Set-up stations... Which is best?
#21
I'm not saying the Integy is the same quality as a Hudy but I've used an Integy before and it worked perfect for me. I set up a 1/8 buggy with it and it was a pretty nice setup station. Actually surprised me that it was made by Integy. I've also used a Hudy and it worked the way it should just like the Integy did.
If you haven't seen or used the Integy and Hudy then hold your negative comments on the Integy.
#22
You could buy the 1/8th scale hudy and buy integy adapters for your 1/10th scale cars and you should be able to use one. The integy adapters screw on the axles and make them the same size as a 1/8th scale. I think it will work. Not sure if anything integy should be allowed to touch hudy though
#23
I thinking of getting this Integy since I can use it for both offroad and touring car...
http://www.integy.com/st_prod.html?p...3#.USWCM94o7IU
