TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 03-19-2013, 12:01 PM
  #2251
Purdue Engineer's Avatar
Hay Ryan,
I would also like to here what your running for your RX8 setup. Randy also helped me out and said yes to decrease the current limiter to reduce wheel spin.
Purdue Engineer is offline
Old 03-19-2013, 12:04 PM
  #2252
jrz93's Avatar
Originally Posted by XRated SCT
Anybody know where I can get a 275mm sensor cable shipped and delivered by this Saturday the latest?
Lol I have same issue and ordered the 275mm tq so I can't run at my local track tonight! Also I'm not gunna read through 150+ pages but found several errors in manual, the biggest one is that the mud guards are side specific, the one with the lip goes on the battery side. They Do not ( or I cannot find a L or R on them) have markings and if u put the battery side on the motor side u cannot slide motor to fit a 14 tooth on it. Just FYI for anyone on the build
Easy fix but if u don't know, u will soon find out!!
jrz93 is offline
Old 03-19-2013, 12:13 PM
  #2253
R/C Tech Elite Member
blade329's Avatar
Trader Rating: 114 (100%+)
Nitrohouse.com, if they carry that item. My favorite place to get things fast in California.
blade329 is offline
Old 03-19-2013, 12:21 PM
  #2254
Default Updated Dakotah Setup
Sorry guys, got some better data...
hacker07 is offline
Old 03-19-2013, 12:32 PM
  #2255
Originally Posted by RC-Rick
OK I was going to ask you in Saturday what your RX8 settings were, but since you brought it up, would you mind sharing? I recall Randy saying that they've been recommending the limiter be dropped down to say 70% as they are finding it really reduces wheel spin and doesn't take away from lap times.
Thanks!!!
Always happy to share...this is from memory...lol...and the important stuff.
As always, I will give my disclaimer that brakes are the biggest cause of heat issues and while I set them at 100 in the esc, they are always down between 45-55 on my radio. Definately using the 223 software...so nice! Geared with 14 tooth pinion and stock 40t spur.
current limiter - 80%
drag brake - 12 (this is not for everyone and takes some getting used to)
timing at factory end points and 10%
expo is linear
brake strength at 100 (again turned way down around 45-55 in radio)
neutral width at 32
throttle min at 3
brake min at 0
hacker07 is offline
Old 03-19-2013, 01:14 PM
  #2256
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by XXXDad
will 200mm work?
Too short go with 275 or 300
BlackStarRacing is offline
Old 03-19-2013, 02:52 PM
  #2257
TCCustoms's Avatar
Looks like GMK has shock piston drill set!
Or this one that has alot of bits and even the 1.3
http://www.amainhobbies.com/product_...ston-Drill-Set
This was explained in the first post by Hacker07(Ryan) in the Build tips here
Side-Guards (F-1) – When installing the side-guards onto the chassis, at first glance, they look the same, however they are different. One side holds the battery in place and one side allows room for the motor. If you look along the inner edge of the guards, you will notice one has a high spot and the other is low the entire way. The one with the high spot is for holding the battery and is the left guard and the other lower one is the right guard.
Just another reason why the title needs changed so people read the first post like they did with the 22SCT....
TLR 22SCT Thread (Check First Page for FAQ & INFO)
TCCustoms is offline
Old 03-19-2013, 03:00 PM
  #2258
Trader Rating: 25 (100%+)
So I weight this beast... And to my surprise she is no beast...
Calibers mounted: 0.95lbs
7.4v 5000mah lipo: 0.60lbs
Losi scte 2.0 no body: 4.25lbs
Jammin scrt10 no body: 4.3lbs
Losi scte 2.0 no body complete: 5.8lbs
Jammin scrt10 no body complete: 5.75lbs
I was a bit shocked
agarabaghi is offline
Old 03-19-2013, 03:28 PM
  #2259
Smile Tires
I am picking one if these up this week. What are the best tires and foams for indoor clay?
Hurt'n4SomeDirt is offline
Old 03-19-2013, 03:30 PM
  #2260
drepus's Avatar
Thumbs up
I was a bit shocked
I had 2 in my hands the other day and it was weird but they both felt lighter than what I remembered my 1.0 felt like.
drepus is offline
Old 03-19-2013, 03:36 PM
  #2261
TCCustoms's Avatar
Dakota Phend just used the proline IONs at the Cactus Classis and won and i used them on carpet locally and they worked quite well and was very happy with them also!
http://prolineracing.com/tires/ion-s...mc-clay-tires/
Old 03-19-2013, 03:50 PM
  #2262
tc5 man's Avatar
Hows the wear on them on carpet the clay compound ones ? I know i used the Panther Rattler tires Clay compound and they wear fast the foams wear with it the on carpet ! Them JC Pressure points wear good on carpet from my exprience grip good.
tc5 man is offline
  #2263
We use barcodes at our indoor clay track.
Old 03-19-2013, 04:21 PM
  #2264
maddog9's Avatar
Trader Rating: 30 (100%+)
Whats is meant by bump steer up + .060"?
maddog9 is offline
Old 03-19-2013, 04:25 PM
  #2265
TCCustoms's Avatar
I only used them maybe 4 times(seperate times) and havent noticed any wear yet
i would assume that means he added (2) .030" shims
