Like Tree4Likes
Old 03-10-2013, 09:54 PM   #1711
blade329's Avatar
Trader Rating: 114 (100%+)
I saw a guy with a 2.0 at Tony's Hobbies yesterday. His truck looked great! Unfortunately, I didn't get a chance to run with him, with my 1.0.
Traxxas Slash 2wd XL-5,
Losi SCTE 2.0,
Associated FT B4.2,
Associated FT T4.2
blade329 is offline   Reply With Quote
Old 03-10-2013, 09:58 PM   #1712
Grandturk's Avatar
Got to run my truck for first time today. It's certainly a better truck than I am a driver. Amazingly nimble. Does not feel like a tank at all. Was carving tight indoor turns no problem.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 03-11-2013, 12:09 AM   #1713
Dos Andos's Avatar
Trader Rating: 32 (100%+)
Hi all
Is the kit setup what most of the TLR team are running? Apart from minor changes in diff and shock oils....
Cheers
"Andy T"
www.adelaiderc.com.au - Team Driver
[email protected]
www.modelflight.com.au
*ARCR* member
Dos Andos is offline   Reply With Quote
Old 03-11-2013, 04:15 AM   #1714
weavty1's Avatar
Thumbs up
Originally Posted by Dos Andos View Post
Hi all
Cheers
Yes.
Tylor "with an O" I can levitate birds. No one cares.
TLR 22 2.0 RM / TLR 22 2.0 MM / TLR 22-4 / TLR 22T / TLR 22 SCT / TLR SCTE 2.0 / TLR 8IGHT-E 3.0 / Team Losi XX-4 WE / Team Losi XXX-4 G+
weavty1 is offline   Reply With Quote
Old 03-11-2013, 05:28 AM   #1715
fpart's Avatar
Trader Rating: 39 (100%+)
Send a message via Skype™ to fpart
It looks from the setup sheet that the link positions are different also
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 03-11-2013, 05:56 AM   #1716
Trader Rating: 25 (100%+)
Send a message via AIM to agarabaghi
Hopefully the non HCP order ship this week!
agarabaghi is offline   Reply With Quote
Old 03-11-2013, 06:18 AM   #1717
Grandturk's Avatar
I think the box stock camber link locations use the 1.0 locations. The team setup uses the new camber link slots
Old 03-11-2013, 06:48 AM   #1718
weavty1's Avatar
I REALLY wish the kit parts were available already...
Old 03-11-2013, 07:09 AM   #1719
Integra's Avatar
Originally Posted by WillSeckold View Post
Does anyone know what Buku clutch you can get for this truck
Huh ?
Old 03-11-2013, 07:10 AM   #1720
Grandturk's Avatar
I feel for you guys that just bought a 1.0 and dropped coin on all the upgrades... But damn if I don't love my new truck!!!
You guys that are Doing the upgrade route - don't forget the shock towers. I think the new camber locations are key to the way this thing handles.
Old 03-11-2013, 07:45 AM   #1721
Casper's Avatar
Trader Rating: 33 (100%+)
Hi all
Cheers
The setup on the first post is what Ryan and I have been running. It is shock changes you already meantioned as well as some camber link changes and ride height.
Front from the 1.0 rear is new locations.
Yes camber links make a big difference with the new towers. Chassis layout made a huge difference as well. Lots of testing went into that.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 03-11-2013, 07:49 AM   #1722
hkrob's Avatar
Trader Rating: 18 (100%+)
What color was the truck it might have been mine I was running at Tony's Saturday afternoon/evening.
hkrob is offline   Reply With Quote
Old 03-11-2013, 08:02 AM   #1723
Originally Posted by TCCustoms View Post
ok, so just put the bag of wheels on the for sale section last night and took out the antenna tube, cover, and wheel nuts out and put the wheel nuts on to find out that 1 was bunk...look closely at the 1 on the left, didnt even round it off to keep insert in
Yes the washer inside looks larger than it should be....it happens.
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 03-11-2013, 08:27 AM   #1724
Purdue Engineer's Avatar
So I just finished the build. Well, I have to do my shocks yet with the 2x 55 pistons. I was thinking: How are you guys check and measure the front toe on the truck without a huddy setup rig?
Also, whats the deal with the front sway bar? It's almost like it's to short. I can't get the end of the bar to stick through the end. Whats the trick to setting these, front and rear. I'm used to haveing a ball link that you can lean forward or back to change pre load.
Purdue Engineer is offline   Reply With Quote
Old 03-11-2013, 08:35 AM   #1725
So in anticipation of my parts, I started on the HD diff cases. Pre-threading is definitely the key. I used a stock screw and my mini drill and didn't strip anything; granted the screw did get hot. I'll get those finished up along with the shocks tonight.
