Like Tree4Likes
Old 03-18-2013, 02:15 PM   #2146
Originally Posted by RC-Rick View Post
So last week I ended up cancelling my conversion parts order as I figured if I'm gonna have to wait, then I should at least see what the prices will be at my LHS and online. This weekend I went to my LHS to see what they knew and there it was all by its lonesome, begging to find a home , a SCTE 2.0 kit. Needless to say I broke down and bought the kit. I already have almost all of the hopups that I was working on for my 1.0, and will now add to my 2.0 as backups. I tried gluing the 55 pistons and think the smaller aluminum 4-40 nuts work better in case the glue cap is to large. I had to clear off and apply a new glue cap on a couple of holes after I tightened down the steel lock nut; the aluminum lock nut has a smaller contact patch on the piston. I'm also going to try the M2C Racing pistons as well. I'm not sure what weight oil to try, so any input on that is appreciated (SoCal indoor; SDRC). I'm leaning towards 27.5 up front and 30 in the rear.
Casper and I will be at SDRC this saturday in case you want any hands on help.
Originally Posted by jmc5313 View Post
Hacker or casper...I am assembling the front diff when i bolt the case halves together i get a tight spot when i rotate the pinion...when its totally loose no tight spot..when half tight it is a slight tight spot...any suggestions....
so, you are referring to just the diff, not putting the diff as a whole into the tranny cases? It shouldnt have a tight spot, if it does, pull it all out and make sure the bottom sun gear is fully seated with that pin.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-18-2013, 02:18 PM   #2147
Casper's Avatar
Trader Rating: 33 (100%+)
Congrats on breaking down and getting a kit! Yeah a mini lock nut should work fine for holding on the piston. Ryan no I have tried the M2C pistons but they look interseting. I would start with what they suggested and run 27.5.
Some others have noticed the same thing. I am not sure what it is. My car had a similar issue. I would just run it and let the gears break in. That is what I did and things have freed up fine.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-18-2013, 02:38 PM   #2148
jmc5313's Avatar
Some others have noticed the same thing. I am not sure what it is. My car had a similar issue. I would just run it and let the gears break in. That is what I did and things have freed up fine.[/QUOTE]
It when i bolt the tranny halves together....i checked for small debris etc...when i rotate both outdrives togetherů about 90░ of rotation feels bound up or tight...the other 270░ feels free...oh well...onward and upward!!!! By the way this is my first tlr build so keep by those computers and smart phones!!!! Thanks!!
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 03-18-2013, 02:54 PM   #2149
Casper's Avatar
I am missing the diff outdrive o-rings!!! Wtf
It when i bolt the tranny halves together....i checked for small debris etc...when i rotate both outdrives togetherů about 90░ of rotation feels bound up or tight...the other 270░ feels free...oh well...onward and upward!!!! By the way this is my first tlr build so keep by those computers and smart phones!!!! Thanks!![/QUOTE]
Oh that is not right. Mine had one spot that felt high. Not 1/4 of the rotation. There is either something not seated properly. Check to make sure you got the outdrive bearings on all they way. They are a tight fit now.
Old 03-18-2013, 03:10 PM   #2150
BmainStar's Avatar
Originally Posted by Casper View Post
Congrats on breaking down and getting a kit! .
..... another customer fitting into the bizz model???
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 03-18-2013, 03:16 PM   #2151
Sweet, you guys coming down to represent TLR @ the DE Racing Spring Series or just to see what those Tekno guys are up too?
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 03-18-2013, 03:18 PM   #2152
jmc5313's Avatar
Oh that is not right. Mine had one spot that felt high. Not 1/4 of the rotation. There is either something not seated properly. Check to make sure you got the outdrive bearings on all they way. They are a tight fit now.[/QUOTE]
Ok got that fixed...one ring gear bolt wasnt as tight as other 3.. spins free now...next? Pins...there were four in bag b...they look the same but have three different part #'s...what??? Do i use two for sun gear and two for the wheel hexes???
3MTA3
Old 03-18-2013, 03:41 PM   #2153
Ok got that fixed...one ring gear bolt wasnt as tight as other 3.. spins free now...next? Pins...there were four in bag b...they look the same but have three different part #'s...what??? Do i use two for sun gear and two for the wheel hexes???[/QUOTE]
Yes, you got it.
-Ryan Dunford
Old 03-18-2013, 03:45 PM   #2154
Casper's Avatar
Dude- I know you have been a loyal customer and we apprecaite the support but this was not the business model and TLR has worked hard to have prompt parts support with kit releases. There was a hiccup with this release and the parts were not shipped with the kit. TLR is working hard to get the parts here as soon as they can and get them out there. There is nothing devious going on here and they are not trying to screw the end user and force them to get a kit instead of buying upgrade parts. The business model is to sell kits and parts. Margins a little better on parts then kits. They don't care how you get your parts. In a kit or piece parts. Peice it together or buy a kit? I understand you are frustrated and we all want you to have your parts so you can upgrade you truck but give it a rest!
The pins that secure the outdrives to the diff case and the pins that are used for the clamping hexes are the same part so you get 4 in the bag for the front and rear ends. It is not super clear as you see the 4 pins and build the diffs first and use two and then the axles many steps later to use the other two but that is where these pins go. Does that help?
Old 03-18-2013, 03:47 PM   #2155
Blown up's Avatar
When they say 2 hole 55 pistons do they mean the 4 hole 55's w/2 holes filled?
XB4 RSpro/LRP 7.5 JR9000s, SCTE 2.0 RX8/Pro46 DS1015, SC10.2 RS/D3.5 17.5 DS1015,
Blown up is offline   Reply With Quote
Old 03-18-2013, 03:53 PM   #2156
XRated SCT's Avatar
Yup
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-18-2013, 03:53 PM   #2157
drepus's Avatar
Yes.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 03-18-2013, 04:14 PM   #2158
xxfile's Avatar
Originally Posted by agarabaghi View Post
you have a link to the power tool you use?
http://www.bing.com/images/search?q=...electedIndex=8
this isnt it but more or less the same has 1/4 inch drive for hex bits
xxfile is offline   Reply With Quote
Old 03-18-2013, 04:35 PM   #2159
2low4u's Avatar
Hey xxfile, did u end up ordering your 2.0 through Great Hobbies?
Losi 8 2.0 Tekno E-Conversion, Tekin RX8 Gen1, Tekin 1900kv
TLR SCTE 2.0, Tekin RX8 Gen 2, Tekin Pro4 4600kv.
Assoicated B4.1FT Worlds Edition, BH 120A, Turnigy 8.5T & 17.5T.
Futaba 4PL.
2low4u is offline   Reply With Quote
Old 03-18-2013, 04:43 PM   #2160
CanadianNascar's Avatar
I was checking there, but part #TLR03000 comes up "not in stock"
But hobby shop in Markham had them in stock, Pinnacle Hobbies.
CanadianNascar is offline   Reply With Quote
