Like Tree4Likes
Old 03-25-2013, 06:00 AM   #2446
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Page 163 and we are still complaining about the same BS.... this truck dominates even for a rooking in the game like me! Hey TLR great job love the truck and the minor issue did nothing to stop me from building and racing!!!!
Now if we start talking tuning options that would be nice... If anyone is running outdoors with big jumps let me know what kinda weights you are using in your shocks? I ran the AE 2 hole shock limiters and ran 35 in the front and 32.5 in the rear stopped alot of the bottoming out on the big jumps...anyone using any of the race springs?
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-25-2013, 06:08 AM   #2447
Purdue Engineer's Avatar
[QUOTE=Now if we start talking tuning options that would be nice... If anyone is running outdoors with big jumps let me know what kinda weights you are using in your shocks? I ran the AE 2 hole shock limiters and ran 35 in the front and 32.5 in the rear stopped alot of the bottoming out on the big jumps...anyone using any of the race springs?[/QUOTE]
I was just thinking the same thing. How about when someone makes a setup change and they really like it, they post what they did. I run on a med size dirt clay mix track. I had the upper rear camber link in the stock position and couldn't get the truck to rotate off power around the tight turns. Moved it to A-1 and boy what a difference.
Purdue Engineer is offline   Reply With Quote
Old 03-25-2013, 06:11 AM   #2448
ill have to try that its funny because turning right was on point turning left to alot more effort couldnt understand why this was happening... i moved my lower front shock to the middle hole made a good difference on landings, but i lost some of the tight turning....
Old 03-25-2013, 06:29 AM   #2449
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
So how did the 2.0 do racing this weekend ? Saw some at the local track and they looked fast , fastest guy at the track is still running a 1.0 .....
Have you been ripped off by Brushless Hobbies ? If so go to BBB.org and file a complaint !
BashemSmashem is offline   Reply With Quote
Old 03-25-2013, 06:45 AM   #2450
weavty1's Avatar
Thumbs up
TLR and JConcepts Factory Driver, Chris Viesins took 2nd place in Open Pro4 this weekend at Psycho Nitro Blast VI, in Georgia!
He was running a box stock SCTE 2.0, running a slightly altered stock/factory setup.
All weekend long, he was dialed.. Good job Chris!
Tylor "with an O" I can levitate birds. No one cares.
TLR 22 2.0 RM / TLR 22 2.0 MM / TLR 22-4 / TLR 22T / TLR 22 SCT / TLR SCTE 2.0 / TLR 8IGHT-E 3.0 / Team Losi XX-4 WE / Team Losi XXX-4 G+
weavty1 is offline   Reply With Quote
Old 03-25-2013, 06:46 AM   #2451
ussprinceton's Avatar
Originally Posted by Brazman View Post
LOSA99032
It is made for the 8ight I believe though it is what most people use.
ok...thanks
ussprinceton is offline   Reply With Quote
Old 03-25-2013, 07:24 AM   #2452
maddog9's Avatar
Trader Rating: 29 (100%+)
Mybe its an actual steering issue or could be a setup issue. Did you double check that you have your steering horn at 90 degrees to your servo when the wheels are centered? Also maybe check to see if you have full travel both direction, usually until the servo buzzes and then back it if off 2-3 points. And finally double check that the steering tie rods are equal length.
maddog9 is offline   Reply With Quote
Old 03-25-2013, 07:25 AM   #2453
maddog9's Avatar
The fastest guys probably will not switch over since they are already at the top, until they start getting beat by average drivers.
Old 03-25-2013, 07:35 AM   #2454
Appreciate it! ill look at those things today....another driver told me my servo saver was too loose so that may have played a part as well... Oh i just switched controllers from a 4pl to a ko propo eurus!!!
Old 03-25-2013, 07:45 AM   #2455
nanoverse's Avatar
Just a correction. Don't adjust EPA with servo buzz, but look for maximum throw. Especially the Savox servos start buzzing early and you don't use all possible linkage travel.
Just reread your post and you basically said the same thing.
HB E817 | HB D815e | HB D413
Hitec Lynx 4s
nanoverse is offline   Reply With Quote
Old 03-25-2013, 07:54 AM   #2456
Yeah, if they already have a dialed truck that is killing it, I doubt that they will be switching over yet. If the pack starts catching up, time to start working on the 2.0
TLR 8ight 3.0, Reds R7
Lots of scale crawlers too!
fulbore4x4 is offline   Reply With Quote
Old 03-25-2013, 07:57 AM   #2457
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
hehe so i order the carbon battery strap since it looks so sexy =D
agarabaghi is offline   Reply With Quote
Old 03-25-2013, 08:01 AM   #2458
rhys's Avatar
Default Can not find it!!!
Where are the team setup sheets? Or atleast someones great setup.
rhys is offline   Reply With Quote
Old 03-25-2013, 08:02 AM   #2459
1st page
Old 03-25-2013, 09:01 AM   #2460
maddog9's Avatar
Make sure your wheels on your truck as well.
