Like Tree4Likes
Old 03-11-2013, 05:42 PM   #1756
roberto_1029's Avatar
Send a message via Yahoo to roberto_1029
On the set up sheet when it says 1.8mm and 2.0mm is that the thickness or how much of the sway bar that
extends past the hollow ball end?
Losi 8ight-E 2.0--Traxxas slash 4x4 Ultimate (Scalpel Build) --TLR SCTE 2.0
TLR 22SCT--TLR 22T --Axial Wraith
roberto_1029 is offline   Reply With Quote
Old 03-11-2013, 05:52 PM   #1757
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Gso125 View Post
My front diff does the exact thing I posted a while back and no one responded. I took it apart and redid it a few times thinking it was my tekno outdrives. So I put it back together with the losi ones for now. I hope after a few runs they break in an seat.
There are some gears out there that have a high spot on them. This breaks in quickly and has not seemed to effect performance at all and goes away quickly.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 03-11-2013, 05:53 PM   #1758
maddog9's Avatar
Trader Rating: 29 (100%+)
No. The sway bar thickness.
maddog9 is offline   Reply With Quote
Old 03-11-2013, 05:57 PM   #1759
Trader Rating: 28 (100%+)
I just measured them and that's there thickness. I also just picked up a sway bar set with 3 front and rears for tuning later on.
Gso125 is offline   Reply With Quote
Old 03-11-2013, 05:59 PM   #1760
Thanks for the info Casper I will just run it and check it out after.
Old 03-11-2013, 06:04 PM   #1761
Originally Posted by -WHEELMAN- View Post
I saw some of you didnt understand a good way to get electronics in this car so I took a few pics of mine. The ESC wire is running out of the RX directly under the servo across the bottom of the chassis. I will post the finished product tonight.
thanks for posting your pics. Looks very clean and clutter free. I just picked up my wire today and will follow how you set up your rx/transponder
Old 03-11-2013, 06:27 PM   #1762
XRated SCT's Avatar
Same thing happened to my rear and center diff., once I ran it yesterday about 3 or 4packs it was gone
Tekno SCT410--RX8 g2/Pro4 HD4300--RP green
Associated FT T4.2--RS g2/Redline g2 17.5--RP blue
XRated SCT is offline   Reply With Quote
Old 03-11-2013, 07:40 PM   #1763
maddog9's Avatar
Same issue with my rear as well.
Old 03-11-2013, 07:54 PM   #1764
TCCustoms's Avatar
Originally Posted by RC-Rick View Post
Yes the washer inside looks larger than it should be....it happens.
yup, didnt round the top off far enough! Called horizon and they are sending them and he said we will pry know before horizon on the lower shock caps and when they are out if we want them but he said Ryan is the GO-TO guy on the info....
Originally Posted by justinhardin View Post
I'm in the process of building a new TLR SCTE 2.0 kit.
My diffs themselves are smooth... feels like I got them built right.
Once the diffs are installed into their gearboxes (LOSB3104), when I fully tighten the gearbox screws, the diff binds on part of the rotation. It'll spin freely for 85% of a rotation...then it binds/slows down for the remaining 15% then frees up.
Inspecting the housing, there is VERY LITTLE clearance between the ring gear and the gearbox itself. Suspecting this as the source of the bind I shaved a bit of gearbox plastic material away and it seemed to help. I got them moving in the gearbox smoothly (or so I thought).
However, now that everything is installed onto the chasis... at least one of the three gearboxes is still binding (extra friction, not freezing) on part of the rotation.
Is this a known problem with a known fix? Will the bind work itself out after I run it for a bit (the metal ring gears chewing through whatever plastic is binding and then running free?).
Thanks in ad ance for any pointers!
The rear of mine was close to rubbing and kinda did but once all together it rolls smooth...
As for the binding....take it apart and make sure all your bearings that go on the outdrives of the diffs are pushed all the way on! This was my problem with the front as it was tight when rotated to a certain spot and once the bearings were pushed all the way in(didnt realize it at first) but all was good after that.
1/10 Traxxas Summit Blue
Axial AX10 Scorpion * Viper VSC 240/55t combo * Hitec HS-7954SH
TCCustoms is offline   Reply With Quote
Old 03-11-2013, 08:07 PM   #1765
For those of you waiting, hang in there the truck is worth it. The weight difference is very noticable in handling as well as the work put out to run it. 3 of us noted nearly 1000mah less use in a 5 min. Race. Motor temps are way down as well from the 1.0. Turning is also a lot more crisp.
ISSUES is offline   Reply With Quote
Old 03-11-2013, 08:24 PM   #1766
Trader Rating: 68 (100%+)
Originally Posted by bigbeej View Post
Will the carbon center top plate fan mounts from the 1.0 fit the 2.0 the same? Something like this:
http://www.snrgraphite.com/index.php...products_id=87
Volcomstned is offline   Reply With Quote
Old 03-11-2013, 08:42 PM   #1767
Dos Andos's Avatar
Trader Rating: 32 (100%+)
Can you just use the associated 12mm 2 hole pistons on the SCTE 2.0 as you do in the 22 and 22sct if you want to run the Ryan/Casper setup?
Cheers
"Andy T"
www.adelaiderc.com.au - Team Driver
[email protected]
www.modelflight.com.au
*ARCR* member
Dos Andos is offline   Reply With Quote
Old 03-11-2013, 09:04 PM   #1768
Grandturk's Avatar
Cheers
Those pistons have holes that are too big and will not generate enough pack for this truck.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-11-2013, 09:06 PM   #1769
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Cheers
I ran them on sunday and she worked well!
☆ Daryl Boston | TeamBlackStarRacing |
☆ TLR | Hot Bodies | Hobbywing | Savox | MT4S | AKA | Avid |
☆ TLR 22 2.0 MM | HB D413 | Schumacher K1|
☆ Coral Springs RC Track | Mills Pond RC Track | South Florida|
BlackStarRacing is offline   Reply With Quote
Old 03-11-2013, 09:09 PM   #1770
BmainStar's Avatar
At this point seeing every one with their 2.0 is really starting to PISS ME OFF!!!
I had a million spares from my 1.0 and very fresh parts to build a 2.0!WHERE are the parts RYAN!????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????Pegasus does not even have the kits yet!!!!!!!!!Where are the parts????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????:f laming::flamin g:I know in a month it wont even matter but this is Toy cars and I am an impatient Scrubb wanting to play with ever body else....
Toy Car Playerz
West Coast
BmainStar is offline   Reply With Quote
