Like Tree4Likes
Old 03-27-2013, 09:13 AM   #2596
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Originally Posted by agarabaghi View Post
Anyone ?? I have the car apart cause that seemed wrong...
Yeah , THAT is a normal amount of play . Did you ever have the older style diffs that came with (and still do come with) the SCTE 1.0 ? Those had so much play that the sun gears would skip on the spider gears under hard braking . I used to rebuild my diffs after 15-20 packs as they would start clacking badly after the sun gears were stripped ....
The new diffs that come with the 2.0 are as tight as any of my 1/8th scale diffs ....
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 03-27-2013, 09:15 AM   #2597
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Awesome. I guess I can put the truck back together! Man did she drive well.
agarabaghi is offline   Reply With Quote
Old 03-27-2013, 09:20 AM   #2598
Purdue Engineer's Avatar
Mine is the same way. All of my out drives are like that. I've been racing for three weeks now like this and no problems that I can tell. Yes, it does not seem right so I would like to here from Ryan or Casper about this. I just raced last night and was thinking of taking the whole truck apart and inspecting everything, but I don't know.
Purdue Engineer is offline   Reply With Quote
Old 03-27-2013, 09:32 AM   #2599
handyman77's Avatar
Question, got my tekin 4600 yesterday and is running hot!! so I want to put a fan on it...any ideas about a good mount for it? there was one that mounted to the center diff but it was for the 1.0..would it work for the 2.0?
Please advise
thanks
MBX7TR....O.S. SPEC 3 .NOVAROSSI PALOMA 7
MUGEN SCTE CONV. TEKIN 4600 HD HOBBYWING XR8
MBX7R..NOVAROSSI DRAKE MOTOR
HOT BODIES D413 LRP VECTOR 6.5T
LRHhobbies.com in placentia, CA.
handyman77 is offline   Reply With Quote
Old 03-27-2013, 09:38 AM   #2600
maddog9's Avatar
Trader Rating: 29 (100%+)
Please advise
thanks
Go down a tooth or two on your pinion gear.
maddog9 is offline   Reply With Quote
Old 03-27-2013, 09:40 AM   #2601
Please advise
thanks
How hot is hot ? 150-160 feels really hot too the finger but is perfectly fine .
The mount for the 1.0 will work but you might loose the wire hold down that the 2.0 comes with .
You can get a clip on heatsink/fan mount for a 540 motor for pretty cheap , I use one from Integy and it works great ....
Old 03-27-2013, 09:42 AM   #2602
handyman77's Avatar
running a 14t now
this is the fan I was talking about, does anyone knows if this will work?
Old 03-27-2013, 09:43 AM   #2603
handyman77's Avatar
After a full pack (about 9 min) it got to 200 with a 14t so that is why I am a little concern
clay track,lots of traction indoor
Old 03-27-2013, 09:47 AM   #2604
XRated SCT's Avatar
Thats weird I also have the 4600kv pro4 and I'm running 13t, the hottest I've seen mine is 140, 13t is good enough for me I might even drop to a 11 or 12t, is your mesh tight?
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-27-2013, 09:54 AM   #2605
handyman77's Avatar
I guess I can drop it to a `13t and see what happen! still would like to run a fan if possible
Old 03-27-2013, 09:54 AM   #2606
One thing I will always point out is that temperature is always relative to the human that is driving. Some people are smoother, some are more notchy, this will result in different temperatures. So, someone giving a good starting point is always ok, but it may not hav ethe same results. Also, everyone maintains their trucks differently as well, this can result in different temps. Assuming the truck is broken in but fairly new, gear meshes are correct, then it is the driver that determines heat. BRAKES are probably the single biggest factor in heat. Everyone always talks about their forward settings but brakes are huge. For example, on my ESC, it is set at 100 on my RX8. But on my radio, for the last track I was on, my brakes were at 45%. Something to consider.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-27-2013, 10:00 AM   #2607
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Yes, The FTW Fan Mount will work.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 03-27-2013, 10:01 AM   #2608
XRated SCT's Avatar
All makes sense to me I'll take that into consideration, yea last weekend I was running and my temps were around 140 when I checked and I only ran a couple mins. after that so I know it didn't go any higher then 150 give or take, then I tried tightened my gear mesh too tight just experimenting and not a long run I was at 176
Old 03-27-2013, 10:07 AM   #2609
XRated SCT's Avatar
I was thinking of throwing a heatsink on, this is what I did on my velineon system, heatsink w/ some artic silver 5 thermal compound this thermal grease IMO is one of the best out there since I'm experienced w/ it fixing electronics, one thing I learned about heatsinks is for it to work full potential the heat needs to actually get to the heatsink and using this grease does that flawlessly, but it's just a tip if you really want temps to go down
Old 03-27-2013, 10:08 AM   #2610
handyman77's Avatar
Ryan,
Thanks for your reply, I am running the activ8 esc from novak and that comes with preset drag brake which I forgot to tone down so I will do that, also mesh was set up correctly...I have about a total of 10 packs on this truck so I am not sure if that can be called "broken in"
I will try the drag brake and will see what happen
Thanks again
Josh
