Old 03-18-2013, 01:50 PM   #2131
XRated SCT's Avatar
What's a replacement ring gear I could get for my 2.0
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-18-2013, 01:53 PM   #2132
jmc5313's Avatar
Originally Posted by agarabaghi View Post
are you sure?
Bag B...oring that goes between washer and diff case for the out drive...
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 03-18-2013, 01:54 PM   #2133
Grandturk's Avatar
http://www.stormerhobbies.com/cgi-bi...cs&pn=losb3572
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-18-2013, 01:55 PM   #2134
jmc5313's Avatar
Bag d has eight of em...am i supposed to rob these?
3MTA3
Old 03-18-2013, 02:00 PM   #2135
jmc5313's Avatar
Dumba$$.... clear rubber o rings are hard to spot for dummies!!!
3MTA3
Old 03-18-2013, 02:04 PM   #2136
XRated SCT's Avatar
Originally Posted by Grandturk View Post
Is it better to run the stock plastic spur or is that 1 from stormer better to buy
Old 03-18-2013, 02:05 PM   #2137
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
plastic should be fine. just get a good mesh
agarabaghi is offline   Reply With Quote
Old 03-18-2013, 02:09 PM   #2138
XRated SCT's Avatar
That's the thing the track I run on isn't an official track it's a homemade one, nice but it's loose dirt has more of the realistic feel to it and yesterday a rock or pebble put a dent in my spur through every tooth lol but my rr pinion is perfectly fine
Old 03-18-2013, 02:14 PM   #2139
http://www.ebay.com/itm/Hot-Racing-L...90834485572%26
Old 03-18-2013, 02:15 PM   #2140
XRated SCT's Avatar
thanks I'll probably pick up that 1
Old 03-18-2013, 02:16 PM   #2141
So i have a question for Ryan or Casper i have had my 2.0 for a week now and i got one night of club racing on it already, but i am seeing a lot of aluminum servo horns on here and i was wondering your opinions on these? Is the stock setup that comes with the truck reliable or is a aluminum horn just a better option? I was always told that you can run aluminum horns if the saver is plastic but if the saver is aluminum to stick with plastic horns, this truck kind of has a combo of both so any input would be great. Thanks
Showtime90 is offline   Reply With Quote
Old 03-18-2013, 02:28 PM   #2142
I run a metal gear servo, run my servo saver tight, and a metal horn...BUT, if my servo fails, then I will put a new one in. I havent had a servo fail in this struck since running the spektrum 6040. Now, that being said, I do this to get the most precise steering possible with a great amount of disregard to the servo. What I tell most people is run a metal gear servo, run the aluminum servo horn, tighten the servo saver and then back it off 1/2 to 3/4 of a turn just as the build tips say. The plastic horns hold up well that we make as we have the two different plastics in them. Over time, and heat cycles, they can get a little give to them and thats when its needed to change them.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 03-18-2013, 02:50 PM   #2143
Talking Breaking Down
So last week I ended up cancelling my conversion parts order as I figured if I'm gonna have to wait, then I should at least see what the prices will be at my LHS and online. This weekend I went to my LHS to see what they knew and there it was all by its lonesome, begging to find a home , a SCTE 2.0 kit. Needless to say I broke down and bought the kit. I already have almost all of the hopups that I was working on for my 1.0, and will now add to my 2.0 as backups. I tried gluing the 55 pistons and think the smaller aluminum 4-40 nuts work better in case the glue cap is to large. I had to clear off and apply a new glue cap on a couple of holes after I tightened down the steel lock nut; the aluminum lock nut has a smaller contact patch on the piston. I'm also going to try the M2C Racing pistons as well. I'm not sure what weight oil to try, so any input on that is appreciated (SoCal indoor; SDRC). I'm leaning towards 27.5 up front and 30 in the rear.
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 03-18-2013, 02:58 PM   #2144
jmc5313's Avatar
Default Diff question
Hacker or casper...I am assembling the front diff when i bolt the case halves together i get a tight spot when i rotate the pinion...when its totally loose no tight spot..when half tight it is a slight tight spot...any suggestions....
3MTA3
Old 03-18-2013, 03:00 PM   #2145
XRated SCT's Avatar
I'm running the spek. 6040 as well and I picked up a 23t aluminum arm for it but it doesn't fit, what saver and arm are you running
SEO by vBSEO 3.5.0
