need help picking the right battery
I bought a ae b4.1 and would like advise on the type of battery i should get for it.
it says 2s or a 3s can be used. I'm not sure which I should pick. they recommend their wolfpack 2s 3000mah 25c 50c burst but Im nervous about if this will no produce the performance I will need to keep up with the other guys.
but im afraid if i go with a 3s of the same c ratings it will be too much.
what do you guys suggest?
If your just starting, don't worry about keeping up - just focus on getting around the track. Otherwise a 2s 3000+ man 30+ C pak is going to be plenty.
this is what the guy at the hobby shop said. I felt bad not buying any from him. he only had $50 ones. but I did buy the car.
I bought these, hopfully they will be decent.
just need to swap out to the deans connector
http://www.hobbyking.com/hobbyking/s...dProduct=20711
I bought these, hopfully they be decent.
Can't beat this battery for the performance OR the price! Should be a great starter pack for you! Danny at SMC is great!
http://www.smc-racing.net/index.php?...product_id=118
On the hobbyking purchase, look out, most tracks require hard pack lipos....
and it's pretty well protected. as in it's right in the middle away from vulnerable impact areas.
it should fit their wolfpack battery the recommend for it has a foam piece in front of it and it's only a few mm shorter and a lot wider than the turnigy.
if they say something I could make a fiberglass box for it. (I make fiberglass motorcycle farings as a side job)
