Like Tree4Likes
Old 03-19-2013, 10:57 AM   #2236
Originally Posted by Tony Vega View Post
Ryan - how about a part number for the M2.6 x10 diff screws?
LOSB3591
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-19-2013, 10:58 AM   #2237
Originally Posted by Potoczak View Post
Hey guys would I be able to run a Orion vortex r10 pro speedo in this truck??
That is what Dakotah just used to win the Cactus with in this truck. It works well with 2 pole from the factory or if you use it with say a Tekin 4600 4 pole which is a great motor, you just need to update the software to the 4 pole software. Although my RX8 is super dialed.
-Ryan Dunford
Old 03-19-2013, 10:59 AM   #2238
Thumbs up
Originally Posted by Gas Rat Racin View Post
What I'm trying to avoid is gluing holes shut. I found some blank Kyosho pistons that I will drill 2 55 holes in.
Looks like GMK has shock piston drill set!
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 03-19-2013, 11:07 AM   #2239
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by hacker07 View Post
This is all for very high traction, warm climate. It does not transcribe well to anything other than maybe carpet racing. they had 37.5wt front and rear. If its colder than the 85+, you want to go about 5 wt down for every 10-15 degrees cooler.
He was running that low pinion gear as they are still running 2 pole 550 in the orion camp and so they are gearing them low and adding timing for the high.
So would that setup work on a tight technical, medium traction, damp clay?
maddog9 is offline   Reply With Quote
Old 03-19-2013, 11:11 AM   #2240
You would be better off running the setup I posted on the first page or the kit setup.
-Ryan Dunford
Old 03-19-2013, 11:14 AM   #2241
OK I was going to ask you in Saturday what your RX8 settings were, but since you brought it up, would you mind sharing? I recall Randy saying that they've been recommending the limiter be dropped down to say 70% as they are finding it really reduces wheel spin and doesn't take away from lap times.
Thanks!!!
Old 03-19-2013, 11:16 AM   #2242
Trader Rating: 83 (100%+)
Thanks!!!
Would really appreciate some rx8 settings as well.
bigbeej is offline   Reply With Quote
Old 03-19-2013, 11:17 AM   #2243
XRated SCT's Avatar
Anybody know where I can get a 275mm sensor cable shipped and delivered by this Saturday the latest?
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-19-2013, 11:22 AM   #2244
rpphobby
Old 03-19-2013, 11:24 AM   #2245
Potoczak's Avatar
Trader Rating: 111 (100%+)
Great thank you!
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-19-2013, 11:28 AM   #2246
XXXDad's Avatar
Trader Rating: 195 (100%+)
Questions?? sesor wire
will 200mm work?
RX8-4600
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 03-19-2013, 11:29 AM   #2247
Amain hobbies. TQ wire is what I have in mine.
http://www.amainhobbies.com/product_...or-Cable-275mm
Tony Vega is offline   Reply With Quote
Old 03-19-2013, 11:33 AM   #2248
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
also found this top plate...
http://www.kkpit.com/index.php?main_...jpemrt8jjkdpk0
agarabaghi is offline   Reply With Quote
Old 03-19-2013, 11:33 AM   #2249
XRated SCT's Avatar
Originally Posted by bigbeej View Post
rpphobby
cool and it'll be delivered by this Sat.
Old 03-19-2013, 11:58 AM   #2250
drepus's Avatar
Originally Posted by XXXDad View Post
will 200mm work?
RX8-4600
Not quite. A 230mm will just reach with the sensor port on the rx8 positioned towards the rear of the truck. The 270mm will reach with room to spare.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
