumbs up
Originally Posted by skyler hays View Post
what is the difference in the inner vs outer hole on the servo arm?[/QUOTE]
Less of a positive 'expo' effect that the far outside hole gives you.. The inner hole makes steering more linear and direct, IMO.. That and the majority of the TLR factory guys run that, as well.
Tylor "with an O" I can levitate birds. No one cares.
TLR 22 2.0 RM / TLR 22 2.0 MM / TLR 22-4 / TLR 22T / TLR 22 SCT / TLR SCTE 2.0 / TLR 8IGHT-E 3.0 / Team Losi XX-4 WE / Team Losi XXX-4 G+
weavty1 is offline   Reply With Quote
