TLR TEN-SCTE 2.0 Kit Thread
#182
Oooooh - the new chassis has screws for droop screw inserts! Nice. No more chewing up the chassis with your droop screws!
#183
Hmmmm step A6 - how exactly am I supposed to get a wrench on the front torque rod nut from underneath. Looks like you've got to do A-6 before A-4. That is - attach the front torque rod to the underneath of the steering assembly top plate before installing the top plate.
#184
This begs the question... why didn't we see blow out prices on the SCTE like we did on the 8ight 2.0?
No trolling, just curious... or did I miss it?
#185
#186
Hmmmm. How come the manual shows a picture of losa6046 rod ends, but the numbers in the manual are losb4023? Step b-9a for instance...
Pics of the truck just look like regular old 4023
Edit - check out step b-12 you've got both types of link ends in there!!! Love it!
#190
#191
Love the shock upgrades that are included in the kit! Ill be able to keep my old shocks as spares/alternate setups as they are the same - just a little more worn.
Can we get the O rings for the shock shafts available without buying the "rebuild kit" - just give me a pack of 4 or 8 SCTE O rings!!!
#194
We are starting with basically the kit setup for tonight and will adjust from there. Being we have been testing with similar setups to this chassis for a while we should be close out of the box but as we play with the full new car we will post a new setup as we get some more wheel time with the car.
