Like Tree4Likes
Old 03-17-2013, 07:49 PM   #2086
rfleck's Avatar
Trader Rating: 58 (100%+)
Originally Posted by hacker07 View Post
Yeah, I ran that esc with the Tekin 4600. You have to update to the 4 pole software though.
Thanks Ryan! Is a fan needed to keep temps reasonable? What pinion would you suggest?
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
rfleck is offline   Reply With Quote
Old 03-17-2013, 07:52 PM   #2087
BmainStar's Avatar
Originally Posted by easye View Post
First time running the new truck and first race. Truck was awsome.
Good work!!!!!!!
Hey guys A bit off topic, I know,.. any one running an M11 X??? I posted this ? in radio section m11 thread but may not get an answer there for a while. Having trouble with the wheel not returning to center ,was told that the return spring needs to be replaced. Have any of you ever done this???Is it hard to do? Thanx ,Riverdale.
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
Old 03-17-2013, 08:17 PM   #2088
Trader Rating: 60 (100%+)
Shock help. any one have a problem with the shock bottoms screwing on? they are so tight and will tighten down. any help? tricks? maybe tomorrow il contact losi and see whats up.
it worked before you crashed it and broke it.
Graphite07 is offline   Reply With Quote
Old 03-17-2013, 08:21 PM   #2089
drepus's Avatar
Not Ryan but I've been running the r10 pro for awhile and I always use the fan since you can really put the power down in these stout trucks. The esc is always warm to the touch after a run with the fan,never hot. I did have the fan die once on a tight indoor carpet track and it got up to 170 but survived.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 03-17-2013, 08:28 PM   #2090
CanadianNascar's Avatar
Originally Posted by Casper View Post
Yes they are supposed to go all the way to the bottom of the body. There was an issue with the lower caps and Horizon will send you out new ones if you could not get the kit ones on. The issue was addressed but not until after the kits were shipped. Check out this tip.
http://losiracing.blogspot.com/2013/...uild-tips.html
Thanks Casper, I did see that link, but the caps look short to bottom out on the shoulder so I did not force them. Maybe I will try the heat gun method.
CanadianNascar is offline   Reply With Quote
Old 03-17-2013, 08:42 PM   #2091
rfleck's Avatar
Ok, so the Tekin Rx8 would be better I presume? I'd like to run without a fan if possible.
Ron Fleck Jr.
Nemoracing USA!
Agama-Beta-Bullitt!
Old 03-17-2013, 09:02 PM   #2092
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Regarding the bottom shock caps. If they seem tight can u just force them on and they will work fine?
Blitzrockey is offline   Reply With Quote
Old 03-17-2013, 09:09 PM   #2093
drepus's Avatar
rx8 should be fine w/o a fan.
Dave Henry
Old 03-17-2013, 09:45 PM   #2094
Originally Posted by 87MagnumII View Post
Just got mine together. I have the tekin pro4 4600. What gearing do you guys recommend? Mostly will be on a big outdoor track. Some time will be spent on a medium indoor track.
Forgot to mention I'm running the rx8 esc. Still haven't seen much as far as gearing opinions for this setup. Anybody got a clue? I'm guessing around 12-14 tooth pinion but that's just a wild guess
87MagnumII is offline   Reply With Quote
Old 03-17-2013, 10:23 PM   #2095
Casper's Avatar
Originally Posted by Purdue Engineer View Post
Does someone have the length measurment of the shock mounting at "full droop?"
I want to use the droop screws in the arms so I am going to back the heim end out of the bottom shock shaft a few turns and adjust the droop screws to the proper measurment.
Thanks guys
You can always screw the eyelets in and measure them. And then do what you are saying. We have been letting the shocks limit droop for a very long time and have had no issues. The 2.0 comes with the steel droop screws so droop settings with the setscrews should hold very well but I don't understand the need to do the extra effort. We typically only use the droop screws if we want less then full droop.
Originally Posted by triple7s View Post
Anyone know if the 1.0 bottoms fit the 2.0? Mine are tore up. Waiting for customer support to open Monday to get new ones....sux
Shock bottoms from the 1.0 will transfer as the 2.0 shocks are the same. TLR is working on the shock bottoms. It was an issue with the mold they are fixing.
Look at the kit building tips on the TLR blog. This method works well.
13-14 is the right range for the 4600. I run a 14 almost everywhere.
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-17-2013, 11:22 PM   #2096
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
This truck has been a blast the past few days. I've blown off friends and family because of it. Its been a bad habbit lately. Should come with a warning label!
I like the 3 and 4 pistons with 27.5 weight oil on low conditions and the 2 hole 55's with 32.5f and 30r for medium to high bite conditions... just saying.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 03-18-2013, 04:59 AM   #2097
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Well I finally got around to building my kit on sunday after all the hosue guest left.
Build went pretty well. I did run into the normal issues, mainly the diff screws and the shock bottoms. Overall the kit was easy enough to build, but it sure would have made it a lot easier if I had the right size tools, had to used hex bits for almost everything.
Couple of questions:
Is there a lil play in the steering? Is that normal?
For the rear Im running the inside hole on the rear blocks with the turnbuckles threaded almost all the way in, Anyone else running it like this?
Shock cap issue, gonna call horizon today about the replacement ones. Does anyone know if another company makes alum ones?
I attached my RX to the side, but it's pretty jammed in there. I might look into getting the micro rx from spektrum.
Pictures:
agarabaghi is offline   Reply With Quote
Old 03-18-2013, 05:39 AM   #2098
All I know is I am going to do the heat gun thing! Losi going to send me new parts. I didn't spend over 400$ for the Shocks not to build right!! So today I will be calling them.
Old 03-18-2013, 05:43 AM   #2099
Yea i don't have a heat gun, so i guess i wont be running the truck till the new parts come in =(
Old 03-18-2013, 06:19 AM   #2100
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Shock bottom crying the damn car will still run......love my truck
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
