Like Tree4Likes
Old 03-18-2013, 07:09 PM   #2191
TCCustoms's Avatar
as ive said before Ryan will let us know when the new shock bottom caps are out according to HH as they have not released/received the new ones yet so if you get caps they will not be the new ones unless you can get the 1.0 bottoms as i think someone said they will work also unless that is also the same press that made these to where they are all fudged up
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 03-18-2013, 07:17 PM   #2192
Trader Rating: 60 (100%+)
Originally Posted by agarabaghi View Post
Same but I picked up a pack from the lhs and they sure didnt go on very easy either ... Went on a bit better but not exactly easy������
i used a cap from a losi scte 1.0 and it screwed right on with no problem.
il wait on the new ones to come in.
it worked before you crashed it and broke it.
Graphite07 is offline   Reply With Quote
Old 03-18-2013, 07:20 PM   #2193
BmainStar's Avatar
Originally Posted by XXXDad View Post
OK.... what helped me is ( yes) you need to turn the spring adj screw (Left) to tighten the spring. So go (counter clock wise )and it will start to spring back. To locate it turn the TX upside down. Hope this helps!
Yesss!!!!That did it!!!Was told I had to replace it.Raced it like that Sat nite LOL Back to the regular 2,0 programming!!THANKS!!!!!!
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 03-18-2013, 07:26 PM   #2194
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
I figured the shock plastic part (losb2904) would be the 1.0 caps as they don't come with the HA balls for the shock ends?
agarabaghi is offline   Reply With Quote
Old 03-18-2013, 07:27 PM   #2195
XRated SCT's Avatar
Originally Posted by publicenemy View Post
Went together excellent.
I did not like how long the servo wire ended up being, so I shortened it.
My excess RX8 wiring is folded and heat shrink ed under the servo.
The excess transponder wiring is coiled under the servo.
My glitch buster wire was the perfect length, also routed under the servo and out the rear.
I had a 9" sensor wire, and it is barely long enough. I would have liked a slightly longer sensor wire, but it works.
I eliminated the ESC switch. I did not like having it located right behind the front tire, with no protection.
So, what do you think?
Nice, I'm about to go to my LHS tomorrow to do some more soldering and then come home and give it a wire tuck lol, one point of advice I'd give you is your sensor wire I'd zip tie it or something cause I did the same thing just had it hanging and it got caught on the spur gear but that was my stock wire that came w/ my tekin motor I'm getting a long one tomorrow
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-18-2013, 07:32 PM   #2196
drepus's Avatar
I helped out two new scte 2.0 owners with their newly built trucks today and was able to get the 2.0 bottom shock caps screwed on all the way quite easily using the heat gun tip and a nice set of wide nose pliers. So don't be afraid to heat them up!
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 03-18-2013, 07:36 PM   #2197
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Gas Rat Racin View Post
I saw the setup on the first page says 2 hole 55 pistons from the 22. So I'm assuming the 2 hole AE pistons we use for the 22 will also work?? Do I need to modify the piston at all to work? What size holes are on the 55 pistons?
I think I found some blank pistons that will work if I drill 2 1.3mm holes in them.
http://www.amainhobbies.com/product_...k-Piston-Set-2
Let me know what you guys think.
TLR 22 SCT, Tekno SCT410, Airtronics MT-4
Clark RC Park, S&N's Trackside, MARCCA Carpet Racing
Gas Rat Racin is offline   Reply With Quote
Old 03-18-2013, 07:54 PM   #2198
Finished painting my body... Not very good at it ha...
Old 03-18-2013, 07:59 PM   #2199
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by BmainStar View Post
I said I would take your word on it!!!!You have given me what I will take as the truth.I am sorry if my words did not sit well with you even after I said ,,,(I would take Your Word.) My intention is to get a response or in your case a reaction ,hoping to hear yes the parts are gonna be available on this or that date ,not to accuse, Cheers!!Have Fun!!!
Oh Man thanks ,Gonna mess with it now.Been asking every where and no body really knows LOL Thanks again!!Prolly should find the manual too!!LOL
Manual: http://www.tlracing.com/ProdInfo/Fil...000_Manual.pdf
Sure those should work but now you need to find a 1.3mm drill bit. Getting some #55 pistons and gluing two holes is probably as cheap and easy. Just my opinion.
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-18-2013, 08:03 PM   #2200
TCCustoms's Avatar
except they are on back order through HH and ive been waiting for 2+ weeks since my LHS ordered them and still waiting so i just did the stock pistons and will replace the lower caps and pistons at the same time
Old 03-18-2013, 08:15 PM   #2201
duneordie's Avatar
Trader Rating: 31 (100%+)
Anybody tried These yet? Looks and sounds cool in the video. There was something like this with flappers that opened on the return stroke to let the shock move a little quicker on rebound a few years ago if i remember...
duneordie is offline   Reply With Quote
Old 03-18-2013, 08:15 PM   #2202
Casper's Avatar
You can glue two holes on the stock pistons and drill those if you are going the drilling route.
Old 03-18-2013, 08:19 PM   #2203
Are the dimples on the pre cut body that comes with the scte 2.0 kit in the right spot for the tower body mounts?
Old 03-18-2013, 08:23 PM   #2204
Sure those should work but now you need to find a 1.3mm drill bit. Getting some #55 pistons and gluing two holes is probably as cheap and easy. Just my opinion.[/QUOTE]
I have issues with the glue coming out. I have a set of drill bits just have to find out what size drill bit is close to 55 1.3 hole. Why doesn't TLR make blank pistons since it seems like most of the pros are modifying the 4 hole pistons anyway?? Seems like an easy moneymaker to me. Thanks for your response Casper.
Old 03-18-2013, 08:32 PM   #2205
Blown up's Avatar
Kits built! S6040 servo's in. Still need ESC/Motor. Over all nice kit. I do need new lower shock caps cause I mauled them in frustration. I also ran into the weak diff screws and I had a brand new spring steel 1/16 driver bought just for the occasion. I did get the rear built w/the HPI443 screws and hope TLR replaces thier kit screws w/these.
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
