RC10T4.2 Factory Team
#1531
I too had this problem with my last body. This time around, I actually lost the wing in the trimming/painting stages, and just decided to run without it. I don't notice a difference in the way it drives. 8.5 turn motor on indoor carpet, offroad.
#1534
Also/FYI, Apex models UK said the CT4.2 kit should be available in September. I ordered the chassis, shock tower and side braces. We'll see if I get them before September.
http://www.apexmodels.com/index.php?...arch--type=ALL
#1535
R/C Tech Elite Member
No I switched to the .1 arms and tower pretty quick after getting the truck. I probably could've tuned the shocks to the chassis but it was bad enough I just put the plastic one back on. A very noticeable difference in handling.
Any word if the centro will have an aluminum chassis?
That would be sweet!
#1544
Hey guys, so changing out the t4.2 front arms to the .1 arms will make the truck have less aggressive steering?
If so, what do i need to to change other than the .1 arms? Shock tower? Caster blocks? Let me know your thoughts.
Thanks in advance.
Thanks in advance.
#1545
Just the 4.1 front tower and front arms, much much nicer to drive and jumps better too
