Like Tree4Likes
Old 03-14-2013, 02:37 PM   #1951
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Originally Posted by Purdue Engineer View Post
Can someone explain the setup sheet where it says bump steer. I pretty much know what it is but how to change it one the car. It says up on the setup sheet. Does that mean the rod end that connects to the bell crank at the center of the car should be up as high as possible? If thats the case then the manual shows it as low as possible. What about at the spindle? The ball end has a spacer on one side so if it is, bump steer up, the washer should be on the bottom at the bell crank. Is that right? Sorry if your all lost. I'm doin the best I can.
Thanks guys.
Where the steering turnbuckle attaches to the steering spindle is where the bump steer is adjusted. the hight of the ball where it attaches to the spindle is where the bump steer is adjusted. If you look at the ball that goes in the turnbuckle end there is a shoulder on one side of the ball which is what they are referencing. If it says up the shoulder on the ball goes down, if it says down the shoulder goes up. Hope that makes sense.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 03-14-2013, 02:41 PM   #1952
Casper's Avatar
Trader Rating: 33 (100%+)
Thanks guys.
The ball ends have a protrusion on one side and not on the other so how you orient this ball will raise or lower the rod end.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-14-2013, 02:45 PM   #1953
Grandturk's Avatar
Originally Posted by -WHEELMAN- View Post
Where the steering turnbuckle attaches to the steering spindle is where the bump steer is adjusted. the hight of the ball where it attaches to the spindle is where the bump steer is adjusted. If you look at the ball that goes in the turnbuckle end there is a shoulder on one side of the ball which is what they are referencing. If it says up the shoulder on the ball goes up, if it says down the shoulder goes down. Hope that makes sense.
Opposite - it refers to the ball. So ball up or ball down. Shoulder location is opposite the ball orientation. So bump up is shoulder down, etc
Edit - Casper beat me. The old 1.0 setup sheet has a picture of the orientation.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-14-2013, 03:27 PM   #1954
-WHEELMAN-'s Avatar
Originally Posted by Casper View Post
The bell cranks are plastic. Ackerman bar is metal, Steering posts are metal.
Edited thanks.
Old 03-14-2013, 04:37 PM   #1955
Purdue Engineer's Avatar
Thanks guys! Thats the way I had it, just make sure. I wasn't sure if you adjusted the bell crank side. So just spindle side and bump steer up means spacer down, (the ball as high as possible). Thanks
Purdue Engineer is offline   Reply With Quote
Old 03-14-2013, 05:12 PM   #1956
Talked to my lhs today. The kit finally shipped and should be in tommorow! They are a "non-privleged" shop.
arrtay is offline   Reply With Quote
Old 03-14-2013, 06:16 PM   #1957
TCCustoms's Avatar
haha, just released the 2.0 and now TLR has brought out the TLR 22SCT RTC
http://www.shortcourse.eu/2013/03/tl...hort+Course%29
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 03-14-2013, 06:25 PM   #1958
TCCustoms's Avatar
Well i had a few mins so i took some advice and it seemed to work out so the QTEQ connections were flipped on the motor and i shortened up the motor wires by about 3-4"
Old 03-14-2013, 06:25 PM   #1959
Panda-PR's Avatar
http://www.amainhobbies.com/product_...ort-Course-Kit
In stock at Amain. I still want to support my LHS but the anticipation is killing me!!!
snake pit:
Serpent: S811T TE-Novarossi Roma/Werks 2058 | S811b-e 2.0
Kyosho MP9 TKI3 Nova 4btt wc & Losi SCTE 2.0
Thanks to Merlin Fuel/Sweep Tires
Panda-PR is offline   Reply With Quote
Old 03-14-2013, 06:58 PM   #1960
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
looks much better the new way CC
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-14-2013, 08:52 PM   #1961
CarlCrocco's Avatar
Trader Rating: 88 (100%+)
No ESC shelf, No RX box, No Rockguard by the ESC or Servo?
Was that stuff really not included to shave 50 grams?
Andrew Crocco "The Hammer"
Viper R/C
XB9E XSCT
CarlCrocco is offline   Reply With Quote
Old 03-14-2013, 09:13 PM   #1962
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Makes sense to me. Throw a piece of lexan on the side pod if you'd like to protect the receiver. Well worth the weight savings.
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 03-14-2013, 09:26 PM   #1963
CRCDUDE's Avatar
Trader Rating: 50 (100%+)
IF Im not mistaken, I think the MIP cowling will fit perfectly
Covers the electronics back to the center diff
Tekno RC http://www.teknorc.com
Trakpower Speed Equipment http://trakpowerusa.com
King Heads http://www.kingheads.com http://www.kinghobbiesandraceway.com
MIP http://miponline.com/store/index.html
AKA http://www.raceaka.com
CRCDUDE is offline   Reply With Quote
Old 03-14-2013, 09:30 PM   #1964
got to run my 2.0 on the track today and i must say it is faster then the 1.0. The truck is alot more nimble, reacts quicker to stearing inputs, and alot smother on the track. Overall a true race truck. Well done TLR!
fantomdude is offline   Reply With Quote
Old 03-14-2013, 09:53 PM   #1965
blade329's Avatar
Trader Rating: 114 (100%+)
Well, since everyone pretty much was removing them from the 1.0, Losi probably figured they weren't needed. Can't please everyone.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
