Like Tree4Likes
Old 03-19-2013, 09:34 AM   #2221
XRated SCT's Avatar
Originally Posted by bigb11 View Post
will losi come out with a chassis cover to keep dirt out.
I would hope so but I don't really care for the plastic protectors/covers, I was trying to figure out if any of the outerwears protectors will fit the 2.0 chassis, only thing is outerwears is pretty pricey for a net and some velcro
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-19-2013, 09:59 AM   #2222
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Avid also has 4 hole 1.3 Pistons. You can glue 2 holes shut.
http://www.avidrc.com/product/5/acce...cessories.html
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 03-19-2013, 10:01 AM   #2223
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Who makes the carbon top plate ive seen on some of the 1.0s and a few 2.0s... I saw Hot Racing makes one but it comes with a front chasis brace...
Integy also has one, but im not really an integy fan...
agarabaghi is offline   Reply With Quote
Old 03-19-2013, 10:03 AM   #2224
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
What I'm trying to avoid is gluing holes shut. I found some blank Kyosho pistons that I will drill 2 55 holes in.
TLR 22 SCT, Tekno SCT410, Airtronics MT-4
Clark RC Park, S&N's Trackside, MARCCA Carpet Racing
Gas Rat Racin is offline   Reply With Quote
Old 03-19-2013, 10:04 AM   #2225
+1
Old 03-19-2013, 10:18 AM   #2226
XRated SCT's Avatar
Originally Posted by Gas Rat Racin View Post
+1
This?http://www.nitrohouse.com/product.as...FcZ_QgodX24AWg
Old 03-19-2013, 10:20 AM   #2227
Default Phend winning setup from Cactus
Here is the setup Phend used. Again, this was in big part from Billy F, so I gotta give him the shout out.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-19-2013, 10:21 AM   #2228
Originally Posted by XRated SCT View Post
Nah, thats for the diff, im talking over the steering posts
Old 03-19-2013, 10:22 AM   #2229
http://www.integy.com/st_prod.html?p...17&p_catid=271
Old 03-19-2013, 10:30 AM   #2230
SNR makes one but its $29!
Old 03-19-2013, 10:44 AM   #2231
maddog9's Avatar
Trader Rating: 29 (100%+)
I see hes running 11T pinion gear, is he using a huge kv motor? And i am assuming35WT shock oils front and rear would be the way to go for indoor ohio cold?
maddog9 is offline   Reply With Quote
Old 03-19-2013, 10:49 AM   #2232
Originally Posted by maddog9 View Post
I see hes running 11T pinion gear, is he using a huge kv motor? And i am assuming since 35WT shock oils front and rear would be the way to go for indoor ohio cold?
This is all for very high traction, warm climate. It does not transcribe well to anything other than maybe carpet racing. they had 37.5wt front and rear. If its colder than the 85+, you want to go about 5 wt down for every 10-15 degrees cooler.
He was running that low pinion gear as they are still running 2 pole 550 in the orion camp and so they are gearing them low and adding timing for the high.
-Ryan Dunford
Old 03-19-2013, 10:51 AM   #2233
Ryan - how about a part number for the M2.6 x10 diff screws?
Tony Vega is offline   Reply With Quote
Old 03-19-2013, 10:51 AM   #2234
Potoczak's Avatar
Trader Rating: 111 (100%+)
Hey guys would I be able to run a Orion vortex r10 pro speedo in this truck??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-19-2013, 10:51 AM   #2235
Grandturk's Avatar
If he's running the big Orion 550 then he's probably geared way down for the track. Lots of 180's and not really any long straights. The 4.0 and 4.5 turn 550's are usually around 5000kv
Your Product Name Here
Grandturk is offline   Reply With Quote
