Like Tree4Likes
Old 03-18-2013, 09:41 PM   #2206
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Gas Rat Racin View Post
Sure those should work but now you need to find a 1.3mm drill bit. Getting some #55 pistons and gluing two holes is probably as cheap and easy. Just my opinion.
I have issues with the glue coming out. I have a set of drill bits just have to find out what size drill bit is close to 55 1.3 hole. Why doesn't TLR make blank pistons since it seems like most of the pros are modifying the 4 hole pistons anyway?? Seems like an easy moneymaker to me. Thanks for your response Casper.[/QUOTE]
That is a good question.
Your std still bit set will not have the correct size and I hate to say it close is not good enough for this as small differences in the hole sizes can make a dramatic difference in the damping characteristics.
Find some CA kicker. Ise a thicker CA and this goes pretty quick. Dab the holes to cover with glue and then at about arms length spay with a CA kicker. Flip over the piston and repeat. Once you have done or or two it goes pretty quick.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-18-2013, 09:42 PM   #2207
hkrob's Avatar
Trader Rating: 18 (100%+)
The drill bit you will need is a #55 size.
hkrob is offline   Reply With Quote
Old 03-18-2013, 09:49 PM   #2208
Casper's Avatar
Originally Posted by agarabaghi View Post
Are the dimples on the pre cut body that comes with the scte 2.0 kit in the right spot for the tower body mounts?
Unfortunately with the 2.0 body mount spacers the dimples don't line up anymore.
Old 03-18-2013, 10:28 PM   #2209
Will TLR be posting the team drivers setup sheets from the Cactus Classic?
Kuma is offline   Reply With Quote
Old 03-18-2013, 10:30 PM   #2210
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Thanks that's what I thought but wasn't sure I guess that's why there called 55 pistons!?!
TLR 22 SCT, Tekno SCT410, Airtronics MT-4
Clark RC Park, S&N's Trackside, MARCCA Carpet Racing
Gas Rat Racin is offline   Reply With Quote
Old 03-18-2013, 10:46 PM   #2211
Casper's Avatar
I know Ryan has already said he would try and find the setups. I am sure he will post them when he gets them. My understanding is Billy had the better of the two setups and Dakotah used Billy's but not know this as fact. Remember what ever this setup is it is a VERY high bite setup. I am sure it would be great for all you guys that run on carpet.
Old 03-18-2013, 10:53 PM   #2212
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Well calling it a night ... Got some tires on order ... Seems like my other tires stick out quite a bit but I might still run them if we head to the track tomorrow.
agarabaghi is offline   Reply With Quote
Old 03-19-2013, 02:08 AM   #2213
bigb11's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to bigb11
will losi come out with a chassis cover to keep dirt out.
PHAT QUAD RACING, HPI/HOTBODIES, RATZAS, DARKSIDE MOTOR SPORTS, PARMA, Brown Engineering, ROBITRONICS, RC AMERICA, PANTHER, TEKIN, TEAM HOLY ROLLER, Rev Tech/Epic, RC AFRICA, HITEC www.browneng.org, DE wheels
bigb11 is offline   Reply With Quote
Old 03-19-2013, 04:38 AM   #2214
Trader Rating: 60 (100%+)
Where can I get all black wire for my ESC to Motor? I'm trying to go with the stealth look on the wires.
it worked before you crashed it and broke it.
Graphite07 is offline   Reply With Quote
Old 03-19-2013, 05:35 AM   #2215
Originally Posted by XRated SCT View Post
Nice, I'm about to go to my LHS tomorrow to do some more soldering and then come home and give it a wire tuck lol, one point of advice I'd give you is your sensor wire I'd zip tie it or something cause I did the same thing just had it hanging and it got caught on the spur gear but that was my stock wire that came w/ my tekin motor I'm getting a long one tomorrow
I do have my sensor wire zip tied to the front diff stand. Thanks
Joel Johnson
TLR SCTE 2.0, TLR 22 SCT, TLR XXX-SCT
publicenemy is offline   Reply With Quote
Old 03-19-2013, 05:50 AM   #2216
Panda-PR's Avatar
Tqwire and check also the wires for the servo (all black)
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 03-19-2013, 07:53 AM   #2217
goehm's Avatar
Trader Rating: 44 (100%+)
AE makes 1.3 t hole pistons that are a direct swap.
As for glue coming out, do you mean that once dried, the oil/pressure is pushing it back out of the hole during use? If so, two options:
  • Make sure the glue mushrooms out of the hole on each side. This will prevent it from blowing out.
  • The other solution (which is what I do when not using AE pistons) is to take a slightly oversized drill bit and countersink each side of the holes - so that it sorta looks like an hourglass. I usually fill my holes with JB Weld epoxy. Then when done, you can sand the pistons flat if you want to.
--GO!
Come visit G's RC Raceway / Shippensburg, PA / www.GSRC.us
goehm is offline   Reply With Quote
Old 03-19-2013, 08:02 AM   #2218
I couldn't find any 1.3 2 hole pistons what's the part number on those you found?
Old 03-19-2013, 08:54 AM   #2219
Grandturk's Avatar
The AE 1.3 pistons are not 2 hole. But of course you can glue those as well.
I'm sure TLR will be releasing their own 2 hole pistons soon. AE is just quicker about getting new pistons out, I guess.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-19-2013, 10:32 AM   #2220
Casper's Avatar
Yeah the AE ones are 1.3 4 hole but you could glue two shut.
